Windows 7 Everyday i see BSOD! Help!
djneo
I have a WD My book Essential, after blue sreen i dont see this HDD. Please help me. Im dont speak English well, sorry :( There are my files. Thx.
  • dmp.files.rar
1. Update:
WD External Storage
wdcsam64.sys Wed Apr 16 04:39:08 2008
Motherboard driver for NEC USB 3.0
nusb3xhc.sys Fri Nov 20 05:16:01 2009
nusb3hub.sys Fri Nov 20 05:15:57 2009
USB 2.0 PC Camera
SNCAMD.SYS Thu Jan 25 05:48:38 2007
snp2sxp.sys Thu May 10 04:11:58 2007
2. Should blue screens reoccur after you update the above drivers, uninstall Daemon Tools
sptd.sys Tue Nov 23 06:47:37 2010
DuplexSecure - FAQ
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\031711-27612-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`03015000 PsLoadedModuleList = 0xfffff800`0325ae90
Debug session time: Thu Mar 17 08:17:57.815 2011 (UTC - 4:00)
System Uptime: 0 days 1:24:52.970
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1E, {ffffffffc0000047, fffff800030c3000, fffff880031fb640, fffff880031d3180}
Unable to load image \SystemRoot\system32\drivers\danew.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for danew.sys
*** ERROR: Module load completed but symbols could not be loaded for danew.sys
Unable to load image \SystemRoot\System32\Drivers\sptd.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for sptd.sys
*** ERROR: Module load completed but symbols could not be loaded for sptd.sys
Probably caused by : danew.sys ( danew+6da )
Followup: MachineOwner
3: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000047, The exception code that was not handled
Arg2: fffff800030c3000, The address that the exception occurred at
Arg3: fffff880031fb640, Parameter 0 of the exception
Arg4: fffff880031d3180, Parameter 1 of the exception
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000047 - An attempt was made to release a semaphore such that its maximum count would have been exceeded.
FAULTING_IP:
nt!RtlRaiseStatus+18
fffff800`030c3000 488b8424b8010000 mov     rax,qword ptr [rsp+1B8h]
EXCEPTION_PARAMETER1:  fffff880031fb640
EXCEPTION_PARAMETER2:  fffff880031d3180
ERROR_CODE: (NTSTATUS) 0xc0000047 - An attempt was made to release a semaphore such that its maximum count would have been exceeded.
BUGCHECK_STR:  0x1E_c0000047
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff800030e1028 to fffff80003095640
STACK_TEXT:
fffff880`031fa8a8 fffff800`030e1028 : 00000000`0000001e ffffffff`c0000047 fffff800`030c3000 fffff880`031fb640 : nt!KeBugCheckEx
fffff880`031fa8b0 fffff800`030e317c : fffff880`031fb380 fffff880`031fb380 fffff880`031fb1c0 fffff880`031fb420 : nt! ?? ::FNODOBFM::`string'+0x4987d
fffff880`031faf50 fffff800`030973fb : fffff880`031fb380 fffff880`031ddfc0 fffffa80`06599730 fffff880`04c33469 : nt!KiRaiseException+0x1b4
fffff880`031fb080 fffff800`030948d3 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff880`045003f1 : nt!NtRaiseException+0x7b
fffff880`031fb1c0 fffff800`030c3000 : fffff880`031fb380 fffff880`031fb420 00000000`00000001 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
fffff880`031fb360 fffff800`0304ffca : fffffa80`054e3000 00000000`00000000 00000000`00000000 fffff800`036026e5 : nt!RtlRaiseStatus+0x18
fffff880`031fb900 fffff880`070a46da : fffffa80`0747efb0 fffff800`00000000 00000000`00000008 fffff800`03601300 : nt! ?? ::FNODOBFM::`string'+0xf5a9
fffff880`031fb980 fffffa80`0747efb0 : fffff800`00000000 00000000`00000008 fffff800`03601300 00000000`00000008 : danew+0x6da
fffff880`031fb988 fffff800`00000000 : 00000000`00000008 fffff800`03601300 00000000`00000008 fffff800`0360169a : 0xfffffa80`0747efb0
fffff880`031fb990 00000000`00000008 : fffff800`03601300 00000000`00000008 fffff800`0360169a fffffa80`0659a4a0 : 0xfffff800`00000000
fffff880`031fb998 fffff800`03601300 : 00000000`00000008 fffff800`0360169a fffffa80`0659a4a0 fffff800`03098a91 : 0x8
fffff880`031fb9a0 fffffa80`0747efc0 : fffffa80`0747ef02 fffff880`045c7696 00000000`54627255 00000000`000000e0 : hal!HalpDmaAllocateMapRegisters+0x3b8
fffff880`031fba30 fffffa80`0747ef02 : fffff880`045c7696 00000000`54627255 00000000`000000e0 fffffa80`70627375 : 0xfffffa80`0747efc0
fffff880`031fba38 fffff880`045c7696 : 00000000`54627255 00000000`000000e0 fffffa80`70627375 00000000`00000000 : 0xfffffa80`0747ef02
fffff880`031fba40 fffff880`045b2631 : fffffa80`04ff8050 fffffa80`07654800 00000000`00000000 00000000`00000000 : USBPORT!USBPORT_DereferenceDeviceHandle+0x14e
fffff880`031fbaa0 fffff880`045b2b0f : fffffa80`03e46c02 fffffa80`0659a4a0 00000000`ffffffff fffffa80`04ff8eb0 : USBPORT!USBPORT_Core_iCompleteDoneTransfer+0xa15
fffff880`031fbb80 fffff880`045b066f : fffffa80`04ff8eb0 fffffa80`04ff81a0 fffffa80`04ff9050 00000000`00000000 : USBPORT!USBPORT_Core_iIrpCsqCompleteDoneTransfer+0x3a7
fffff880`031fbbe0 fffff880`045a1f89 : fffffa80`04ff8050 00000000`00000000 fffffa80`04ff8e02 fffffa80`04ff8eb0 : USBPORT!USBPORT_Core_UsbIocDpc_Worker+0xf3
fffff880`031fbc20 fffff880`00e6c0cc : fffffa80`04f4c000 fffffa80`04ff8ec8 fffffa80`04ff8e00 fffff880`031fbcc8 : USBPORT!USBPORT_Xdpc_Worker+0x1d9
fffff880`031fbc50 fffffa80`04f4c000 : fffffa80`04ff8ec8 fffffa80`04ff8e00 fffff880`031fbcc8 00000000`00000010 : sptd+0x460cc
fffff880`031fbc58 fffffa80`04ff8ec8 : fffffa80`04ff8e00 fffff880`031fbcc8 00000000`00000010 00000000`00000246 : 0xfffffa80`04f4c000
fffff880`031fbc60 fffffa80`04ff8e00 : fffff880`031fbcc8 00000000`00000010 00000000`00000246 fffff880`031fbc98 : 0xfffffa80`04ff8ec8
fffff880`031fbc68 fffff880`031fbcc8 : 00000000`00000010 00000000`00000246 fffff880`031fbc98 00000000`00000018 : 0xfffffa80`04ff8e00
fffff880`031fbc70 00000000`00000010 : 00000000`00000246 fffff880`031fbc98 00000000`00000018 00000000`00000000 : 0xfffff880`031fbcc8
fffff880`031fbc78 00000000`00000246 : fffff880`031fbc98 00000000`00000018 00000000`00000000 fffffa80`04f4d24d : 0x10
fffff880`031fbc80 fffff880`031fbc98 : 00000000`00000018 00000000`00000000 fffffa80`04f4d24d fffff880`031d3180 : 0x246
fffff880`031fbc88 00000000`00000018 : 00000000`00000000 fffffa80`04f4d24d fffff880`031d3180 fffffa80`04ff8eb0 : 0xfffff880`031fbc98
fffff880`031fbc90 00000000`00000000 : fffffa80`04f4d24d fffff880`031d3180 fffffa80`04ff8eb0 fffffa80`04ff8ec8 : 0x18
STACK_COMMAND:  kb
FOLLOWUP_IP:
danew+6da
fffff880`070a46da ??              ???
