Windows 7 Enable Direct2D and Hardware Acceleration in Mozilla Firefox
A little background for those who wondering what is Direct2D and DirectWrite Hardware Acceleration
Direct2D :
Direct2Dis a hardware-accelerated, immediate-mode, 2-D graphics API that provides high performance and high-quality rendering for 2-D geometry, bitmaps, and text. The Direct2D API is designed to interoperate well with GDI, GDI+, and Direct3D.
DirectWrite Hardware Acceleration:
Today's applications must support high-quality text rendering, resolution-independent outline fonts, and full Unicode text and layout support. DirectWrite, a new DirectX API, provides these features and more:
  • A device-independent text layout system that improves text readability in documents and in UI.
  • High-quality, sub-pixel, ClearType text rendering that can use GDI, Direct2D, or application-specific rendering technology.
  • Hardware-accelerated text, when used with Direct2D.
  • Support for multi-format text.
  • Support for the advanced typography features of OpenType fonts.
  • Support for the layout and rendering of text in all supported languages.
  • GDI-compatible layout and rendering.
Note:
  1. This will only work with Firefox 4 Beta and later
  2. Some Add-ons may interfere with proper operation when they call a certain API prematurely. I had problems with ABP add-ons managed to find a link for developers build https://adblockplus.org/devbuilds/adblockplus/
  3. Your Video Drivers should be updated to the latest version.
Here is how:
1. If you're not using Firefox 4 Beta download it from here. Firefox 4 Beta
2. On the Address bar type in about:config then click on "I'll be careful. I promise!"
Link Removed - Invalid URL
3. Under Filter type in "gfx.font_rendering.directwrite.enabled" without Quotes and double click on it to change the value from False to True
4. Then under Filter type in "mozilla.widget.render-mode" without Quotes and double click on it change the value from -1 to 6
5. Now restart your browser to take effect
Hope this helps,
Captain
Top Bottom
