Hey guys I was fiddling around with my pc trying to replace the start orb with the PS button (playstation) by using reshack.
So I saved the original .bmp edited it in PS and saved it as a .bmp I then editied the registry to use my newly created psexplorer.exe. I then ended my original explorer and selected the nex psexplorer located in C:\Windows.old\ (I just copied the windows folder and pasted it in C:\
But now every time I turn on my computer its all black and I have to manually start pxexplorer.exe from the task manager and the thing is its still the original windows 7 start orb even though I used reshack to replace Bitmap>6801>1033
Any help is much appreciated because I'm really stumped.
***EDIT***
I have fixed the startup issue by entering the direct path in regedit but still even after a reboot its the same start orb, I even checked with Reshack the Bitmap>6801>1033 and it showed my created .bmp so why is this happening? is there a specific size for the start orb (perhaps mine is too big?)
***EDIT***