SYMBOL_STACK_INDEX:  7
SYMBOL_NAME:  danew+6da
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: danew
IMAGE_NAME:  danew.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ba87dcd
FAILURE_BUCKET_ID:  X64_0x1E_c0000047_danew+6da
Loading Dump File [F:\a\Minidump\D M P\DMP\031811-21886-01.dmp]
Machine Name:
Kernel base = 0xfffff800`03003000 PsLoadedModuleList = 0xfffff800`03248e90
Debug session time: Fri Mar 18 03:19:55.960 2011 (UTC - 4:00)
System Uptime: 0 days 15:55:09.489
BugCheck 3B, {c0000005, fffff8000309fc0c, fffff8800aff2c80, 0}
Probably caused by : ntkrnlmp.exe ( nt!ObReferenceObjectSafe+c )
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff8000309fc0c, Address of the instruction which caused the bugcheck
Arg3: fffff8800aff2c80, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`0309fc0c 498b02          mov     rax,qword ptr [r10]
CONTEXT:  fffff8800aff2c80 -- (.cxr 0xfffff8800aff2c80)
rax=0000000000000000 rbx=fffbfa8004fc2a98 rcx=fffbfa8004fc2910
rdx=fffffa80076cddd1 rsi=fffffa80073bf780 rdi=fffffa8006a14b30
rip=fffff8000309fc0c rsp=fffff8800aff3660 rbp=0000000000000000
 r8=fffffa80076cddd0  r9=0000000000000016 r10=fffbfa8004fc28e0
r11=fffffa80063300d0 r12=fffbfa8004fc2910 r13=0000000000000000
r14=0000000000000001 r15=fffff8000322ab90
iopl=0         nv up ei ng nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010286
nt!ObReferenceObjectSafe+0xc:
fffff800`0309fc0c 498b02          mov     rax,qword ptr [r10] ds:002b:fffbfa80`04fc28e0=????????????????
Resetting default scope
BUGCHECK_STR:  0x3B
PROCESS_NAME:  FixCamera.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff8000309fc0c
STACK_TEXT:
fffff880`0aff3660 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ObReferenceObjectSafe+0xc
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!ObReferenceObjectSafe+c
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7951a
STACK_COMMAND:  .cxr 0xfffff8800aff2c80 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!ObReferenceObjectSafe+c
Drivers:
fffff880`04400000 fffff880`0443e000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`01094000 fffff880`010eb000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`04077000 fffff880`040bf000   adsyca6p adsyca6p.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
fffff880`0140d000 fffff880`01496000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`040bf000 fffff880`040d5000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`045c6000 fffff880`045db000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0104d000 fffff880`01058000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`04598000 fffff880`045a0000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`04571000 fffff880`04598000   archlp   archlp.sys   Tue Jan 12 03:07:45 2010 (4B4C2DD1)
fffff880`0101a000 fffff880`01023000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01023000 fffff880`0104d000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff960`008f0000 fffff960`00951000   ATMFD    ATMFD.DLL    Fri Jan 07 04:20:44 2011 (4D26DAEC)
fffff880`0184f000 fffff880`01856000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04560000 fffff880`04571000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`07b1e000 fffff880`07b3c000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00690000 fffff960`006b7000   cdd      cdd.dll      Sat Nov 20 07:55:34 2010 (4CE7C546)
fffff880`0a631000 fffff880`0a64e000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`0181c000 fffff880`01846000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`01bb5000 fffff880`01be5000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00ce3000 fffff880`00d41000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01521000 fffff880`01593000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`045e4000 fffff880`045f4000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`0a7d7000 fffff880`0a7e5000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`044bf000 fffff880`04542000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`08200000 fffff880`08202f00   danew    danew.sys    Tue Mar 23 04:37:33 2010 (4BA87DCD)
fffff880`04542000 fffff880`04560000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`04068000 fffff880`04077000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01b9f000 fffff880`01bb5000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05dd2000 fffff880`05df4000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`0a7f1000 fffff880`0a7fa000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0a7e5000 fffff880`0a7f1000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0a600000 fffff880`0a613000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`07717000 fffff880`07723000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`046bb000 fffff880`047af000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`047af000 fffff880`047f5000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`06e7f000 fffff880`06f57000   eamonm   eamonm.sys   Fri Aug 13 08:38:55 2010 (4C653CDF)
fffff880`0162b000 fffff880`01650000   ehdrv    ehdrv.sys    Wed Jul 14 04:14:21 2010 (4C3D71DD)
fffff880`06f78000 fffff880`06fa5000   epfw     epfw.sys     Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`047f5000 fffff880`04800000   Epfwndis Epfwndis.sys Wed Jul 14 04:10:31 2010 (4C3D70F7)
fffff880`07a00000 fffff880`07a11000   epfwwfp  epfwwfp.sys  Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`0a766000 fffff880`0a79c000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01058000 fffff880`0106c000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00faf000 fffff880`00ffb000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`015a4000 fffff880`015ae000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01b65000 fffff880`01b9f000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01a62000 fffff880`01aac000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`0a6f7000 fffff880`0a700000   gdrv     gdrv.sys     Thu Mar 12 23:22:29 2009 (49B9D175)
fffff800`035ed000 fffff800`03636000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`04600000 fffff880`04624000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`05d39000 fffff880`05d95000   HdAudio  HdAudio.sys  Sat Nov 20 05:44:23 2010 (4CE7A687)
fffff880`0106c000 fffff880`01085000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`045f4000 fffff880`045fc080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`076f4000 fffff880`07702000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`07a55000 fffff880`07b1e000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01b5c000 fffff880`01b65000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`07a11000 fffff880`07a2a000   idmwfp   idmwfp.sys   Wed Sep 29 16:43:26 2010 (4CA3A4EE)
fffff880`011d2000 fffff880`011f2000   jraid    jraid.sys    Wed Jan 27 03:58:17 2010 (4B600029)
fffff880`01496000 fffff880`014a5000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05d2b000 fffff880`05d39000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00b9c000 fffff800`00ba6000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`05c43000 fffff880`05c86000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`01506000 fffff880`01521000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`01600000 fffff880`0162b000   ksecpkg  ksecpkg.sys  Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`05df4000 fffff880`05df9200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`07702000 fffff880`07717000   LHidFilt LHidFilt.Sys Tue Aug 24 13:21:36 2010 (4C73FFA0)
fffff880`06fa5000 fffff880`06fba000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`07767000 fffff880`0778a000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cc2000 fffff880`00ccf000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`07759000 fffff880`07767000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`01085000 fffff880`01094000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05d1e000 fffff880`05d2b000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`01000000 fffff880`0101a000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`07b3c000 fffff880`07b54000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`07b54000 fffff880`07b81000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`07b81000 fffff880`07bce000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`07bce000 fffff880`07bf2000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`015b7000 fffff880`015c2000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`010eb000 fffff880`010f5000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0a7fc000 fffff880`0a7fdc00   MSPCLOCK MSPCLOCK.sys Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`0a7fa000 fffff880`0a7fba80   MSPQM    MSPQM.sys    Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`014a8000 fffff880`01506000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`0405d000 fffff880`04068000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01b4a000 fffff880`01b5c000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01693000 fffff880`01786000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`04a1d000 fffff880`04a29000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0a753000 fffff880`0a766000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`01200000 fffff880`0122f000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`05d09000 fffff880`05d1e000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`04165000 fffff880`04174000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`040f1000 fffff880`04136000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01786000 fffff880`017e6000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`015c2000 fffff880`015d3000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04051000 fffff880`0405d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`03003000 fffff800`035ed000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`01232000 fffff880`013d5000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`01846000 fffff880`0184f000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`05c98000 fffff880`05caf000   nusb3hub nusb3hub.sys Fri Nov 20 05:15:57 2009 (4B066C5D)
