[FONT=lucida console]**************************Mon Jan 28 02:14:00.920 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012813-27190-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 3:38:07.559[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KeWaitForSingleObject+65 )[/B]
BugCheck [B]1E, {ffffffffc0000096, fffff80002ed4c55, 0, 0}[/B]
BugCheck Info: [B]Link Removed[/B]
Arguments:
Arg1: ffffffffc0000096, The exception code that was not handled
Arg2: fffff80002ed4c55, The address that the exception occurred at
BUGCHECK_STR: 0x1E_c0000096
PROCESS_NAME: [B]TESV.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000096_nt!KeWaitForSingleObject+65[/B]
BIOS Version V3.11
BIOS Release Date 05/24/2011
Manufacturer MICRO-STAR INTERNATIONAL CO.,LTD
Product Name MS-7576
**************************Sun Jan 27 22:35:11.689 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012713-24242-01.dmp]
System Uptime:[B]1 days 7:45:09.327[/B]
Probably caused by :[B]win32k.sys ( win32k!NtUserWindowFromPoint+1c )[/B]
BugCheck [B]A, {fffff8002367fb88, 2, 1, fffff80002eee099}[/B]
Arguments:
Arg1: fffff8002367fb88, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff80002eee099, address which referenced memory
BUGCHECK_STR: 0xA
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: [B]Skype.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_win32k!NtUserWindowFromPoint+1c[/B]
BIOS Version V3.11
**************************Sat Jan 26 00:19:09.075 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012513-28204-01.dmp]
System Uptime:[B]0 days 21:26:53.340[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiRetireDpcList+1a9 )[/B]
BugCheck [B]A, {1c4, 2, 0, fffff80002e996d9}[/B]
Arguments:
Arg1: 00000000000001c4, memory referenced
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002e996d9, address which referenced memory
BUGCHECK_STR: 0xA
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KiRetireDpcList+1a9[/B]
BIOS Version V3.11
**************************Fri Jan 25 02:23:40.620 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012513-34164-01.dmp]
System Uptime:[B]1 days 3:22:57.884[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!SwapContext+0 )[/B]
BugCheck [B]A, {80, 2, 0, fffff80002e86120}[/B]
Arguments:
Arg1: 0000000000000080, memory referenced
Arg4: fffff80002e86120, address which referenced memory
BUGCHECK_STR: 0xA
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_nt!SwapContext+0[/B]
BIOS Version V3.11
**************************Wed Jan 23 23:00:09.039 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012313-27814-01.dmp]
System Uptime:[B]0 days 3:30:07.303[/B]
Probably caused by :[B]USBPORT.SYS ( USBPORT!USBPORT_Core_InitTimeout+1d )[/B]
BugCheck [B]1E, {0, 0, 0, 0}[/B]
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
BUGCHECK_STR: 0x1E
PROCESS_NAME: [B]audiodg.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_USBPORT!USBPORT_Core_InitTimeout+1d[/B]
BIOS Version V3.11
**************************Wed Jan 23 19:29:07.565 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012313-32385-01.dmp]
System Uptime:[B]3 days 3:55:42.830[/B]
Probably caused by :[B]USBPORT.SYS ( USBPORT!USBPORT_Xdpc_iSetState+46 )[/B]
BugCheck [B]D1, {4f444648, 2, 0, fffff880042f35de}[/B]
Arguments:
Arg1: 000000004f444648, memory referenced
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff880042f35de, address which referenced memory
BUGCHECK_STR: 0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_USBPORT!USBPORT_Xdpc_iSetState+46[/B]
BIOS Version V3.11
**************************Sat Jan 19 23:15:47.789 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011913-52759-01.dmp]
System Uptime:[B]0 days 4:55:31.428[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+48d4a )[/B]
BugCheck [B]18, {fffffa800822eb40, fffffa800a89e970, 1, 1}[/B]
Arguments:
Arg1: fffffa800822eb40, Object type of the object whose reference count is being lowered
Arg2: fffffa800a89e970, Object whose reference count is being lowered
Arg3: 0000000000000001, Reserved
Arg4: 0000000000000001, Reserved
The reference count of an object is illegal for the current state of the object.
Each time a driver uses a pointer to an object the driver calls a kernel routine
to increment the reference count of the object. When the driver is done with the
pointer the driver calls another kernel routine to decrement the reference count.
Drivers must match calls to the increment and decrement routines. This bugcheck
can occur because an object's reference count goes to zero while there are still
open handles to the object, in which case the fourth parameter indicates the number
of opened handles. It may also occur when the object?s reference count drops below zero
whether or not there are open handles to the object, and in that case the fourth parameter
contains the actual value of the pointer references count.
