Driver IRQL not less or equal BSOD - Please HELP!
Hi! These past few days I have been encountering several bsod, it is really frustrating since i don't know what to do. The last bsod I encountered gave the info Driver_IRQL_not_less_or_equal. Please help me to fix this.
Also my pc hangs when I play facebook games.
proc: amd 64 x2 dual core 5000+ 2.6ghz
ram: kingston 2gb ddr2-800
mobo: asus M4A78-VM
graphics: inno3d 9600gt 512mb 256bit
antivir: AVG free 2013
I also uploaded here the requested files/screenshots from rammon, cpuz and SF Diag Tool
usasma
Fantastic Member
SP1 isn't installed, please do the following:
Installing Windows 7 Service Pack 1
1. Visit the PC manufacturer's website and update ALL drivers. DO NOT use Windows Update or the "Update drivers" function of Device Manager.
2. Check Device Manager for any unknown/disabled devices - if there are unknown/disabled devices, fix them with the latest drivers from the device manufacturer's website (not the PC Manufacturer)
3. Visit Windows Update and get all updates (may take repeated visits)
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1: Steps to follow before you install Windows 7 SP1 and Windows Server 2008 R2 SP1 from the Microsoft Download Center
5. Visit Windows Update and get any other available updates. May take repeated visits, but keep it up until you get several "Windows is updated" results.
If you're having difficulties with installing a Service Pack, please use the SURTool from this link: What is the System Update Readiness Tool?
Also, check out this troubleshooting link from Microsoft: Troubleshoot problems installing Service Pack 1 (SP1) for Windows 7 and Windows Server 2008 R2
I have had limited success in installing updates/Service Packs when using a "clean boot". I suspect that I'm just bypassing the problem - and that it can come back to bite me in the butt later on.
Your D: drive is getting overfull and this will hamper your system's performance. You have approximately 10% free space - 15% is recommended. Please remove about 2½ gB in order to reach 15% free space.
AsIO.sys Mon Dec 17 04:10:20 2007 (47663CFC)
Asus PCProbe Utility
http://www.carrona.org/drivers/driver.php?id=AsIO.sys
AtiPcie.sys Tue May 5 11:00:16 2009 (4A005480)
ATI PCIE Driver for ATI PCIE chipset or [br] ATI PCI Express (3GIO) Filter[br]Found in my ATI video drivers (I have an Intel chipset)
http://www.carrona.org/drivers/driver.php?id=AtiPcie.sys
Un-install any ATI video drivers that may be installed on your system.
RTKVHDA.sys Fri May 22 14:03:37 2009 (4A16E8F9)
Realtek HD Audio Codec Driver
http://www.carrona.org/drivers/driver.php?id=RTKVHDA.sys
DLF62X86.SYS Tue Oct 13 07:04:27 2009 (4AD45EBB)
This is your D-Link PCI Fast Ethernet Adapter
DLF62X86.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
npf.sys Tue Oct 20 13:57:28 2009 (4ADDFA08)
NetGroup Packet Filter Driver, part of the WinPcap packet capture library
http://www.carrona.org/drivers/driver.php?id=npf.sys
If these updates don't stop the BSOD's, then please start with these free hardware diagnostics: Hardware Diagnostics
Analysis:
[FONT=lucida console]**************************Sat Sep 15 11:36:51.817 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091512-38563-01.dmp]
Windows 7 Kernel Version [B]7600 [/B]MP (2 procs) Free x86 compatible
Built by: [B]7600[/B].16385.x86fre.win7_rtm.090713-1255
System Uptime:[B]0 days 0:31:26.705[/B]
BugCheck Code: [B]BugCheck D1, {0, 2, 8, 0}[/B]
Probably caused by :[B]USBPORT.SYS ( USBPORT!USBPORT_Core_iCompleteDoneTransfer+6e0 )[/B]
BugCheck Info: [B]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/B]
PROCESS_NAME: [B]System[/B]
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]0xD1_CODE_AV_NULL_IP_USBPORT!USBPORT_Core_iCompleteDoneTransfer+6e0[/B]
  BIOS Version                  1502
  BIOS Release Date             09/22/2009
**************************Fri Sep 14 22:09:21.923 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091512-24913-01.dmp]
System Uptime:[B]0 days 0:21:16.827[/B]
BugCheck Code: [B]BugCheck 19, {3, 848342c0, 0, 848342c0}[/B]