fffff880`04624000 fffff880`04654000   nusb3xhc nusb3xhc.sys Fri Nov 20 05:16:01 2009 (4B066C61)
fffff880`055fc000 fffff880`055fd180   nvBridge nvBridge.kmd Fri Oct 08 02:47:30 2010 (4CAEBE82)
fffff880`04a2a000 fffff880`055fb180   nvlddmkm nvlddmkm.sys Fri Oct 08 03:41:00 2010 (4CAECB0C)
fffff880`0a700000 fffff880`0a753000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`0413f000 fffff880`04165000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`04495000 fffff880`044b2000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01135000 fffff880`0114a000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`01102000 fffff880`01135000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`011bb000 fffff880`011c2000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`011c2000 fffff880`011d2000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01593000 fffff880`015a4000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`09a18000 fffff880`09abe000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05d95000 fffff880`05dd2000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00ccf000 fffff880`00ce3000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`041c0000 fffff880`041e4000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`041e4000 fffff880`041ff000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`013d5000 fffff880`013f6000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`040d5000 fffff880`040ef000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04000000 fffff880`04051000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`044b2000 fffff880`044bd000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`017e6000 fffff880`017ef000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`017ef000 fffff880`017f8000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`015ae000 fffff880`015b7000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01b10000 fffff880`01b4a000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`06fba000 fffff880`06fd2000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0443e000 fffff880`04495000   Rt64win7 Rt64win7.sys Mon Mar 22 05:57:14 2010 (4BA73EFA)
fffff880`07471000 fffff880`076aa080   RTKVHD64 RTKVHD64.sys Tue Apr 06 06:17:30 2010 (4BBB0A3A)
fffff880`00f80000 fffff880`00faf000   SCSIPORT SCSIPORT.SYS Sat Nov 20 05:34:01 2010 (4CE7A419)
fffff880`09abe000 fffff880`09ac9000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04a11000 fffff880`04a1d000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`04174000 fffff880`04191000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`08df2000 fffff880`08dfa380   SNCAMD   SNCAMD.SYS   Thu Jan 25 05:48:38 2007 (45B88B06)
fffff880`08209000 fffff880`08df1080   snp2sxp  snp2sxp.sys  Thu May 10 04:11:58 2007 (4642D3CE)
fffff880`01b08000 fffff880`01b10000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`00e15000 fffff880`00f77000   sptd     sptd.sys     Tue Nov 23 06:47:37 2010 (4CEBA9D9)
fffff880`0a65e000 fffff880`0a6f7000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`09b0c000 fffff880`09b77000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`09ac9000 fffff880`09afa000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`076ab000 fffff880`076bbd00   STREAM   STREAM.SYS   Mon Jul 13 20:06:18 2009 (4A5BCBFA)
fffff880`046b9000 fffff880`046ba480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`0185e000 fffff880`01a62000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`09afa000 fffff880`09b0c000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`01400000 fffff880`0140d000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`015d3000 fffff880`015f5000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`041ac000 fffff880`041c0000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00440000 fffff960`0044a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`045a0000 fffff880`045c6000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`05c86000 fffff880`05c98000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`076d7000 fffff880`076f4000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`04654000 fffff880`04655f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04a00000 fffff880`04a11000   usbehci  usbehci.sys  Sat Nov 20 05:43:54 2010 (4CE7A66A)
fffff880`05caf000 fffff880`05d09000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`04656000 fffff880`04661000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04661000 fffff880`046b7000   USBPORT  USBPORT.SYS  Sat Nov 20 05:44:00 2010 (4CE7A670)
fffff880`076bc000 fffff880`076d7000   USBSTOR  USBSTOR.SYS  Sat Nov 20 05:44:05 2010 (4CE7A675)
fffff880`010f5000 fffff880`01102000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01650000 fffff880`0165e000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`046b7000 fffff880`046b8d80   vHidDev  vHidDev.sys  Mon Dec 21 08:49:58 2009 (4B2F7D06)
fffff880`0165e000 fffff880`01683000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01aac000 fffff880`01abc000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`0114a000 fffff880`0115f000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`0115f000 fffff880`011bb000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01abc000 fffff880`01b08000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`04191000 fffff880`041ac000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`01683000 fffff880`01693000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`08dfb000 fffff880`08dfe880   wdcsam64 wdcsam64.sys Wed Apr 16 04:39:08 2008 (4805BB2C)
fffff880`00d41000 fffff880`00de5000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00de5000 fffff880`00df4000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`04136000 fffff880`0413f000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00371000   win32k   win32k.sys   Wed Jan 05 01:55:38 2011 (4D2415EA)
fffff880`045db000 fffff880`045e4000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f77000 fffff880`00f80000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`06f57000 fffff880`06f78000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`0a79c000 fffff880`0a7cd000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0a766000 fffff880`0a7d7000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`07723000 fffff880`07731000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`07731000 fffff880`0773d000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0773d000 fffff880`07746000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`07746000 fffff880`07759000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0a777000 fffff880`0a7a8000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0a766000 fffff880`0a777000   WinUsb.sys
    Checksum:  00000000
    ImageSize:  00011000
fffff880`0a600000 fffff880`0a631000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0a7d7000 fffff880`0a7e8000   WinUsb.sys
    Checksum:  00000000
    ImageSize:  00011000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01be5000 fffff880`01bf3000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01bf3000 fffff880`01bff000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01800000 fffff880`01809000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01809000 fffff880`0181c000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
[langtitle=uk]Re: Everyday i see BSOD! Help![/langtitle]
[lang=uk]Я все зробив, але проблема присутня. Це мій файл після останнього синього екрану:[/lang]
  • dump.file.rar
032011-30950-01.dmp
BugCheck 1000007E, {ffffffffc0000005, fffff800030a3c0c, fffff880033aee88, fffff880033ae6e0}
Probably caused by : cng.sys ( cng!GatherRandomKey+22c )
1. Uninstall your Pinnacle version, it's very old and not for Windows 7:
MarvinBus64.sys Fri Sep 23 17:17:03 2005
2. Update or disable in windows device manager, the webcam -- USB 2.0 PC Camera (SN9C201)
3. Uninstall Daemon Tools, reboot, and clear up with this tool:
DuplexSecure - FAQ
CRASH DUMPS
Loading Dump File [F:\DMP\032011-30950-01.dmp]
Machine Name:
Kernel base = 0xfffff800`03007000 PsLoadedModuleList = 0xfffff800`0324ce90
Debug session time: Sun Mar 20 07:34:37.402 2011 (UTC - 4:00)
System Uptime: 0 days 0:39:07.932
0: kd> !analyze -v
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff800030a3c0c, The address that the exception occurred at
Arg3: fffff880033aee88, Exception Record Address
Arg4: fffff880033ae6e0, Context Record Address
Debugging Details:
FAULTING_IP:
fffff800`030a3c0c 498b02          mov     rax,qword ptr [r10]
EXCEPTION_RECORD:  fffff880033aee88 -- (.exr 0xfffff880033aee88)
ExceptionAddress: fffff800030a3c0c (nt!ObReferenceObjectSafe+0x000000000000000c)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT:  fffff880033ae6e0 -- (.cxr 0xfffff880033ae6e0)
rax=0000000000000000 rbx=fffbfa800732ba38 rcx=fffbfa800732b8b0
rdx=fffffa80077202c1 rsi=fffffa8003a8e040 rdi=fffffa8006410b30
rip=fffff800030a3c0c rsp=fffff880033af0c0 rbp=0000000000000000
 r8=fffffa80077202c0  r9=000000000000001a r10=fffbfa800732b880
r11=fffffa80051b7ec0 r12=fffbfa800732b8b0 r13=0000000000000000
r14=0000000000000001 r15=fffff8000322eb90
fffff800`030a3c0c 498b02          mov     rax,qword ptr [r10] ds:002b:fffbfa80`0732b880=????????????????