BUGCHECK_STR: 0x18
PROCESS_NAME: [B]hl2.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x18_CORRUPT_REF_COUNT_nt!_??_::FNODOBFM::_string_+48d4a[/B]
BIOS Version V3.11
**************************Wed Jan 16 20:44:04.150 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011613-29218-01.dmp]
System Uptime:[B]0 days 0:29:26.789[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiDoubleFaultAbort+b2 )[/B]
BugCheck [B]7F, {8, 80050031, 6f8, fffff80002eac4de}[/B]
Arguments:
Arg1: 0000000000000008, EXCEPTION_DOUBLE_FAULT
Arg2: 0000000080050031
Arg3: 00000000000006f8
Arg4: fffff80002eac4de
BUGCHECK_STR: 0x7f_8
PROCESS_NAME: [B]NexusClient.ex[/B]
FAILURE_BUCKET_ID: [B]X64_0x7f_8_nt!KiDoubleFaultAbort+b2[/B]
BIOS Version V3.11
**************************Wed Jan 16 00:00:36.982 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011513-21840-01.dmp]
System Uptime:[B]0 days 4:58:27.262[/B]
Probably caused by :[B]hardware ( USBPORT!USBPORT_InitializeIsoTransfer+4ad )[/B]
Arguments:
BUGCHECK_STR: 0x1E
FAILURE_BUCKET_ID: [B]X64_IP_MISALIGNED[/B]
BIOS Version V3.11
**************************Tue Jan 15 19:01:35.503 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011513-24242-01.dmp]
System Uptime:[B]0 days 19:55:35.783[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiPageFault+260 )[/B]
BugCheck [B]D1, {fffff80000000000, 2, 8, fffff80000000000}[/B]
Arguments:
Arg1: fffff80000000000, memory referenced
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: fffff80000000000, address which referenced memory
BUGCHECK_STR: 0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_CODE_AV_BAD_IP_nt!KiPageFault+260[/B]
BIOS Version V3.11
**************************Mon Jan 14 22:55:19.506 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011413-19422-01.dmp]
System Uptime:[B]0 days 1:02:41.160[/B]
Arguments:
BUGCHECK_STR: 0xA
PROCESS_NAME: [B]winamp.exe[/B]
BIOS Version V3.11
**************************Mon Jan 14 21:52:01.839 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011413-23119-01.dmp]
System Uptime:[B]0 days 20:09:22.493[/B]
BugCheck [B]A, {1c4, 2, 0, fffff80002eea6d9}[/B]
Arguments:
Arg4: fffff80002eea6d9, address which referenced memory
BUGCHECK_STR: 0xA
BIOS Version V3.11
**************************Mon Jan 14 01:39:30.508 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011413-29343-01.dmp]
System Uptime:[B]0 days 0:58:10.803[/B]
Probably caused by :[B]hardware ( win32k!HmgLockEx+122 )[/B]
BugCheck [B]50, {fffffa81025a36d1, 1, fffff80002eddc6d, 5}[/B]
Arguments:
Arg1: fffffa81025a36d1, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff80002eddc6d, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000005, (reserved)
BUGCHECK_STR: 0x50
PROCESS_NAME: [B]Steam.exe[/B]
BIOS Version V3.11
**************************Mon Jan 14 00:40:46.920 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011313-49218-01.dmp]
System Uptime:[B]0 days 0:06:15.200[/B]
Probably caused by :[B]Ntfs.sys ( Ntfs! ?? ::NNGAKEGL::`string'+2bf0 )[/B]
BugCheck [B]D1, {fffff8800133b0c0, 0, 8, fffff8800133b0c0}[/B]
Arguments:
Arg1: fffff8800133b0c0, memory referenced
Arg2: 0000000000000000, IRQL
Arg4: fffff8800133b0c0, address which referenced memory
BUGCHECK_STR: 0xD1
PROCESS_NAME: [B]uTorrent.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xD1_CODE_AV_BAD_IP_Ntfs!_??_::NNGAKEGL::_string_+2bf0[/B]
BIOS Version V3.11
**************************Sun Jan 13 22:54:19.758 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011313-39031-01.dmp]
System Uptime:[B]0 days 0:09:07.022[/B]
Probably caused by :[B]AuthenticAMD[/B]
BugCheck [B]124, {0, fffffa800946f028, b6004000, 5d000135}[/B]
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800946f028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b6004000, High order 32-bits of the MCi_STATUS value.
Arg4: 000000005d000135, Low order 32-bits of the MCi_STATUS value.
BUGCHECK_STR: 0x124_AuthenticAMD
FAILURE_BUCKET_ID: [B]X64_0x124_AuthenticAMD_PROCESSOR_CACHE[/B]
BIOS Version V3.11
**************************Sun Jan 13 22:44:36.334 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\011313-40934-01.dmp]
System Uptime:[B]0 days 7:14:53.599[/B]
Probably caused by :[B]hardware ( nt!MiInitializePfn+b7 )[/B]
BugCheck [B]50, {fffffa8051aeb6a1, 0, fffff80002eda507, 5}[/B]
Arguments:
Arg1: fffffa8051aeb6a1, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80002eda507, If non-zero, the instruction address which referenced the bad memory
address.
BUGCHECK_STR: 0x50
BIOS Version V3.11
[/FONT]
