Windows 7 Display desktop icons
ehaskell
How do I display icons on the desktop as i do in xp/vista. For example. if i right click on the desktop and creat a new folder it shows upunder desktop on the taskbar but not on the desktop itself. I have to be missing someting very simple.
Thanks
Try right clicking on the desktop, and in the menu follow:
View -> Show Desktop Icons. If there is a checkmark beside it already you'll need to seek another solution.
Did the trick. Went back and saw that was a feature of Vista.
have done most work in xp so it was new to me.
Since you are miles ahead, is there a way to get an icon on the taskbar that allows you to show the desktop with a click I can get it by right clicking on desktop and then selecting show the desktop, a two step process.
Thanks for your help.
Eric
There should be a small vertical rectangle at the bottom right of your taskbar. It's function is exactly what you're after I believe. :)
(It's more to the right than your clock)
Right again and thanks again!!!
The feature is very cool. Makes sense that it works that way--just like the open files.
Eric
No problem :)
Enjoy Windows 7.
Also, there might be a reputation button to add to mine. People get that when they help (I think) so that would be good if you could add to mine :D
EDIT: It's a little heart icon above the post on the right.