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800032b80e8
 ffffffffffffffff
FOLLOWUP_IP:
fffff880`014f7e8c 83ff20          cmp     edi,20h
BUGCHECK_STR:  0x7E
LAST_CONTROL_TRANSFER:  from fffff800033459a9 to fffff800030a3c0c
STACK_TEXT:
fffff880`033af0c0 fffff800`033459a9 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff8a0`0feb3170 : nt!ObReferenceObjectSafe+0xc
fffff880`033af0f0 fffff800`03345201 : 00000000`00000000 fffff880`033af700 00000000`0000a0e8 fffff8a0`0feb2f80 : nt!PsGetNextProcess+0x81
fffff880`033af140 fffff800`03390ef6 : fffff8a0`0fea90a8 00000000`0001ff58 fffff880`033af2d0 00000000`00000000 : nt!ExpGetProcessInformation+0x774
fffff880`033af290 fffff800`03391949 : fffff8a0`0fea90a8 fffffa80`6365734b 00000000`00000000 fffff880`033afc20 : nt!ExpQuerySystemInformation+0xfb4
fffff880`033af640 fffff800`030868d3 : fffff880`033af710 fffff800`0308587d 00000000`00000001 fffff8a0`0fea9000 : nt!NtQuerySystemInformation+0x4d
fffff880`033af680 fffff800`03082e70 : fffff880`014f7e8c fffff800`0320bbc0 fffff880`033af844 fffff8a0`0fea9000 : nt!KiSystemServiceCopyEnd+0x13
fffff880`033af818 fffff880`014f7e8c : fffff800`0320bbc0 fffff880`033af844 fffff8a0`0fea9000 00000000`0000002e : nt!KiServiceLinkage
fffff880`033af820 fffff880`014f83ed : fffffa80`04842c50 fffff800`0308f9f3 00000000`20206f49 fffff880`03163180 : cng!GatherRandomKey+0x22c
fffff880`033afbe0 fffff800`0337df4d : 00000000`00000001 00000000`00000001 fffffa80`062d9440 fffffa80`03a8e040 : cng!scavengingWorkItemRoutine+0x3d
fffff880`033afc80 fffff800`03091a21 : fffff8a0`0fea9000 fffff800`03499101 fffff800`03224600 fffffa80`03a8e040 : nt!IopProcessWorkItem+0x3d
fffff880`033afcb0 fffff800`03324cce : 00000000`00000000 fffffa80`03a8e040 00000000`00000080 fffffa80`039d4040 : nt!ExpWorkerThread+0x111
fffff880`033afd40 fffff800`03078fe6 : fffff880`03163180 fffffa80`03a8e040 fffff880`0316dfc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`033afd80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
SYMBOL_NAME:  cng!GatherRandomKey+22c
MODULE_NAME: cng
IMAGE_NAME:  cng.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce79e2d
STACK_COMMAND:  .cxr 0xfffff880033ae6e0 ; kb
FAILURE_BUCKET_ID:  X64_0x7E_cng!GatherRandomKey+22c
DRIVERS
fffff880`02fbd000 fffff880`02ffb000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`013ae000 fffff880`013f6000   a3oiaqlt a3oiaqlt.SYS Sun Nov 28 05:38:44 2010 (4CF23134)
fffff880`011a2000 fffff880`011f9000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`04271000 fffff880`042fa000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`055ea000 fffff880`05600000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`02f49000 fffff880`02f5e000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00fe9000 fffff880`00ff4000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`02f1b000 fffff880`02f23000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`02ef4000 fffff880`02f1b000   archlp   archlp.sys   Tue Jan 12 03:07:45 2010 (4B4C2DD1)
fffff880`00fe0000 fffff880`00fe9000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00dcf000 fffff880`00df9000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff960`00970000 fffff960`009d1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`01833000 fffff880`0183a000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02ee3000 fffff880`02ef4000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`07186000 fffff880`071a4000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00700000 fffff960`00727000   cdd      cdd.dll      unavailable (00000000)
fffff880`01800000 fffff880`0182a000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00d0f000 fffff880`00dcf000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`01b94000 fffff880`01bc4000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00cb1000 fffff880`00d0f000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`014f3000 fffff880`01565000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`0441d000 fffff880`0442d000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`0768d000 fffff880`0769b000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02e42000 fffff880`02ec5000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`08209000 fffff880`0820bf00   danew    danew.sys    Tue Mar 23 04:37:33 2010 (4BA87DCD)
fffff880`02ec5000 fffff880`02ee3000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`043c9000 fffff880`043d8000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01b7e000 fffff880`01b94000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`070d9000 fffff880`070fb000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`076a7000 fffff880`076b0000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0769b000 fffff880`076a7000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`076b0000 fffff880`076c3000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`07681000 fffff880`0768d000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04431000 fffff880`04525000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`04525000 fffff880`0456b000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`07705000 fffff880`077dd000   eamonm   eamonm.sys   Fri Aug 13 08:38:55 2010 (4C653CDF)
fffff880`07101000 fffff880`0712e000   epfw     epfw.sys     Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`045ea000 fffff880`045f5000   Epfwndis Epfwndis.sys Wed Jul 14 04:10:31 2010 (4C3D70F7)
fffff880`07cc3000 fffff880`07cd4000   epfwwfp  epfwwfp.sys  Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`00c4c000 fffff880`00c60000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00c00000 fffff880`00c4c000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`01576000 fffff880`01580000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01b44000 fffff880`01b7e000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01a41000 fffff880`01a8b000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`07f6f000 fffff880`07f78000   gdrv     gdrv.sys     Thu Mar 12 23:22:29 2009 (49B9D175)
fffff800`035f1000 fffff800`0363a000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`0456b000 fffff880`0458f000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`05c00000 fffff880`05c5c000   HdAudio  HdAudio.sys  Sat Nov 20 05:44:23 2010 (4CE7A687)
fffff880`015d4000 fffff880`015ed000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`045f7000 fffff880`045ff080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`07163000 fffff880`07171000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`07000000 fffff880`070c9000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01b3b000 fffff880`01b44000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`07cd4000 fffff880`07ced000   idmwfp   idmwfp.sys   Wed Sep 29 16:43:26 2010 (4CA3A4EE)
fffff880`00e6c000 fffff880`00e8c000   jraid    jraid.sys    Wed Jan 27 03:58:17 2010 (4B600029)
fffff880`00e8c000 fffff880`00e9b000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05db1000 fffff880`05dbf000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00bd5000 fffff800`00bdf000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`05c83000 fffff880`05cc6000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`014d8000 fffff880`014f3000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`070fb000 fffff880`07100200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`07171000 fffff880`07186000   LHidFilt LHidFilt.Sys Tue Aug 24 13:21:36 2010 (4C73FFA0)
fffff880`07400000 fffff880`07415000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`076e2000 fffff880`07705000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`05cc6000 fffff880`05d0a000   MarvinBus64 MarvinBus64.sys Fri Sep 23 17:17:03 2005 (433470CF)
