Caillte
I recently just formatted my harddrive. It went from Windows Vista to Windows 7. When I first installed windows 7, I selected the clean install, but it saved the old files in old.windows. I decided to format the drive and start fresh. Through ALL of these installs, I've had blue screens.
I just install again a few days ago and I've had 4 or 5 BSOD since then.
Attached are the dumb files/SF Diagnostic Tools and CPUID screenshots.
Any help would be appreciated.
Hi Caillte and Welcome to The Forum.
STOP 0x0000000A: IRQL_NOT_LESS_OR_EQUAL
Usual causes:
Kernel mode driver, System Service, BIOS, Windows, Virus scanner, Backup tool, compatibility.
Your latest dump file lists dxgmms1.sys as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
Norton is known to be a cause of BSOD's on many Windows 7 systems. I suggest that you uninstall Norton using the Link Removed in Safe Mode. Download Blue Screen friendly Link Removed due to...
Usual causes:
As a Priority:
Norton is known to be a cause of BSOD's on many Windows 7 systems. I suggest that you uninstall Norton using the Link Removed in Safe Mode. Download Blue Screen friendly Link Removed due to 404 Error as its replacement. Make sure Windows firewall is enabled!
Drivers that pre-date Windows 7. Update:
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with iTunes
HpqKbFiltr.sys Wed Apr 29 14:48:30 2009 HP Quick Launch Buttons Keyboard driver
jmcr.sys Thu Jul 09 13:45:19 2009 Link Removed due to 404 Error
Drivers with Updates:
atikmdag.sys Wed Aug 05 05:14:11 2009 Link Removed
  • Download and install DriverSweeper.
  • Uninstall your current Graphics setup through Programs and Features
  • Boot to (preferably) Safe Mode and run Driver Sweeper to clean up the remnants of your current Graphics set up.
  • Reboot to Normal Mode.
  • Install your new Graphics set up.
Bugcheck Analysis:
BugCheck A, {fffffa0006818bf0, 2, 0, fffff80002c88f35}
Probably caused by : dxgmms1.sys ( dxgmms1!VidSchWaitForEvents+f5 )
Drivers:
fffff880`04a1d000 fffff880`04a2a000   Accelerometer Accelerometer.sys Fri May 13 19:47:02 2011 (4DCD7CA6)
fffff880`00e64000 fffff880`00ebb000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`03e65000 fffff880`03eee000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`0448e000 fffff880`044a4000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`06840000 fffff880`06971000   agrsm64  agrsm64.sys  Thu Aug 13 16:20:43 2009 (4A842F4B)
fffff880`00e35000 fffff880`00e4c000   amd_sata amd_sata.sys Fri Apr 15 19:37:14 2011 (4DA8905A)
fffff880`01131000 fffff880`0113f000   amd_xata amd_xata.sys Fri Apr 15 19:37:17 2011 (4DA8905D)
fffff880`041cc000 fffff880`041e0000   amdiox64 amdiox64.sys Thu Feb 18 15:17:53 2010 (4B7D5A21)
fffff880`04426000 fffff880`0443b000   amdppm   amdppm.sys   Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`0113f000 fffff880`0114a000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`08b71000 fffff880`08b7c000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00fda000 fffff880`00fe3000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e00000 fffff880`00e2a000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`052a9000 fffff880`0554f000   athrx    athrx.sys    Tue Jun 21 09:03:39 2011 (4E00505B)
fffff880`03e43000 fffff880`03e64000   AtihdW76 AtihdW76.sys Thu Mar 31 08:15:43 2011 (4D942A1F)
fffff880`04a4b000 fffff880`05062000   atikmdag atikmdag.sys Wed Aug 05 05:14:11 2009 (4A790713)
fffff880`01846000 fffff880`0184e000   AtiPcie64 AtiPcie64.sys Wed Mar 10 14:33:45 2010 (4B97ADC9)
fffff880`00f2c000 fffff880`00f38000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`01899000 fffff880`018a0000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`044dd000 fffff880`045fc000   BHDrvx64 BHDrvx64.sys Thu Nov 10 00:00:00 2011 (4EBB1400)
fffff880`040d6000 fffff880`040e7000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`0571b000 fffff880`05739000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00720000 fffff960`00747000   cdd      cdd.dll      unavailable (00000000)
fffff880`0168b000 fffff880`016b5000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`041ba000 fffff880`041cc000   circlass circlass.sys Tue Jul 14 01:06:34 2009 (4A5BCC0A)
fffff880`01816000 fffff880`01846000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00cfb000 fffff880`00d59000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`052a1000 fffff880`052a5500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`01200000 fffff880`01272000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`00f23000 fffff880`00f2c000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`04a33000 fffff880`04a43000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`069ce000 fffff880`069dc000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`04035000 fffff880`040b8000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`040b8000 fffff880`040d6000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`04226000 fffff880`04235000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01800000 fffff880`01816000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`066a7000 fffff880`066c9000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`069e6000 fffff880`069fd000   dump_amd_sata dump_amd_sata.sys Fri Apr 15 19:37:14 2011 (4DA8905A)
