Jaxx89
- Joined
- Apr 3, 2009
- Messages
- 8
- Thread Author
- #1
I currently have 3 SATA drives. 1.5TB x2 and 1TB x1
Drive partitions as following:
C: 499GB
D: 897GB
E: 499GB
F: 897GB
G: 931GB
I am installing a new 2TB SATA 3 drive, but on SATA 2 mode for now.
New config of drives will be quite similar except for that I will be merging the partition of the current drive which has the OS (C: & D
499GB + 897GB
The new 2 TB drive will have 2 partitions C: 499GB and the rest D:
The other drives will remain the same.
SO for this purpose, will I need to reinstall my OS
OR
I can transfer my Current one to my new drive (backup and restore OR third party software)
OR
I can use the System Image of Windows 7 I had created a while ago just in case my OS went corrupt.
I'm kinda confused and that's why I asked this question.
I'm buying a Seagate drive so can I use
C: 499GB
D: 897GB
E: 499GB
F: 897GB
G: 931GB
OR
OR
DiscWizard
EDIT: USERS WHO THINK I'M STUPID TO INSTALL 4 INTERNALS AS SATA AND NO RAID OR SSD, YOUR COMMENTS ARE NOT WELCOME.
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,641
Backup is a good idea. With the help of third party tools you can extend system partition without loosing data and keeping the mbr in working order.SO for this purpose, will I need to reinstall my OS
OR
OR
EASEUS FREE Partition Manager Software: Free Partition Magic alternative for Windows 2000/XP/Vista/7 and Server 2000/2003/2008 Hard Drive partitions.
FREE Partition Manager feature - Hard disk partition management for Windows 2000/XP/2003/Vista/2008/Windows 7 (32 bit and 64 bit): resize/move hard disk partition, convert, split and merge partitions, etc.
Similar threads
- Replies
- 3
- Views
- 2K