fffff880`00c90000 fffff880`00c9d000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`076c3000 fffff880`076d1000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`05c72000 fffff880`05c81000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05da4000 fffff880`05db1000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00fc6000 fffff880`00fe0000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`071a4000 fffff880`071bc000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`071bc000 fffff880`071e9000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`07c52000 fffff880`07c9f000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`07c9f000 fffff880`07cc3000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`01589000 fffff880`01594000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f52000 fffff880`00f5c000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0147a000 fffff880`014d8000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`0425d000 fffff880`04268000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01b29000 fffff880`01b3b000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0169c000 fffff880`0178f000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`04a00000 fffff880`04a0c000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`07fcb000 fffff880`07fde000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`00c60000 fffff880`00c8f000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`05d8f000 fffff880`05da4000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`0436e000 fffff880`0437d000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`042fa000 fffff880`0433f000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`0178f000 fffff880`017ef000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`01594000 fffff880`015a5000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04251000 fffff880`0425d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`03007000 fffff800`035f1000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`0120b000 fffff880`013ae000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`0182a000 fffff880`01833000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`05d1c000 fffff880`05d35000   nusb3hub nusb3hub.sys Thu Nov 18 20:34:24 2010 (4CE5D420)
fffff880`0458f000 fffff880`045c0000   nusb3xhc nusb3xhc.sys Thu Nov 18 20:34:25 2010 (4CE5D421)
fffff880`055e8000 fffff880`055e9180   nvBridge nvBridge.kmd Fri Oct 08 02:47:30 2010 (4CAEBE82)
fffff880`04a16000 fffff880`055e7180   nvlddmkm nvlddmkm.sys Fri Oct 08 03:41:00 2010 (4CAECB0C)
fffff880`07f78000 fffff880`07fcb000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`04348000 fffff880`0436e000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`04400000 fffff880`0441d000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00f9c000 fffff880`00fb1000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`00f69000 fffff880`00f9c000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`011f9000 fffff880`01200000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e5c000 fffff880`00e6c000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01565000 fffff880`01576000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07ced000 fffff880`07d93000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05dbf000 fffff880`05dfc000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c9d000 fffff880`00cb1000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`00ff4000 fffff880`00fffe00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`02e00000 fffff880`02e24000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`02e24000 fffff880`02e3f000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`043d8000 fffff880`043f9000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`01457000 fffff880`01471000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04200000 fffff880`04251000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`015ed000 fffff880`015f8000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01693000 fffff880`0169c000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01580000 fffff880`01589000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01aef000 fffff880`01b29000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`0712e000 fffff880`07146000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01400000 fffff880`01457000   Rt64win7 Rt64win7.sys Mon Mar 22 05:57:14 2010 (4BA73EFA)
fffff880`07417000 fffff880`07680800   RTKVHD64 RTKVHD64.sys Tue Nov 02 07:25:59 2010 (4CCFF547)
fffff880`01173000 fffff880`011a2000   SCSIPORT SCSIPORT.SYS Sat Nov 20 05:34:01 2010 (4CE7A419)
fffff880`07d93000 fffff880`07d9e000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`045de000 fffff880`045ea000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0437d000 fffff880`0439a000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`08200000 fffff880`08208380   SNCAMD   SNCAMD.SYS   Thu Jan 25 05:48:38 2007 (45B88B06)
fffff880`08210000 fffff880`08df8080   snp2sxp  snp2sxp.sys  Thu May 10 04:11:58 2007 (4642D3CE)
fffff880`01ae7000 fffff880`01aef000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01008000 fffff880`0116a000   sptd     sptd.sys     Tue Nov 23 06:47:37 2010 (4CEBA9D9)
fffff880`07ed6000 fffff880`07f6f000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`07e6b000 fffff880`07ed6000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`07d9e000 fffff880`07dcf000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`076d1000 fffff880`076e1d00   STREAM   STREAM.SYS   Mon Jul 13 20:06:18 2009 (4A5BCBFA)
fffff880`05c81000 fffff880`05c82480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`0183d000 fffff880`01a41000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`07dcf000 fffff880`07de1000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`015c7000 fffff880`015d4000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`015a5000 fffff880`015c7000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`043b5000 fffff880`043c9000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00460000 fffff960`0046a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`02f23000 fffff880`02f49000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`05d0a000 fffff880`05d1c000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`07146000 fffff880`07163000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`045c0000 fffff880`045c1f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`045cd000 fffff880`045de000   usbehci  usbehci.sys  Sat Nov 20 05:43:54 2010 (4CE7A66A)
fffff880`05d35000 fffff880`05d8f000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`045c2000 fffff880`045cd000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`02f67000 fffff880`02fbd000   USBPORT  USBPORT.SYS  Sat Nov 20 05:44:00 2010 (4CE7A670)
fffff880`00f5c000 fffff880`00f69000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`045f5000 fffff880`045f6d80   vHidDev  vHidDev.sys  Mon Dec 21 08:49:58 2009 (4B2F7D06)
fffff880`01a8b000 fffff880`01a9b000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`00fb1000 fffff880`00fc6000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01a9b000 fffff880`01ae7000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`0439a000 fffff880`043b5000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`00e9f000 fffff880`00f43000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f43000 fffff880`00f52000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0433f000 fffff880`04348000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00010000 fffff960`00321000   win32k   win32k.sys   unavailable (00000000)
fffff880`02f5e000 fffff880`02f67000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0116a000 fffff880`01173000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`077dd000 fffff880`077fe000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`0c872000 fffff880`0c8e3000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01bc4000 fffff880`01bd2000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01bd2000 fffff880`01bde000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01bde000 fffff880`01be7000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01be7000 fffff880`01bfa000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
[lang=uk]І знову :([/lang]
  • dmp.file.rar
You didn't update the drivers:
Western Digital
Webcam
Also, you didn't uninstall Pinnacle and Daemon Tools:
CRASH DUMPS
Loading Dump File [F:\DMP\032111-21262-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0305f000 PsLoadedModuleList = 0xfffff800`032a4e90
Debug session time: Mon Mar 21 04:41:08.725 2011 (UTC - 4:00)
System Uptime: 0 days 2:59:14.764
BugCheck 3B, {c0000005, fffff800030fbc0c, fffff8800a741c80, 0}
1: kd> !analyze -v
Arguments:
Arg2: fffff800030fbc0c, Address of the instruction which caused the bugcheck
Arg3: fffff8800a741c80, Address of the context record for the exception that caused the bugcheck
Debugging Details:
FAULTING_IP:
fffff800`030fbc0c 498b02          mov     rax,qword ptr [r10]
CONTEXT:  fffff8800a741c80 -- (.cxr 0xfffff8800a741c80)
rax=0000000000000000 rbx=fffbfa8006d208b8 rcx=fffbfa8006d20730
rdx=0000000000000001 rsi=fffffa80075cfb60 rdi=fffffa80070d8b30
rip=fffff800030fbc0c rsp=fffff8800a742660 rbp=0000000000000000
 r8=0000000000000000  r9=0000000000000016 r10=fffbfa8006d20700
r11=fffffa80075d3110 r12=fffbfa8006d20730 r13=0000000000000000
r14=0000000000000001 r15=fffff80003286b90
fffff800`030fbc0c 498b02          mov     rax,qword ptr [r10] ds:002b:fffbfa80`06d20700=????????????????