fffff880`069dc000 fffff880`069e6000   dump_diskdump dump_diskdump.sys Fri Apr 22 21:04:32 2011 (4DB1DF50)
fffff880`06800000 fffff880`06813000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`06782000 fffff880`0678e000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`05062000 fffff880`05156000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`05156000 fffff880`0519c000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0437f000 fffff880`043f8000   eeCtrl64 eeCtrl64.sys Sat Oct 22 02:18:28 2011 (4EA219E4)
fffff880`04a00000 fffff880`04a1d000   enecir   enecir.sys   Wed May 20 07:08:57 2009 (4A139E79)
fffff880`08ae0000 fffff880`08b00000   ENG64    ENG64.SYS    Fri Jul 29 14:17:51 2011 (4E32B2FF)
fffff880`04200000 fffff880`04226000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Sat Oct 22 02:18:29 2011 (4EA219E5)
fffff880`08c03000 fffff880`08dfb000   EX64     EX64.SYS     Fri Jul 29 14:15:11 2011 (4E32B25F)
fffff880`08bc5000 fffff880`08bfb000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`01071000 fffff880`01085000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0114a000 fffff880`01196000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01411000 fffff880`0141b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01bbb000 fffff880`01bf5000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01aae000 fffff880`01af8000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`055e1000 fffff880`055ee000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`031f0000 fffff800`03239000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`0519c000 fffff880`051c0000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`06991000 fffff880`069aa000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`06980000 fffff880`06991000   hidir    hidir.sys    Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`069aa000 fffff880`069b2080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`06830000 fffff880`0683e000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`01bb1000 fffff880`01bbb000   hpdskflt hpdskflt.sys Fri May 13 19:47:02 2011 (4DCD7CA6)
fffff880`05293000 fffff880`0529f000   HpqKbFiltr HpqKbFiltr.sys Wed Apr 29 14:48:30 2009 (49F85AAE)
fffff880`05652000 fffff880`0571b000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01ba8000 fffff880`01bb1000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`05275000 fffff880`05293000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`04302000 fffff880`0437f000   IDSvia64 IDSvia64.sys Wed Jul 20 14:19:46 2011 (4E26D5F2)
fffff880`03e00000 fffff880`03e2d000   Ironx64  Ironx64.SYS  Fri Nov 12 23:06:50 2010 (4CDDC88A)
fffff880`051e0000 fffff880`051ef000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`069b3000 fffff880`069c1000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00bb2000 fffff800`00bbc000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`04177000 fffff880`041ba000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`015d8000 fffff880`015f3000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01660000 fffff880`0168b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`066c9000 fffff880`066ce200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`067e0000 fffff880`067f5000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0679c000 fffff880`067bf000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00cda000 fffff880`00ce7000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`06971000 fffff880`06980000   modem    modem.sys    Tue Jul 14 01:10:48 2009 (4A5BCD08)
fffff880`0678e000 fffff880`0679c000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`051ef000 fffff880`051fe000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`069c1000 fffff880`069ce000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00fc0000 fffff880`00fda000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`05739000 fffff880`05751000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`05751000 fffff880`0577e000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`0577e000 fffff880`057cc000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`057cc000 fffff880`057f0000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`00e2a000 fffff880`00e35000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`0141b000 fffff880`01426000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00ec4000 fffff880`00ece000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0139e000 fffff880`013fc000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`042f7000 fffff880`04302000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01b96000 fffff880`01ba8000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`016e3000 fffff880`017d6000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`044c8000 fffff880`044d4000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`06653000 