Error code 80040154 when checking for updates!
Discussion in 'Windows 7 Help and Support' started by Cratecruncher, Nov 14, 2010.
  1. Cratecruncher
    Cratecruncher New Member
    Nov 14, 2010
    4
    0
    I recently built a new desktop and installed a fresh OS on a clean hard drive. Things seemed to be going fine but now it seems I'm having some problems.
    When I try and update Windows 7 manually I get an error code 80040154 and a note saying the system was unable to check for updates. When it was first installed I was able to update the OS with no problems. Any idea where I should start?
    Windows 7 (64bit 6.1)
    AMD X6 1055T 2.8
    MSI 890GXM-G65
    4 GB DDR3
    Radeon 5770
    Diamond Extreme Sound 5.1
  2. zvit
    zvit Honorable Member
    Nov 3, 2009
    2,455
    84
  3. Cratecruncher
    Nov 14, 2010
    4
    0
    Thank you for the link Zvit! This was my first post here. I was beginning to think no one would answer. I'll try the suggestions mentioned and follow up here.
Share This Page
Loading...
