Driver_power_state_failure
This has been an issue for a few days now. It seems to only happen when my PC comes out of hibernation. It does not do it when I'm actually using the PC, only at random during PC hibernation. I will post my most recent Minidump file.
I have an HP e9150t with 6GB RAM, Windows 7 64-bit, Nvidia GeForce GT 220, and an Intel i7 920 CPU.
Thank you very much. Will be sure to post if it's fixed or not as soon as possible.
zigzag3143
Honorable Member
Microsoft MVP
TG is correct
While you are updating that driver you may as well update all of those that were released before july 13, 2009 the release of win 7.
They are:
skfiltv.sys        fffff880`06510000    fffff880`0651d000    0x0000d000    0x48a3d541    8/14/2008 02:48:33
spldr.sys        fffff880`01aab000    fffff880`01ab3000    0x00008000    0x4a0858bb    5/11/2009 12:56:27
GEARAspiWDM.sys        fffff880`04ed1000    fffff880`04ede000    0x0000d000    0x4a1151c0    5/18/2009 08:17:04
amdxata.sys        fffff880`011a1000    fffff880`011ac000    0x0000b000    0x4a12f2eb    5/19/2009 13:56:59
[COLOR=red][B]dump_iaStor.sys        fffff880`02ec0000    fffff880`02fdc000    0x0011c000    0x4a287aa4    6/4/2009 21:53:40
iaStor.sys        fffff880`01038000    fffff880`01154000    0x0011c000    0x4a287aa4    6/4/2009 21:53:40       [/B][/COLOR]
e1y62x64.sys        fffff880`04e6a000    fffff880`04eb3000    0x00049000    0x4a32fdfa    6/12/2009 21:16:42
LHidFilt.Sys        fffff880`04bec000    fffff880`04bff000    0x00013000    0x4a391ea3    6/17/2009 12:49:39
LMouFilt.Sys        fffff880`046c8000    fffff880`046dc000    0x00014000    0x4a391ea7    6/17/2009 12:49:43
LUsbFilt.Sys        fffff880`04a6a000    fffff880`04a7a000    0x00010000    0x4a391eaa    6/17/2009 12:49:46
How To Find Drivers:
- search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- - The most common drivers are listed on this page: Driver Reference
- - Driver manufacturer links are on this page: Drivers and Downloads
How's it going there?
8064d1284749867-driver_power_state_failure-091710-41090-01.dmp
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state
FAILURE_BUCKET_ID: X64_0x9F_IMAGE_e1y62x64.sys
Probably caused by : e1y62x64.sys
Update:
e1y62x64.sys Sat Jun 13 04:16:42 2009
Intel(R) Gigabit Network Connection NDIS 6 deserialized driver
http://downloadcenter.intel.com/default.aspx?iid=gg_support-EN_01+home_downloadctr
Update also:
skfiltv.sys Thu Aug 14 09:48:33 2008
Creative wireless headset
Creative Worldwide Support
RTKVHD64.sys Tue Aug 04 12:50:52 2009
Realtek(r) High Definition Audio
Realtek
LHidFilt.Sys Wed Jun 17 19:49:39 2009
Logitech SetPoint(TM)
Logitech
jraid.sys Fri Jul 17 18:31:50 2009
JMicron JMB36X RAID Driver
Driver
iaStor.sys Fri Jun 05 04:53:40 2009
Intel Matrix Storage Manager
If more BSOD's, you may want to uninstall Symantec and replace it with Microsoft Security Essentials. Attach your latest crash dumps.
SYMEVENT64x86.SYS Fri Aug 14 01:28:21 2009
SYMDS64.SYS Tue Aug 18 02:35:30 2009
Sorry it has taken so long to reply. I believe the problem has been fixed, thanks a ton guys :)