fffff880`06666000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`040e7000 fffff880`04116000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`04000000 fffff880`04015000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`03f78000 fffff880`03f87000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03eee000 fffff880`03f33000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01600000 fffff880`01660000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`01272000 fffff880`01283000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`042eb000 fffff880`042f7000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02c07000 fffff800`031f0000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01435000 fffff880`015d8000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01890000 fffff880`01899000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`06600000 fffff880`06653000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`03f3c000 fffff880`03f62000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00f0e000 fffff880`00f23000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00ece000 fffff880`00f01000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00fa9000 fffff880`00fb0000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00fb0000 fffff880`00fc0000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01400000 fffff880`01411000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`06ad8000 fffff880`06b7e000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`01085000 fffff880`010c2000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00ce7000 fffff880`00cfb000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`044a4000 fffff880`044c8000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`04116000 fffff880`04131000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04131000 fffff880`04152000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04152000 fffff880`0416c000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`0429a000 fffff880`042eb000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`0416c000 fffff880`04177000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`018a0000 fffff880`018a9000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01bf5000 fffff880`01bfe000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`016d3000 fffff880`016dc000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01b5c000 fffff880`01b96000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`06666000 fffff880`0667e000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0555c000 fffff880`055e1000   Rt64win7 Rt64win7.sys Fri Jun 10 07:33:15 2011 (4DF1BAAB)
fffff880`06d43000 fffff880`06d72000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`06b7e000 fffff880`06b89000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`01b54000 fffff880`01b5c000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`08a20000 fffff880`08ae0000   SRTSP64  SRTSP64.SYS  Wed Mar 30 03:46:12 2011 (4D929974)
fffff880`03e2d000 fffff880`03e43000   SRTSPX64 SRTSPX64.SYS Wed Mar 30 03:46:18 2011 (4D92997A)
fffff880`06c7c000 fffff880`06d14000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`06a00000 fffff880`06a69000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`06b89000 fffff880`06bba000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`010ce000 fffff880`01131000   storport storport.sys Fri Mar 11 04:30:23 2011 (4D79A55F)
fffff880`066cf000 fffff880`06754000   stwrt64  stwrt64.sys  Fri May 27 04:13:43 2011 (4DDF16E7)
fffff880`052a6000 fffff880`052a7480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01000000 fffff880`01071000   SYMDS64  SYMDS64.SYS  Wed Dec 08 00:16:58 2010 (4CFECE7A)
fffff880`012ba000 fffff880`0139e000   SYMEFA64 SYMEFA64.SYS Mon Mar 14 03:20:58 2011 (4D7D899A)
fffff880`03fb6000 fffff880`03fec000   SYMEVENT64x86 SYMEVENT64x86.SYS Thu Mar 24 23:02:36 2011 (4D8BCD8C)
fffff880`01196000 fffff880`011fd000   SYMNETS  SYMNETS.SYS  Tue Apr 19 23:33:31 2011 (4DAE0DBB)
fffff880`0443b000 fffff880`0448e000   SynTP    SynTP.sys    Thu May 27 22:41:36 2010 (4BFEE710)
fffff880`018aa000 fffff880`01aae000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`06bba000 fffff880`06bcc000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01426000 fffff880`01433000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01283000 fffff880`012a5000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`03fa2000 fffff880`03fb6000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`005b0000 fffff960`005ba000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`04400000 fffff880`04426000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`041e0000 fffff880`041f2000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`06813000 fffff880`06830000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`0529f000 fffff880`052a0f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`05264000 fffff880`05275000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`05256000 fffff880`05264000   usbfilter usbfilter.sys Mon Nov 29 09:50:21 2010 (4CF3775D)
