Windows 7 Driver_Irql_Not_Less_Or_Equal Bsod
JazzMac251
Getting a DRIVER_IRQL_NOT_LESS_OR_EQUAL BSOD when playing SC2 for about an hour or so. Recently upgraded my memory, but I've been having graphics card driver issues for a while.
All the relevant info is attached
Hi Jazz,
Thank you for the info. please update your bios as it is now quite old. Dumps are pointing to this being the culprit but update and see how are then. Here's your motherboards website: ASUS - Motherboards- ASUS P6T
If your unsure how to go on please post back and I'll run it by you..
Hi Jazz,
Thank you so much for your reply. I'll try this out. If you don't hear back from me, assume that your suggestions fixed my problem. Thanks in advance!
