Driver for RS56-PCI modem fax
avz
Hi I hope that you will be able to help. I have a PCI modem fax card that I need in order to send and recieve faxes. the modem has a RS56-PCI chip. all my efforts to find a win7 driver for it (driverguide and other sites) were in vain. the driver that I've found were for older OS, including XP. Is there a universal/generic driver for WIN7 that will enable it to work? or perhaps you know where the proper driver can be found?
Thanx.
Try Vista driver in Vista compatibility mode.
or
Control Panel > System > Device Manager > Right-click on the modem > Properties > Update driver > Browse to the folder with the driver files extracted.
or
Try to install a standard driver http://windows7forums.com/tweaks-guides-howtos/28594-compatibility-mode-standard-drivers.html..