fffff880`04235000 fffff880`0428f000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`055ee000 fffff880`055f9000   usbohci  usbohci.sys  Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`05200000 fffff880`05256000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`08baa000 fffff880`08bc5000   USBSTOR  USBSTOR.SYS  Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`08b7c000 fffff880`08ba9280   usbvideo usbvideo.sys Sat Nov 20 10:44:34 2010 (4CE7A692)
fffff880`00f01000 fffff880`00f0e000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`016b5000 fffff880`016c3000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`017d6000 fffff880`017fb000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01af8000 fffff880`01b08000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00f38000 fffff880`00f4d000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00f4d000 fffff880`00fa9000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01b08000 fffff880`01b54000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`0554f000 fffff880`0555c000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`03f62000 fffff880`03f78000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`03f87000 fffff880`03fa2000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`016c3000 fffff880`016d3000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00d59000 fffff880`00dfd000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00cc0000 fffff880`00ccf000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`03f33000 fffff880`03f3c000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000e0000 fffff960`003f4000   win32k   win32k.sys   unavailable (00000000)
fffff880`04a2a000 fffff880`04a33000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00ebb000 fffff880`00ec4000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`067bf000 fffff880`067e0000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`08b00000 fffff880`08b31000   WUDFRd   WUDFRd.sys   Sat Nov 20 10:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`06d14000 fffff880`06d43000   jmcr.sys
    Checksum:  00000000
    ImageSize:  0002F000
fffff880`08b00000 fffff880`08b71000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`06754000 fffff880`06782000   usbvideo.sys
    Checksum:  00000000
    ImageSize:  0002E000
fffff880`051c0000 fffff880`051e0000   sdbus.sys
    Checksum:  00000000
    ImageSize:  00020000
fffff880`0184e000 fffff880`0185c000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0185c000 fffff880`01866000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`01866000 fffff880`0187d000   dump_amd_sat
    Checksum:  00000000
    ImageSize:  00017000
fffff880`0187d000 fffff880`01890000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Going to be doing all of that tonight, hopefully it fixes it! Thank you.
Got another BSOD. After this BSOD, about 15 minutes later, laptop went black, but didn't shut off. It seems to happen most when playing games.
STOP 0x00000050: PAGE_FAULT_IN_NONPAGED_AREA
Usual causes:
Defective hardware (particularly memory - but not just RAM), Faulty system service, Antivirus, Device driver, NTFS corruption, BIOS.
Your latest dump file lists dxgmms1.sys as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely. It is however related to your graphics driver atikmdag.sys which is still dated the same as previously, Wed Aug 05 05:14:11 2009.
Your Bios is also quite old (Aug 2009). Just grabbing a few models at the HP site gave bioses that were all dated 2011. Link Removed All the DV7's have a model number after the name, e.g. dv7-6b05ea. Without knowing your specific model I cannot check for bios, or in fact driver updates. I'd grab every available update for your machine available
I'm trying to reinstall the graphic driver again. It keeps saying it's completed, but apparently it's not. When I went to the HP website I selected every single update there and installed all in the very beginning. The only BIOS file for me to download is the 2009 one.
  • Link Removed - Invalid URL is my laptop.
Okay, I successfully updated the graphics and went almost an entire day without a BSOD, until this morning. Attached file.
STOP 0x00000044: MULTIPLE_IRP_COMPLETE_REQUESTS
Usual causes:
Device driver(s).
Your latest dump file lists CLASSPNP.SYS as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Cause
A driver has called IoCompleteRequest to ask that an IRP be completed, but the packet has already been completed.
Resolving the Problem
This is a tough bug to find because the simplest case — a driver that attempted to complete its own packet twice — is usually not the source of the problem. More likely, two separate drivers each believe that they own the packet, and each has attempted to complete it. The first request succeeds, and the second fails, resulting in this bug check.
Tracking down which drivers in the system caused the error is difficult, because the trail of the first driver has been covered by the second.
