Elevating MCQs: Evidence-Based Item Writing and Review for Reliable Assessments
University of Nebraska–Lincoln faculty and instructional designers who’ve wrestled with large question banks know the problem: multiple‑choice questions (MCQs) are fast to grade and easy to deliver, but they’re also painfully easy to get wrong. Poorly written items measure reading skill, test‑taking savvy, or luck—not the learning outcomes you intended. This feature synthesizes evidence‑based item‑writing guidance and operational workflows you can use today to write, review, and maintain high‑quality multiple‑choice assessments that measure understanding, not trivia.
Teacher writes a multiple-choice question on the whiteboard about the capital of France.Background / Overview​
Multiple‑choice questions remain ubiquitous because they scale: they’re efficient to administer in learning management systems, straightforward to score automatically, and—when designed well—capable of assessing higher‑order thinking. But quality matters. Low‑quality MCQs produce misleading scores, create fairness and validity problems, and erode student trust.
Universities and centers for teaching—TeacherConnect at the University of Nebraska–Lincoln among them—have been advising faculty to pair careful item design with regular item analysis and review cycles. Those recommendations align with long‑standing best practices developed in assessment literature and printed by leading teaching centers. This article brings those best practices together into a practical, step‑by‑step playbook for instructors and course teams who want more reliable, defensible MCQ assessments.
Why MCQ quality matters​
Bad items distort what you measure.
  • Validity risk: Items with ambiguous stems or implausible distractors fail to measure the targeted learning outcome.
  • Reliability loss: Flawed items produce noisy scores that reduce the test’s consistency.
  • Equity harms: Items that rely on niche knowledge, idioms, or culturally‑specific contexts disadvantage some groups.
  • Poor learning feedback: If distractors aren’t designed to reflect common misconceptions, students get little actionable feedback.
Improving MCQ quality isn’t mere polish; it’s assessment stewardship. Well‑constructed items yield clearer data about student learning and reduce the time instructors spend diagnosing confusion.
Principles that should guide every MCQ​
1. Start with learning outcomes, not facts​
Write each item to assess a single, measurable learning objective. If your outcome is "apply the law of conservation of energy to mechanical systems," the question should require that application—not a regurgitation of formula names.
2. Use a clear, focused stem​
The stem must present a single problem or task. Keep it short, remove irrelevant material, and ensure the stem contains all information needed to answer. Avoid partial sentences completed by options (the “fill‑in” stem) unless every option grammatically completes the stem.
3. Design plausible distractors​
Distractors (incorrect options) should be believable and diagnostic—that is, they should represent common mistakes, misconceptions, or plausible but incorrect reasoning. Implausible distractors are noise.
4. Make the correct option indisputably best​
Students should be able to choose the correct option based on course knowledge and reasoning. Avoid "trick" questions that rely on ambiguous phrasing or hidden caveats.
5. Keep options parallel and similar in length​
Options should be grammatically and syntactically parallel, similar in content scope, and roughly similar in length to avoid cueing.
6. Avoid item‑writing traps​
  • Don’t use "All of the above" or "None of the above" routinely; they can change item difficulty in unpredictable ways.
  • Avoid negative stems (e.g., "Which of the following is NOT…") unless necessary; if used, bold the negative term and keep the sentence short.
  • Avoid absolute terms in options (always, never) unless context supports them.
  • Avoid overlapping options that can both be technically true.
7. Aim for higher‑order thinking when appropriate​
MCQs can assess analysis, application, and evaluation by using scenarios, multi‑step problems, or data interpretation rather than only recall.
Practical checklist for writing a single high‑quality MCQ​
  • 1.) Identify the specific learning objective the item measures.
  • 2.) Draft a concise stem that contains the task and any necessary context.
  • 3.) Craft one correct answer that is clearly the best choice.
  • 4.) Create three to five distractors that are plausible and reflect real errors.
  • 5.) Ensure all options are parallel in grammar and length.
  • 6.) Remove irrelevant information from the stem.
  • 7.) Run a quick bias‑check: does the stem require cultural knowledge, obscure phrasing, or unnecessary reading complexity?
  • 8.) Pilot the item with a colleague or a small student sample if possible.