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff800030fbc0c
STACK_TEXT:
fffff880`0a742660 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ObReferenceObjectSafe+0xc
FOLLOWUP_IP:
MODULE_NAME: nt
STACK_COMMAND:  .cxr 0xfffff8800a741c80 ; kb
DRIVERS
fffff880`02eef000 fffff880`02f2d000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`00e2f000 fffff880`00e86000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`01400000 fffff880`01489000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`02fc8000 fffff880`02fde000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`043cd000 fffff880`043e2000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`011bb000 fffff880`011c6000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`042d9000 fffff880`042e1000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`042b2000 fffff880`042d9000   archlp   archlp.sys   Tue Jan 12 03:07:45 2010 (4B4C2DD1)
fffff880`01188000 fffff880`01191000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01191000 fffff880`011bb000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff960`00950000 fffff960`009b1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`01869000 fffff880`01870000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`042a1000 fffff880`042b2000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`07980000 fffff880`0799e000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00620000 fffff960`00647000   cdd      cdd.dll      unavailable (00000000)
fffff880`01836000 fffff880`01860000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`01bcf000 fffff880`01bff000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00cfe000 fffff880`00d5c000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0150c000 fffff880`0157e000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`02fad000 fffff880`02fbd000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`076e6000 fffff880`076f4000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04200000 fffff880`04283000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`08dfa000 fffff880`08dfcf00   danew    danew.sys    Tue Mar 23 04:37:33 2010 (4BA87DCD)
fffff880`04283000 fffff880`042a1000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`04398000 fffff880`043a7000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01bb9000 fffff880`01bcf000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05ddc000 fffff880`05dfe000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`07700000 fffff880`07709000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`076f4000 fffff880`07700000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`07709000 fffff880`0771c000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0771c000 fffff880`07728000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0465b000 fffff880`0474f000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`0474f000 fffff880`04795000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`064e4000 fffff880`065bc000   eamonm   eamonm.sys   Fri Aug 13 08:38:55 2010 (4C653CDF)
fffff880`06400000 fffff880`0642d000   epfw     epfw.sys     Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`02fbd000 fffff880`02fc8000   Epfwndis Epfwndis.sys Wed Jul 14 04:10:31 2010 (4C3D70F7)
fffff880`07871000 fffff880`07882000   epfwwfp  epfwwfp.sys  Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`08e66000 fffff880`08e9c000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`0104c000 fffff880`01060000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01000000 fffff880`0104c000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`0158f000 fffff880`01599000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01b7f000 fffff880`01bb9000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01a7c000 fffff880`01ac6000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`08fda000 fffff880`08fe3000   gdrv     gdrv.sys     Thu Mar 12 23:22:29 2009 (49B9D175)
fffff800`03016000 fffff800`0305f000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`04795000 fffff880`047b9000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`02eb7000 fffff880`02ed0000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`02ed0000 fffff880`02ed8080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`076c3000 fffff880`076d1000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`078b7000 fffff880`07980000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01b76000 fffff880`01b7f000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`07882000 fffff880`0789b000   idmwfp   idmwfp.sys   Wed Sep 29 16:43:26 2010 (4CA3A4EE)
fffff880`0114e000 fffff880`0116e000   jraid    jraid.sys    Wed Jan 27 03:58:17 2010 (4B600029)
fffff880`02fde000 fffff880`02fed000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05dce000 fffff880`05ddc000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00ba9000 fffff800`00bb3000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`05ca0000 fffff880`05ce3000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`014f1000 fffff880`0150c000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`05c99000 fffff880`05c9e200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`076d1000 fffff880`076e6000   LHidFilt LHidFilt.Sys Tue Aug 24 13:21:36 2010 (4C73FFA0)
fffff880`0642d000 fffff880`06442000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`07736000 fffff880`07759000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`05ce3000 fffff880`05d27000   MarvinBus64 MarvinBus64.sys Fri Sep 23 17:17:03 2005 (433470CF)
fffff880`00cdd000 fffff880`00cea000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`07728000 fffff880`07736000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`02fed000 fffff880`02ffc000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05dc1000 fffff880`05dce000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`0116e000 fffff880`01188000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`0799e000 fffff880`079b6000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`079b6000 fffff880`079e3000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`07800000 fffff880`0784d000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`0784d000 fffff880`07871000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`015a2000 fffff880`015ad000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ff3000 fffff880`00ffd000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01493000 fffff880`014f1000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`0438d000 fffff880`04398000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01b64000 fffff880`01b76000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0168b000 fffff880`0177e000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`02e24000 fffff880`02e30000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`08e53000 fffff880`08e66000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`02e30000 fffff880`02e5f000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`05dac000 fffff880`05dc1000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`015ed000 fffff880`015fc000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`013b0000 fffff880`013f5000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`0177e000 fffff880`017de000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`015ad000 fffff880`015be000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04381000 fffff880`0438d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0305f000 fffff800`03649000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`0120d000 fffff880`013b0000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`01860000 fffff880`01869000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`05d39000 fffff880`05d52000   nusb3hub nusb3hub.sys Thu Nov 18 20:34:24 2010 (4CE5D420)
fffff880`047b9000 fffff880`047ea000   nusb3xhc nusb3xhc.sys Thu Nov 18 20:34:25 2010 (4CE5D421)
fffff880`055e6000 fffff880`055e7180   nvBridge nvBridge.kmd Fri Oct 08 02:47:30 2010 (4CAEBE82)
fffff880`04a14000 fffff880`055e5180   nvlddmkm nvlddmkm.sys Fri Oct 08 03:41:00 2010 (4CAECB0C)
fffff880`08e00000 fffff880`08e53000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`011c6000 fffff880`011ec000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`02f90000 fffff880`02fad000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`010b1000 fffff880`010c6000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`0107e000 fffff880`010b1000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`01137000 fffff880`0113e000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`0113e000 fffff880`0114e000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0157e000 fffff880`0158f000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`07759000 fffff880`077ff000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05c5c000 fffff880`05c99000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cea000 fffff880`00cfe000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`01060000 fffff880`0106be00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`02e5f000 fffff880`02e7a000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`02e7a000 fffff880`02e9b000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`02e9b000 fffff880`02eb5000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04330000 fffff880`04381000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`02ed9000 fffff880`02ee4000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`017ee000 fffff880`017f7000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`017f7000 fffff880`01800000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01599000 fffff880`015a2000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01b2a000 fffff880`01b64000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`06442000 fffff880`0645a000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02f2d000 fffff880`02f84000   Rt64win7 Rt64win7.sys Mon Mar 22 05:57:14 2010 (4BA73EFA)
fffff880`07414000 fffff880`0767d800   RTKVHD64 RTKVHD64.sys Tue Nov 02 07:25:59 2010 (4CCFF547)
fffff880`00e00000 fffff880`00e2f000   SCSIPORT SCSIPORT.SYS Sat Nov 20 05:34:01 2010 (4CE7A419)