As a Priority:
jmcr.sys ???? Link Removed Can we try this again,
enecir.sys Wed May 20 07:08:57 2009 ENE Consumer IR Driver for eHome OEM
We need to run Driver Verifier, see if we can flush the true culprit out.
To start Driver Verifier:
- Create a restore point!!
- GoTo Start and in the Search or a Run... Window type verifier and press Enter.
- Select Create custom settings (for code developers) and click Next.
- Select Select individual settings from a full list and click Next.
- Select every option EXCEPT for Low Resource Simulation and click Next.
- Select Select driver names from a list and click Next.
- Select all drivers listed that are NOT provided by Microsoft and click Next.
- Select Finish on the next page.
Reboot the system and wait for it to crash to the Blue Screen. If this happens as soon as Windows tries to start then try it in Safe Mode. Continue to use your system normally, if you know what causes the crash, do that repeatedly. The objective is to get the system to crash because Driver Verifier is stressing the drivers out and hopefully create a pattern.
On the extremely rare occasion that you can't get into Safe Mode, use System Restore from your installation DVD / Restore Disc to set the system back to the previous restore point that you created.
If it doesn't crash for you, then let it run for at least 36 hours of continuous operation (an estimate on my part).
To turn off Driver Verifier when finished, Open a Command Prompt or Run... window and type verifier /reset and press Enter/OK.
or
GoTo Start and in the Search or a Run... Window type verifier. Select Delete existing settings and press "Finish".
Bugcheck Analysis:
MULTIPLE_IRP_COMPLETE_REQUESTS (44)
Arguments:
Arg1: fffffa8004238270, Address of the IRP
Arg2: 0000000000000eae
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
IRP_ADDRESS:  fffffa8004238270
FOLLOWUP_IP:
CLASSPNP!TransferPktComplete+1ce
fffff880`019aabce 837c243002      cmp     dword ptr [rsp+30h],2
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x44
PROCESS_NAME:  System
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from fffff80002c6a5e0 to fffff80002c80c40
STACK_TEXT:
fffff880`02f22b78 fffff800`02c6a5e0 : 00000000`00000044 fffffa80`04238270 00000000`00000eae 00000000`00000000 : nt!KeBugCheckEx
fffff880`02f22b80 fffff880`019aabce : 00000000`00000001 00000000`00000000 00000000`00000000 fffffa80`0429d700 : nt! ?? ::FNODOBFM::`string'+0x42392
fffff880`02f22c70 fffff800`02c84021 : 00000000`00000000 00000000`00000003 00000000`00000000 00000000`00000000 : CLASSPNP!TransferPktComplete+0x1ce
fffff880`02f22cf0 fffff880`010627d8 : fffff880`037de010 fffffa80`04ba1101 fffffa80`03f597c0 00000000`00000000 : nt!IopfCompleteRequest+0x341
fffff880`02f22de0 fffff880`01062553 : 00000000`00000000 00000000`000000f5 00000000`ffffff80 fffffa80`04b7b060 : storport!RaidUnitCompleteRequest+0x208
fffff880`02f22ec0 fffff800`02c8c0ac : fffff880`009e8180 fffffa80`00000000 fffffa80`04b7b128 00000000`000000e1 : storport!RaidpAdapterDpcRoutine+0x53
fffff880`02f22f00 fffff800`02c83765 : 00000000`00000000 fffffa80`03ce91c0 00000000`00000000 fffff880`01062500 : nt!KiRetireDpcList+0x1bc
fffff880`02f22fb0 fffff800`02c8357c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KyRetireDpcList+0x5
fffff880`009a9a40 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchInterruptContinue
STACK_COMMAND:  kb
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  CLASSPNP!TransferPktComplete+1ce
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: CLASSPNP
IMAGE_NAME:  CLASSPNP.SYS
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7929b
FAILURE_BUCKET_ID:  X64_0x44_CLASSPNP!TransferPktComplete+1ce
Drivers:
fffff880`045e6000 fffff880`045f3000   Accelerometer Accelerometer.sys Fri May 13 19:47:02 2011 (4DCD7CA6)
fffff880`00f15000 fffff880`00f6c000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`03c64000 fffff880`03ced000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`03f75000 fffff880`03f8b000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`05cbe000 fffff880`05def000   agrsm64  agrsm64.sys  Thu Aug 13 16:20:43 2009 (4A842F4B)
fffff880`00dd7000 fffff880`00dee000   amd_sata amd_sata.sys Fri Apr 15 19:37:14 2011 (4DA8905A)
fffff880`010c3000 fffff880`010d1000   amd_xata amd_xata.sys Fri Apr 15 19:37:17 2011 (4DA8905D)
fffff880`05117000 fffff880`0512b000   amdiox64 amdiox64.sys Thu Feb 18 15:17:53 2010 (4B7D5A21)
fffff880`03f31000 fffff880`03f46000   amdppm   amdppm.sys   Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`010d1000 fffff880`010dc000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`06597000 fffff880`065a2000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00d99000 fffff880`00da2000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00da2000 fffff880`00dcc000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`0420a000 fffff880`044b0000   athrx    athrx.sys    Tue Jun 21 09:03:39 2011 (4E00505B)
fffff880`051ac000 fffff880`051c6000   AtihdW76 AtihdW76.sys Tue Oct 18 08:09:49 2011 (4E9D263D)
fffff880`048a3000 fffff880`04ede000   atikmdag atikmdag.sys Wed Sep 23 23:55:17 2009 (4ABAA755)
