Windows 7 Eclipse with Aptana plugin lagg and freeze
L
Lightning
Guest
I have Windows 7 build 7100 x64. I also have installed Java 6.13.
Eclipse is a Java based platform so I guess the Java platform causes the problem:
If I use the clipboard or I type too fast, the whole Eclipse starts lagg and if I click on something, it freezes permanently.
Yes, this is a 64 bit OS but Eclipse works fine on Vista x64, so I don't think this is the reason.
Other Java based applications works fine such as Woopra or Java applet in browsers.
I tried the XP SP3 compatibility mode but it didn't help.
I have Intel Core 2 E8400 which supports hardware virtualization, 8GB DDR2 RAM and ATI 4850 Toxic VGA.
The OS is on a Transcend 64GB MLC SSD but Eclipse and few stuffs is on a SATAII HDD. So hardwares can't be the reason neither.
Windows 7 is much greater than Vista but I'm disappointed because of Eclipse. :(
Thanks a lot,
Lightning
fawwaz
win 7 ultimate v6.1 build 7127, win 7 32bit,
Aptana is working more than perfectly -> just one small complaint while installing plugins but nothing to worry about -> i installed PyDEV, PHP, Adobe AIR, IPONE DEV Tools -> everything is working pefect!!
i haven't made any changes to system, UAC is at the low level but haven't turned it off - just confirm install as normal, nothing to fix afterwards - just start and run Aptana as normal, choose working dir etc....
i'm now happy user of win 7 and aptana studio :)
L
Lightning
Guest
I found the reason by now. This whole bug or whatever is because I edit files on a network drive.
So on a local drive everything works fine, but on a network drive...
How can I fix this?
Off:
I also can't include network folders to the Libraries such as Documents, except if I syncronize them,
what I really don't want to do with hundreds of Gigabytes.
Win7 hates home serves. :D
fawwaz
Should be very simple: Computer -> File -> Add a network location -> Next -> Choose a custom network location -> .....
So you can make FTP, Network Share etc. work with your Aptana.
Does this help?
Also read: http://windows7forums.com/windows-7-discussion/4868-cant-add-network-drive-library.html
Quote "You can use symbolic link to add a network folder." post by Okaryn
Also read and watch tutorial: Using Windows 7 Libraries with Network Drives
Link: Link Removed - Invalid URL
