Windows 7 Event Viewer errors and warnings
dkperez
Is there a place in these forums that'd be best for asking/talking about some of the entries that are showing up in the event viewer? I"m not sure some are specific to Windows 7, but I think several are related to something I probably need to set up/change, or whatever..... SO, here? Support? Elsewhere?
You will probably get replies here, but Windows 7 support would be the better option. Don't worry about the references to third party software, the query is essentially Windows 7.
I have several solution for the problems I fixed that were listed in the event viewer, as well as a batch file that would clear all logs. .... in my blogs
Top Bottom