fffff880`019d9000 fffff880`019e1000   AtiPcie64 AtiPcie64.sys Wed Mar 10 14:33:45 2010 (4B97ADC9)
fffff880`00fdd000 fffff880`00fe9000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`01633000 fffff880`0163a000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03efa000 fffff880`03f0b000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`019e1000 fffff880`019ff000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`00710000 fffff960`00737000   cdd      cdd.dll      unavailable (00000000)
fffff880`0119a000 fffff880`011c4000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00ca8000 fffff880`00d68000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`05105000 fffff880`05117000   circlass circlass.sys Tue Jul 14 01:06:34 2009 (4A5BCC0A)
fffff880`019a9000 fffff880`019d9000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00c4a000 fffff880`00ca8000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`045e1000 fffff880`045e5500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`014f7000 fffff880`01569000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`00fd4000 fffff880`00fdd000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`04fef000 fffff880`04fff000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`0508c000 fffff880`0509a000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`03e59000 fffff880`03edc000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`03edc000 fffff880`03efa000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`03dc0000 fffff880`03dcf000   discache discache.sys unavailable (00000000)
fffff880`01993000 fffff880`019a9000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0503d000 fffff880`0505f000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`050a4000 fffff880`050bb000   dump_amd_sata dump_amd_sata.sys Fri Apr 15 19:37:14 2011 (4DA8905A)
fffff880`0509a000 fffff880`050a4000   dump_diskdump dump_diskdump.sys Fri Apr 22 21:04:32 2011 (4DB1DF50)
fffff880`051c6000 fffff880`051d9000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`05080000 fffff880`0508c000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`04ede000 fffff880`04fd2000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04800000 fffff880`04846000   dxgmms1  dxgmms1.sys  unavailable (00000000)
fffff880`04fd2000 fffff880`04fef000   enecir   enecir.sys   Wed May 20 07:08:57 2009 (4A139E79)
fffff880`01128000 fffff880`0113c000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`010dc000 fffff880`01128000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0157a000 fffff880`01584000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01959000 fffff880`01993000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`0184c000 fffff880`01896000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`044bd000 fffff880`044c3b80   GEARAspiWDM GEARAspiWDM.sys Mon May 16 21:56:05 2011 (4DD18F65)
fffff800`031ed000 fffff800`03236000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`04846000 fffff880`0486a000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`05c11000 fffff880`05c2a000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05c00000 fffff880`05c11000   hidir    hidir.sys    Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`05c2a000 fffff880`05c32080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`03dcf000 fffff880`03ddd000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0194f000 fffff880`01959000   hpdskflt hpdskflt.sys Fri May 13 19:47:02 2011 (4DCD7CA6)
fffff880`04562000 fffff880`0456e000   HpqKbFiltr HpqKbFiltr.sys Wed Apr 29 14:48:30 2009 (49F85AAE)
fffff880`02418000 fffff880`024e1000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01946000 fffff880`0194f000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`04544000 fffff880`04562000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0456e000 fffff880`0457d000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05065000 fffff880`05073000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00b98000 fffff800`00ba2000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`050c2000 fffff880`05105000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013ac000 fffff880`013c7000   ksecdd   ksecdd.sys   unavailable (00000000)
fffff880`013c7000 fffff880`013f2000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`0505f000 fffff880`05064200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`0256f000 fffff880`02584000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0252b000 fffff880`0254e000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c29000 fffff880`00c36000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`05def000 fffff880`05dfe000   modem    modem.sys    Tue Jul 14 01:10:48 2009 (4A5BCD08)
