Windows 7 Error 0x0000007E y problemas con "usb video device" driver]
dan
Hi!
I have a problem with my netbook (a mini hp 5101). when i turn it on, appears a blu screen with the code
STOP: 0x0000007E​
plus four parameters.
There are a few suggestions in the same screen, wich are update the BIOS and check the drivers. I've updated the BIOS (from the HP site) and nothing happened.
The computer works in safe mode and also when i select (in the F8 menu) Last configuration that worked. It seems that the problem is a driver (USB video device).
Loaded driver \SystemRoot\system32\DRIVERS\kbdhid.sys
Did not load driver @usbvideo.inf,%usbvideo.devicedesc%;USB Video Device
Did not load driver @battery.inf,%acpi\pnp0c0a.devicedesc%;Microsoft ACPI-Compliant Control Method Battery
Did not load driver @battery.inf,%acpi\acpi0003.devicedesc%;Microsoft AC Adapter
Did not load driver @battery.inf,%*compbatt.devicedesc%;Microsoft Composite Battery
Did not load driver @cpu.inf,%intelppm.devicedesc%;Intel Processor
Did not load driver @oem2.inf,%iclge0%;Mobile Intel(R) 945 Express Chipset Family
Did not load driver @igdlh.inf,%iclgd1%;Mobile Intel(R) 945 Express Chipset Family (Microsoft Corporation - WDDM 1.0)
Did not load driver @oem1.inf,%hdaudiofunctiondriver.adicodec.devicedesc%;SoundMAX Integrated Digital HD Audio
Loaded driver \SystemRoot\system32\drivers\WudfPf.sys
Loaded driver \SystemRoot\system32\DRIVERS\bowser.sys
Loaded driver \SystemRoot\System32\drivers\mpsdrv.sys
Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb.sys
Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb10.sys
Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb20.sys
Loaded driver \SystemRoot\system32\DRIVERS\USBSTOR.SYS
Loaded driver \SystemRoot\System32\Drivers\fastfat.SYS
i have a HP mini 5101,
Intel Atom N280 1.66Ghz
1Gb RAM
Windows 7 professional 32bits
i've installed the most recent driver for my webcam, but the blue screen keeps appearing.
What should i do?
Help! [-O<
Hello, welcome.
C:\Windows\Minidump
Copy files in there to any other folder, then zip the files. Attach the zip to a post here. We will see for ya.
Top Bottom
