- Thread Author
- #1
For those of you who try to use the DVD drive and get this annoying message:
Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52), try this.
1. Press Windows R, type regedit and press enter.
2. Open the Registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Note After you remove the UpperFilters registry entry and the LowerFilters registry entry, you may lose functionality in certain programs such as CD recording programs. In this scenario, you must reinstall any affected programs. If the problem recurs, contact the program vendor to determine whether an update is available for the program.
It worked fine for me.2. Open the Registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