*** ERROR: Module load completed but symbols could not be loaded for Npfs.SYS
Probably caused by :[B]Npfs.SYS ( Npfs+8fa5 )[/B]
BugCheck Info: [B]BAD_POOL_HEADER (19)[/B]
BUGCHECK_STR:  0x19_3
PROCESS_NAME: [B]avgcsrvx.exe[/B]
FAILURE_BUCKET_ID: [B]0x19_3_Npfs+8fa5[/B]
  BIOS Version                  1502
**************************Thu Sep 13 05:16:03.697 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091312-23883-01.dmp]
System Uptime:[B]0 days 0:08:22.601[/B]
BugCheck Code: [B]BugCheck A, {0, 2, 0, 82ace6fe}[/B]
Probably caused by :[B]memory_corruption ( nt!MiGatherMappedPages+ff )[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]0xA_nt!MiGatherMappedPages+ff[/B]
  BIOS Version                  1502
**************************Thu Sep 13 03:12:38.164 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091312-26426-01.dmp]
System Uptime:[B]0 days 0:08:28.053[/B]
BugCheck Code: [B]BugCheck 1000008E, {c000001d, 82a60fb9, 8850dd10, 0}[/B]
Probably caused by :[B]ntkrpamp.exe ( nt!KiTrap0D+14d )[/B]
BugCheck Info: [B]KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)[/B]
BUGCHECK_STR:  0x8E
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]0x8E_BAD_IP_nt!KiTrap0D+14d[/B]
  BIOS Version                  1502
**************************Wed Sep 12 13:24:59.703 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091312-26020-01.dmp]
System Uptime:[B]0 days 1:58:44.591[/B]
BugCheck Code: [B]BugCheck 1000008E, {c0000005, 82b697ff, a289aee4, 0}[/B]
*** WARNING: Unable to verify timestamp for avgtdix.sys
*** ERROR: Module load completed but symbols could not be loaded for avgtdix.sys
*** WARNING: Unable to verify timestamp for avgidshx.sys
*** ERROR: Module load completed but symbols could not be loaded for avgidshx.sys
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+19f )[/B]
BUGCHECK_STR:  0x8E
FAILURE_BUCKET_ID: [B]0x8E_nt!ExDeferredFreePool+19f[/B]
  BIOS Version                  1502
**************************Tue Sep 11 02:48:32.527 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091112-29577-01.dmp]
System Uptime:[B]0 days 0:25:17.290[/B]
BugCheck Code: [B]BugCheck 50, {b48dde14, 1, 8cf6cde3, 2}[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VidMmInterface+167e3 )[/B]
BugCheck Info: [B]PAGE_FAULT_IN_NONPAGED_AREA (50)[/B]
BUGCHECK_STR:  0x50
FAILURE_BUCKET_ID: [B]0x50_dxgmms1!VidMmInterface+167e3[/B]
  BIOS Version                  1502
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]AsIO.sys                    Mon Dec 17 04:10:20 2007 (47663CFC)[/B][/COLOR]
[COLOR=RED][B]AtiPcie.sys                 Tue May  5 11:00:16 2009 (4A005480)[/B][/COLOR]
ASACPI.sys                  Wed May 13 07:11:32 2009 (4A0AAAE4)
[COLOR=RED][B]amdxata.sys                 Tue May 19 13:57:35 2009 (4A12F30F)[/B][/COLOR]
[COLOR=RED][B]RTKVHDA.sys                 Fri May 22 14:03:37 2009 (4A16E8F9)[/B][/COLOR]
nvlddmkm.sys                Tue May 15 03:34:51 2012 (4FB2071B)
avgidshx.sys                Thu Aug  9 07:43:23 2012 (5023A25B)
avgldx86.sys                Thu Aug  9 07:44:24 2012 (5023A298)
avglogx.sys                 Thu Aug  9 07:44:40 2012 (5023A2A8)
avgidsshimx.sys             Thu Aug  9 22:31:44 2012 (50247290)
avgmfx86.sys                Thu Aug  9 22:33:14 2012 (502472EA)
avgrkx86.sys                Thu Aug  9 22:33:18 2012 (502472EE)
avgtdix.sys                 Thu Aug  9 22:34:39 2012 (5024733F)
avgidsdriverx.sys           Mon Aug 13 10:28:24 2012 (50290F08)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=DLF62X86.SYS
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
http://www.carrona.org/drivers/driver.php?id=avgidshx.sys
http://www.carrona.org/drivers/driver.php?id=avgldx86.sys
http://www.carrona.org/drivers/driver.php?id=avglogx.sys
http://www.carrona.org/drivers/driver.php?id=avgidsshimx.sys
http://www.carrona.org/drivers/driver.php?id=avgmfx86.sys
http://www.carrona.org/drivers/driver.php?id=avgrkx86.sys
http://www.carrona.org/drivers/driver.php?id=avgtdix.sys
http://www.carrona.org/drivers/driver.php?id=avgidsdriverx.sys