fffff880`0789b000 fffff880`078a6000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`02f84000 fffff880`02f90000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`042e4000 fffff880`04301000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0769d000 fffff880`076a5380   SNCAMD   SNCAMD.SYS   Thu Jan 25 05:48:38 2007 (45B88B06)
fffff880`08211000 fffff880`08df9080   snp2sxp  snp2sxp.sys  Thu May 10 04:11:58 2007 (4642D3CE)
fffff880`01b22000 fffff880`01b2a000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`00e88000 fffff880`00fea000   sptd     sptd.sys     Tue Nov 23 06:47:37 2010 (4CEBA9D9)
fffff880`08f41000 fffff880`08fda000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`08ed6000 fffff880`08f41000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`0645a000 fffff880`0648b000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`08200000 fffff880`08210d00   STREAM   STREAM.SYS   Mon Jul 13 20:06:18 2009 (4A5BCBFA)
fffff880`02ffc000 fffff880`02ffd480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01878000 fffff880`01a7c000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`079e3000 fffff880`079f5000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`015e0000 fffff880`015ed000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`015be000 fffff880`015e0000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`0431c000 fffff880`04330000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`004c0000 fffff960`004ca000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`043a7000 fffff880`043cd000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`05d27000 fffff880`05d39000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`076a6000 fffff880`076c3000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`047ea000 fffff880`047ebf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`055e8000 fffff880`055f9000   usbehci  usbehci.sys  Sat Nov 20 05:43:54 2010 (4CE7A66A)
fffff880`05d52000 fffff880`05dac000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`047ec000 fffff880`047f7000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04600000 fffff880`04656000   USBPORT  USBPORT.SYS  Sat Nov 20 05:44:00 2010 (4CE7A670)
fffff880`0767e000 fffff880`07699000   USBSTOR  USBSTOR.SYS  Sat Nov 20 05:44:05 2010 (4CE7A675)
fffff880`00ccf000 fffff880`00cdc000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02eb5000 fffff880`02eb6d80   vHidDev  vHidDev.sys  Mon Dec 21 08:49:58 2009 (4B2F7D06)
fffff880`01ac6000 fffff880`01ad6000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`010c6000 fffff880`010db000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`010db000 fffff880`01137000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01ad6000 fffff880`01b22000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`04301000 fffff880`0431c000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`017de000 fffff880`017ee000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`07699000 fffff880`0769c880   wdcsam64 wdcsam64.sys Wed Apr 16 04:39:08 2008 (4805BB2C)
fffff880`00d5c000 fffff880`00e00000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00cc0000 fffff880`00ccf000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`01489000 fffff880`01492000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000b0000 fffff960`003c1000   win32k   win32k.sys   Wed Jan 05 01:55:38 2011 (4D2415EA)
fffff880`043e2000 fffff880`043eb000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fea000 fffff880`00ff3000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`065bc000 fffff880`065dd000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`08e9c000 fffff880`08ecd000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0be0c000 fffff880`0be7d000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01800000 fffff880`0180e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0180e000 fffff880`0181a000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0181a000 fffff880`01823000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01823000 fffff880`01836000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
[lang=uk][Lang = UK] Пишу Вам оста & # 1085; ній раз, драйв і # 1077; ра для Western Digital віднови & # 1074;, Pinnacle Studio І Deamon Відаля, І зн ; ову синій екран & # 1085;. Для вебкамери & # 1085; ажаль Немає але вих драйверів . Напевно перес & # 1090; авлю систему
[/ мова]
[/lang]
  • dmp.file.rar
Re: [langtitle=uk]Re: Everyday i see BSOD! Help![/langtitle]
BugCheck 3B, {c0000005, fffff800030e9c0c, fffff8800c290c80, 0}
Old drivers:
Daemon Tools sptd.sys Tue Nov 23 06:47:37 2010
See my posts above.
CRASH DUMPS
Loading Dump File [F:\DMP\032111-21855-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`0304d000 PsLoadedModuleList = 0xfffff800`03292e90
Debug session time: Mon Mar 21 17:10:16.272 2011 (UTC - 4:00)
System Uptime: 0 days 4:35:41.801
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
2: kd> !analyze -v
Arguments:
Arg2: fffff800030e9c0c, Address of the instruction which caused the bugcheck
Arg3: fffff8800c290c80, Address of the context record for the exception that caused the bugcheck
Debugging Details:
FAULTING_IP:
fffff800`030e9c0c 498b02          mov     rax,qword ptr [r10]
CONTEXT:  fffff8800c290c80 -- (.cxr 0xfffff8800c290c80)
rax=0000000000000000 rbx=fffbfa8005e4d1e8 rcx=fffbfa8005e4d060
rdx=fffffa8004c0b421 rsi=fffffa8007852780 rdi=fffffa800641b770
rip=fffff800030e9c0c rsp=fffff8800c291660 rbp=0000000000000000
 r8=fffffa8004c0b420  r9=0000000000296598 r10=fffbfa8005e4d030
r11=fffffa80042ef010 r12=fffbfa8005e4d060 r13=0000000000000000
r14=0000000000000001 r15=fffff80003274b90
fffff800`030e9c0c 498b02          mov     rax,qword ptr [r10] ds:002b:fffbfa80`05e4d030=????????????????
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff800030e9c0c
STACK_TEXT:
fffff880`0c291660 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ObReferenceObjectSafe+0xc
FOLLOWUP_IP:
MODULE_NAME: nt
STACK_COMMAND:  .cxr 0xfffff8800c290c80 ; kb
DRIVERS
fffff880`04200000 fffff880`0423e000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`01455000 fffff880`014de000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`055e8000 fffff880`055fe000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`04377000 fffff880`0438c000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`01174000 fffff880`0117f000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`04349000 fffff880`04351000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`04322000 fffff880`04349000   archlp   archlp.sys   Tue Jan 12 03:07:45 2010 (4B4C2DD1)
fffff880`01141000 fffff880`0114a000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0114a000 fffff880`01174000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff960`00960000 fffff960`009c1000   ATMFD    ATMFD.DLL    Fri Jan 07 04:20:44 2011 (4D26DAEC)
fffff880`018e9000 fffff880`018f0000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04311000 fffff880`04322000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`07ae1000 fffff880`07aff000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00710000 fffff960`00737000   cdd      cdd.dll      Sat Nov 20 07:55:34 2010 (4CE7C546)
fffff880`0b9e0000 fffff880`0b9fd000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`018b6000 fffff880`018e0000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`01850000 fffff880`01880000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00cef000 fffff880`00d4d000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01575000 fffff880`015e7000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`047ec000 fffff880`047fc000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`07736000 fffff880`07744000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04270000 fffff880`042f3000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`0a9fc000 fffff880`0a9fef00   danew    danew.sys    Tue Mar 23 04:37:33 2010 (4BA87DCD)
fffff880`042f3000 fffff880`04311000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`04198000 fffff880`041a7000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0183a000 fffff880`01850000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06ea2000 fffff880`06ec4000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`07750000 fffff880`07759000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`07744000 fffff880`07750000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`07759000 fffff880`0776c000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`076d3000 fffff880`076df000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04616000 fffff880`0470a000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`0470a000 fffff880`04750000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`06eca000 fffff880`06fa2000   eamonm   eamonm.sys   Fri Aug 13 08:38:55 2010 (4C653CDF)
fffff880`077b0000 fffff880`077dd000   epfw     epfw.sys     Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`04600000 fffff880`0460b000   Epfwndis Epfwndis.sys Wed Jul 14 04:10:31 2010 (4C3D70F7)
fffff880`07bb5000 fffff880`07bc6000   epfwwfp  epfwwfp.sys  Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`0b9aa000 fffff880`0b9e0000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`011cb000 fffff880`011df000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0117f000 fffff880`011cb000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`01400000 fffff880`0140a000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01800000 fffff880`0183a000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01afd000 fffff880`01b47000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`0b899000 fffff880`0b8a2000   gdrv     gdrv.sys     Thu Mar 12 23:22:29 2009 (49B9D175)
fffff800`03004000 fffff800`0304d000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`04750000 fffff880`04774000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`05b77000 fffff880`05bd3000   HdAudio  HdAudio.sys  Sat Nov 20 05:44:23 2010 (4CE7A687)