  • 9.) Add rationales (for instructor guidance and automated feedback) explaining why each distractor is incorrect.
  • 10.) Tag the item with the learning outcome, Bloom’s level, and any prerequisite knowledge.
From theory to practice: improving an existing item bank​
If you inherit or maintain a question bank, use this stepwise workflow to raise item quality systematically.
Step 1 — Audit and tag​
  • Export your bank and tag each item with: learning outcome, Bloom’s level (remember, understand, apply, analyze, evaluate, create), author, date, and use history.
  • Flag items missing tags or with inconsistent formatting for immediate review.
Step 2 — Remove or retire broken items​
  • Items with ambiguous keys, duplicate content, or obviously implausible distractors should be retired or rewritten before reuse.
Step 3 — Prioritize high‑impact items​
  • Focus on frequently used items in summative assessments first—flaws there have the largest effect on student grades.
Step 4 — Local peer review​
  • Implement a simple peer review: two independent reviewers read every item and rate stem clarity, key correctness, and distractor plausibility. Use a short rubric (0 = fail, 1 = acceptable, 2 = strong).
Step 5 — Pilot and collect data​
  • Run items in formative quizzes or low‑stakes practice to collect response patterns. Use the results for item analysis.
Step 6 — Item analysis and curation​
  • Compute basic classical metrics: difficulty index (proportion of students answering correctly) and discrimination index (how well item separates high‑ and low‑performers).
  • Remove or revise items with very low discrimination or odd difficulty levels that don’t fit the test blueprint.
Step 7 — Maintain governance​
  • Establish a versioning and review cadence (e.g., items reviewed every 18 months or after 3 course runs).
  • Keep an item history log for transparency in accreditation or appeals.
How to do item analysis (simple, practical)​
Item analysis converts student response data into actionable decisions.
  • Difficulty (P‑value): proportion correct. Desired range depends on purpose; for mixed assessments aim for a distribution across difficulty. Items that almost everyone or almost no one gets correct provide little discrimination.
  • Discrimination: often computed as point‑biserial correlation or the difference in proportion correct between top and bottom performance groups. High discrimination indicates the item is aligned to overall test performance.
  • Distractor analysis: check how often each distractor is selected. Useful distractors attract some students; distractors never selected should be rewritten or removed.
Most learning management systems (Canvas, Blackboard, Moodle) provide basic item analysis reports. Export these periodically and act on items that show low discrimination or implausible distractor patterns.
Writing MCQs that assess higher‑order thinking​
MCQs don’t have to be shallow. Use the following techniques to target analysis and application.
  • Use short case vignettes that require applying concepts to a novel situation.
  • Embed data (a small table or graph) and ask students to interpret patterns or make a prediction.
  • Break complex problems into a set of linked multiple‑choice parts (scaffolded items).
  • Prefer “best answer” stems that require choosing the most defensible response when multiple options might be partially correct.
  • Use multiple‑response (select all that apply) or multiple drop‑downs when you want to assess multi‑facet reasoning—note these item types require careful scoring and more cognitive load.
Using technology and AI—promise and pitfalls​
Modern tools simplify item creation but require caution.
  • Automated item generators and AI (large language models) can draft stems, generate distractors, and expand item banks quickly. They are useful for idea generation and scaling.
  • Always review AI‑generated items for factual accuracy, alignment to outcomes, and fairness. AI tends to create implausible distractors or hallucinate content that sounds authoritative but is incorrect.
  • Use AI to create plausible distractor templates (e.g., common misconceptions) and then humanize them. Do not publish AI answers without human verification.
  • For large banks, consider automated item‑quality checks (rule‑based heuristics that flag negative stems, non‑parallel options, keywords in options that cue the answer) before human review.
Accessibility, fairness, and accommodations​
Good item design improves accessibility for all students.
  • Keep reading complexity appropriate for the level of the course; do not test reading comprehension unless that’s the objective.
  • Avoid culturally specific references, slang, or idioms that may disadvantage international students.
  • Ensure visual materials (figures, graphs) are clearly labeled and include alt text or textual descriptions for students using screen readers.
  • For timed, high‑stakes tests, ensure accommodations (extended time, alternate formats) are available and that items don’t rely on transient sensory cues.