fffff880`065d6000 fffff880`065e4000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`045d2000 fffff880`045e1000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05073000 fffff880`05080000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00d7f000 fffff880`00d99000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`011c4000 fffff880`011f5000   MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`024e1000 fffff880`024f9000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`05450000 fffff880`0547d000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`0547d000 fffff880`054cb000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`054cb000 fffff880`054ef000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`00dcc000 fffff880`00dd7000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`01025000 fffff880`01030000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f75000 fffff880`00f7f000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0113c000 fffff880`0119a000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`03db5000 fffff880`03dc0000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01934000 fffff880`01946000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01400000 fffff880`014f3000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`03faf000 fffff880`03fbb000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`025d7000 fffff880`025ea000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`03fbb000 fffff880`03fea000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`05197000 fffff880`051ac000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`03d77000 fffff880`03d86000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03ced000 fffff880`03d32000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01584000 fffff880`015e4000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`0650e000 fffff880`06526000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`01030000 fffff880`01041000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03c51000 fffff880`03c5d000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02c04000 fffff800`031ed000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01209000 fffff880`013ac000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`0162a000 fffff880`01633000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`02584000 fffff880`025d7000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`03d3b000 fffff880`03d61000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00fbf000 fffff880`00fd4000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f7f000 fffff880`00fb2000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00d68000 fffff880`00d6f000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00d6f000 fffff880`00d7f000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01569000 fffff880`0157a000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`054ef000 fffff880`05595000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`05000000 fffff880`0503d000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c36000 fffff880`00c4a000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`03f8b000 fffff880`03faf000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`03e00000 fffff880`03e1b000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`03e1b000 fffff880`03e3c000   raspptp  raspptp.sys  unavailable (00000000)
fffff880`03e3c000 fffff880`03e56000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03c00000 fffff880`03c51000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`03fea000 fffff880`03ff5000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`015f4000 fffff880`015fd000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`013f2000 fffff880`013fb000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01200000 fffff880`01209000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`018fa000 fffff880`01934000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`02400000 fffff880`02418000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`03f46000 fffff880`03f75000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`05595000 fffff880`055a0000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`018f2000 fffff880`018fa000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`06476000 fffff880`0650e000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`0640d000 fffff880`06476000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`055a0000 fffff880`055d1000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`01060000 fffff880`010c3000   storport storport.sys Fri Mar 11 04:30:23 2011 (4D79A55F)
fffff880`05c39000 fffff880`05cbe000   stwrt64  stwrt64.sys  Fri May 27 04:13:43 2011 (4DDF16E7)
fffff880`045fc000 fffff880`045fd480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0457d000 fffff880`045d0000   SynTP    SynTP.sys    Thu May 27 22:41:36 2010 (4BFEE710)
fffff880`01648000 fffff880`0184c000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`055d1000 fffff880`055e3000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01041000 fffff880`0104e000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`00c00000 fffff880`00c22000   tdx      tdx.sys      unavailable (00000000)
fffff880`03da1000 fffff880`03db5000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`005f0000 fffff960`005fa000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03f0b000 fffff880`03f31000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`0512b000 fffff880`0513d000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`051d9000 fffff880`051f6000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`045d0000 fffff880`045d1f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`04533000 fffff880`04544000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04525000 fffff880`04533000   usbfilter usbfilter.sys Mon Nov 29 09:50:21 2010 (4CF3775D)