fffff880`01200000 fffff880`01219000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`0460d000 fffff880`04615080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`07713000 fffff880`07721000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`07a18000 fffff880`07ae1000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01bf7000 fffff880`01c00000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`07bc6000 fffff880`07bdf000   idmwfp   idmwfp.sys   Wed Sep 29 16:43:26 2010 (4CA3A4EE)
fffff880`01107000 fffff880`01127000   jraid    jraid.sys    Wed Jan 27 03:58:17 2010 (4B600029)
fffff880`043eb000 fffff880`043fa000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05b69000 fffff880`05b77000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff880`05a3b000 fffff880`05a7e000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`0155a000 fffff880`01575000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`06ec4000 fffff880`06ec9200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`07721000 fffff880`07736000   LHidFilt LHidFilt.Sys Tue Aug 24 13:21:36 2010 (4C73FFA0)
fffff880`077dd000 fffff880`077f2000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0776c000 fffff880`0778f000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`05a7e000 fffff880`05ac2000   MarvinBus64 MarvinBus64.sys Fri Sep 23 17:17:03 2005 (433470CF)
fffff880`00cce000 fffff880`00cdb000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`076df000 fffff880`076ed000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0404a000 fffff880`04059000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05b5c000 fffff880`05b69000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`01127000 fffff880`01141000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`07aff000 fffff880`07b17000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`07b17000 fffff880`07b44000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`07b44000 fffff880`07b91000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`07b91000 fffff880`07bb5000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`0140a000 fffff880`01415000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ff4000 fffff880`00ffe000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0b908000 fffff880`0b909c00   MSPCLOCK MSPCLOCK.sys Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`0b9fd000 fffff880`0b9fea80   MSPQM    MSPQM.sys    Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`014fc000 fffff880`0155a000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`0418d000 fffff880`04198000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01be5000 fffff880`01bf7000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0169d000 fffff880`01790000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`0b8f5000 fffff880`0b908000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`04000000 fffff880`0402f000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`05b47000 fffff880`05b5c000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`040d5000 fffff880`040e4000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`04061000 fffff880`040a6000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01790000 fffff880`017f0000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`01415000 fffff880`01426000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04181000 fffff880`0418d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0304d000 fffff800`03637000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`0122e000 fffff880`013d1000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`018e0000 fffff880`018e9000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`05ad4000 fffff880`05aed000   nusb3hub nusb3hub.sys Thu Nov 18 20:34:24 2010 (4CE5D420)
fffff880`04774000 fffff880`047a5000   nusb3xhc nusb3xhc.sys Thu Nov 18 20:34:25 2010 (4CE5D421)
fffff880`0b8a2000 fffff880`0b8f5000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`040af000 fffff880`040d5000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`047cf000 fffff880`047ec000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0106a000 fffff880`0107f000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`01037000 fffff880`0106a000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`010f0000 fffff880`010f7000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`010f7000 fffff880`01107000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`015e7000 fffff880`015f8000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`09ace000 fffff880`09b74000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`06e65000 fffff880`06ea2000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cdb000 fffff880`00cef000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`011df000 fffff880`011eae00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`0423e000 fffff880`04262000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`0402f000 fffff880`0404a000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`013d1000 fffff880`013f2000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`014de000 fffff880`014f8000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04130000 fffff880`04181000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`04262000 fffff880`0426d000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`018f0000 fffff880`018f9000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01693000 fffff880`0169c000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`017f0000 fffff880`017f9000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01bab000 fffff880`01be5000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`07400000 fffff880`07418000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`041a7000 fffff880`041fe000   Rt64win7 Rt64win7.sys Mon Mar 22 05:57:14 2010 (4BA73EFA)
fffff880`0744a000 fffff880`076b3800   RTKVHD64 RTKVHD64.sys Tue Nov 02 07:25:59 2010 (4CCFF547)
fffff880`09b74000 fffff880`09b7f000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`047c3000 fffff880`047cf000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`040e4000 fffff880`04101000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`076ed000 fffff880`076f5380   SNCAMD   SNCAMD.SYS   Thu Jan 25 05:48:38 2007 (45B88B06)
fffff880`09e02000 fffff880`0a9ea080   snp2sxp  snp2sxp.sys  Thu May 10 04:11:58 2007 (4642D3CE)
fffff880`01ba3000 fffff880`01bab000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`00e89000 fffff880`00feb000   sptd     sptd.sys     Tue Nov 23 06:47:37 2010 (4CEBA9D9)
fffff880`0b800000 fffff880`0b899000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`09a00000 fffff880`09a6b000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`09b7f000 fffff880`09bb0000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`0a9eb000 fffff880`0a9fbd00   STREAM   STREAM.SYS   Mon Jul 13 20:06:18 2009 (4A5BCBFA)
fffff880`047fc000 fffff880`047fd480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`018f9000 fffff880`01afd000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`09bb0000 fffff880`09bc2000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`01448000 fffff880`01455000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`01426000 fffff880`01448000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`0411c000 fffff880`04130000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00480000 fffff960`0048a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`04351000 fffff880`04377000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`05ac2000 fffff880`05ad4000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`076f6000 fffff880`07713000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`047a5000 fffff880`047a6f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`047b2000 fffff880`047c3000   usbehci  usbehci.sys  Sat Nov 20 05:43:54 2010 (4CE7A66A)
fffff880`05aed000 fffff880`05b47000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`047a7000 fffff880`047b2000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04395000 fffff880`043eb000   USBPORT  USBPORT.SYS  Sat Nov 20 05:44:00 2010 (4CE7A670)
fffff880`076b4000 fffff880`076cf000   USBSTOR  USBSTOR.SYS  Sat Nov 20 05:44:05 2010 (4CE7A675)
fffff880`00cc0000 fffff880`00ccd000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0460b000 fffff880`0460cd80   vHidDev  vHidDev.sys  Mon Dec 21 08:49:58 2009 (4B2F7D06)
fffff880`01b47000 fffff880`01b57000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`0107f000 fffff880`01094000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`01094000 fffff880`010f0000   volmgrx  volmgrx.sys  Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01b57000 fffff880`01ba3000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`04101000 fffff880`0411c000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`076cf000 fffff880`076d2880   wdcsam64 wdcsam64.sys Wed Apr 16 04:39:08 2008 (4805BB2C)
fffff880`00d4d000 fffff880`00df1000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00df1000 fffff880`00e00000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`040a6000 fffff880`040af000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00080000 fffff960`00391000   win32k   win32k.sys   Wed Jan 05 01:55:38 2011 (4D2415EA)
fffff880`0438c000 fffff880`04395000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00feb000 fffff880`00ff4000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0778f000 fffff880`077b0000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`0b91b000 fffff880`0b94c000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0b90a000 fffff880`0b91b000   WinUsb.sys
    Checksum:  00000000
    ImageSize:  00011000
fffff880`0b979000 fffff880`0b9aa000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0b908000 fffff880`0b979000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  00031000
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  00031000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01880000 fffff880`0188e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0188e000 fffff880`0189a000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0189a000 fffff880`018a3000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`018a3000 fffff880`018b6000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Top Bottom
