amaury_1005
Hi
I'm trying to install W7 on my laptop but I have a problem.
I had vista on it, I started the installation going on the iso and clicking on Setup.
All went fine, I selected an empty partition of 40go.
It installs and at the final step : Completing installation, nothing happens. It stays on this step.
I tryed booting it from an USB disk, same happened.
I formated the main partition trying to install 7 on it, same.
Computed spec :
It's a laptop, Intel Centrino 1.4Ghz, 2go ram, 128 mo geforce
I wondered if I needed to install vista in English and then make an update ?
Thanks for help
Computed spec :
Thanks for help