Quality control governance for departments​
Creating good items at scale demands institutional processes, not heroic instructor toil.
  • Establish a course assessment blueprint linking outcomes to item counts and acceptable cognitive levels.
  • Use collaborative item writing: pair a subject‑expert with a pedagogy reviewer. The content expert ensures accuracy; the pedagogy reviewer checks clarity and alignment.
  • Maintain an item repository with metadata: learning outcome, Bloom’s level, last reviewed date, discrimination index, and author.
  • Set a review cycle (e.g., all items reviewed after 3 uses or every 24 months).
  • Train graduate teaching assistants and adjunct staff in item writing standards and rubric use.
Example: rewrite a weak item (before → after)​
Weak item
  • Stem: "Which gas law is used in calculating the pressure of an ideal gas?"
  • Options: A. Boyle’s law B. Charles’s law C. Ideal gas law D. Avogadro’s law
Problems: ambiguous stem; distractors include an obviously correct "Ideal gas law" but the stem is too simple (recall), distractors aren’t diagnostic.
Improved item (application)
  • Stem: "A sealed container of helium is heated from 300 K to 600 K while volume remains constant. Which law most directly explains the observed change in pressure?"
  • Options:
  • A. Boyle’s law — pressure varies inversely with volume.
  • B. Charles’s law — volume varies directly with temperature at constant pressure.
  • C. The ideal gas law — pressure, volume, and temperature are related by PV = nRT.
  • D. Avogadro’s law — volume varies with the number of moles at constant temperature and pressure.
Why this is better: the stem gives a scenario requiring application, options are parallel, and distractors reflect plausible but distinct reasoning errors.
Metrics every instructor should monitor​
  • Item difficulty (P‑value) across administrations
  • Item discrimination (point‑biserial or D)
  • Distractor functionality (percentage selecting each distractor)
  • Test reliability (Cronbach’s alpha or omega)
  • Alignment rate: proportion of items mapped to a specific learning outcome
Regularly review items that fall outside acceptable thresholds and revise or retire them.
Common pitfalls and how to avoid them​
  • Pitfall: Writing items that test obscure trivia.
  • Fix: Map every item to a documented learning outcome and ask whether the item’s knowledge is essential.
  • Pitfall: Distractors that are implausible.
  • Fix: Use common student errors as a source for distractors; examine homework and formative responses for patterns.
  • Pitfall: Overuse of negative wording.
  • Fix: Rephrase to positive stems when possible; if negative wording is required, emphasize the negative word.
  • Pitfall: Heavy reliance on MCQs for all learning outcomes.
  • Fix: Mix item types—use short answer, essays, projects—when assessing complex synthesis and communication skills.
A short policy template departments can adopt​
  • All summative MCQ items must be mapped to a learning outcome and peer‑reviewed before use.
  • Items may not contain culturally specific references unless the reference is central to the learning objective.
  • Items with discrimination below department threshold will be reviewed and either revised or removed.
  • AI‑generated items are allowed only after human verification for accuracy, fairness, and alignment.
Final recommendations — a compact action plan you can implement this week​
  • Run an audit: export your course bank and tag items with outcomes and Bloom’s level.
  • Pick your top 20 most frequently used items and apply the checklist in this article.
  • Use your LMS item analysis after the next formative quiz; flag items with low discrimination for revision.
  • Create a one‑page item‑writing rubric and share it with instructors and TAs.
  • Pilot AI assistance for draft generation, but require a manual verification step.
  • Schedule quarterly item review meetings in your department to share problem items and solutions.
Multiple‑choice questions will remain a central tool in higher education assessment, but they’ll only be useful if they’re built and managed with care. The work is both creative and technical: craft stems that target real learning objectives, build diagnostic distractors that reveal student thinking, and use data from item analysis to iterate. Pair thoughtful item design with governance—peer review, tagging, and periodic quality checks—and your MCQ bank will stop being a liability and start being a powerful source of insight into student learning. Implement the steps above, and you’ll both improve assessment quality and free up time to focus on what matters most: teaching and learning.
Source: University of Nebraska–Lincoln Web Login Service
