lololkilla11
Help I have been using my pc lately and iv been getting the driver power stat failure alot lately and what happens is my internet goes out and when I shut down it takes at least 5 minutes until it goes BSOD and the error message appears can some one help me with this and tell me how to fix it as soon as possible because this has been going on for a while and I want it to stop. So can anyone tell me step by step what to do so I can fix this issue and get on with using my pc.Thank You.
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be
found later.
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then:
Please read the first post in this sticky thread here Link Removed
Do...
found later.
Then:
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.
Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
Additionally, if you haven’t already, please take some time and fill out your system specs in your forum profile area Link Removed .