fffff880`0513d000 fffff880`05197000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`044c4000 fffff880`044cf000   usbohci  usbohci.sys  Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`044cf000 fffff880`04525000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`024fd000 fffff880`0252a280   usbvideo usbvideo.sys Sat Nov 20 10:44:34 2010 (4CE7A692)
fffff880`00fb2000 fffff880`00fbf000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`0163a000 fffff880`01648000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01000000 fffff880`01025000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01896000 fffff880`018a6000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00fe9000 fffff880`00ffe000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`018a6000 fffff880`018f2000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`044b0000 fffff880`044bd000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`03d61000 fffff880`03d77000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`03d86000 fffff880`03da1000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`015e4000 fffff880`015f4000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e62000 fffff880`00f06000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f06000 fffff880`00f15000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`03d32000 fffff880`03d3b000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`000d0000 fffff960`003e4000   win32k   win32k.sys   unavailable (00000000)
fffff880`045f3000 fffff880`045fc000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f6c000 fffff880`00f75000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`0254e000 fffff880`0256f000   WudfPf   WudfPf.sys   unavailable (00000000)
Unloaded modules:
fffff880`065a2000 fffff880`065ac000   hiber_storpo
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`065ac000 fffff880`065c3000   hiber_amd_sa
    Checksum:  00000000
    ImageSize:  00017000
fffff880`065c3000 fffff880`065d6000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`03ddd000 fffff880`03deb000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`06526000 fffff880`06597000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0486a000 fffff880`04899000   jmcr.sys
    Checksum:  00000000
    ImageSize:  0002F000
fffff880`019e1000 fffff880`019ef000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`019ef000 fffff880`019f9000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`01600000 fffff880`01617000   dump_amd_sat
    Checksum:  00000000
    ImageSize:  00017000
fffff880`01617000 fffff880`0162a000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
HTH.
Okay, so far I haven't gotten any BSOD, BUT the laptop has shut off 3 times since I did the driver verifier.
The first time the screen froze and a bunch of horizontal white lines showed up. (World of warcraft was running)
Second time the screen froze. Had to manually restart. (Burning a dvd)
Third time the screen froze with a loud static/grinding noise. (Watching a video online)
Each time, it does not create a dump file.
Also, thank you for the driver update. Driver scan wasn't picking that one up as a needed update.
If you're OK with DV for up to say 24 hours, can you cope? If it becomes a pain, turn it off.
I would've expected at least one true crash by now.
I'll be sure to leave it on for at least 24 hours, hopefully some pattern emerges.
Still no BSOD. Just two more frozen screens. After the first time, the screen went back to normal and I got the typical pop up from the taskbar. This one: (hopefully it's bigger when clicked on) Link Removed
Just a few minutes after posting this the screen froze once more. Had to restart it. Then I got a BSOD. Attached:
Ok, That has a stop 19: Device Driver. Hardly surprising as Driver Verifier is enabled! What is surprising is the fact its blaming a base Windows system file.
Turn off driver verifier. Its served its purpose, as in, done diddly squat to help us! :D
or
GoTo Start and in the Search or a Run... Window type verifier. Select Delete existing settings and press Finish.
Fancy stressing your video card out?
Link Removed I love the way the title is in a flame font :)
Download GPU-z so you can monitor the cards temperatures.
With what you've been saying (freezes etc.) I'm pretty sure it's all graphics related, although I sometimes get "tunnel vision" and can't see the wood for the trees. Just saddened that DV didn't crash your pc.
Alright, its going and logging the info. Don't think my laptop has ever been this slow lol.
What am I looking for with this?
Are you still running it? After an hour? Did your screen go "Wonkey Donkey", or did it over heat at all?
A drastic example of "Wonkey Donkey". Possibly better known as artefacts.
Well, I'm impressed! usually a 30 minute run will suffice to show if problems may be present. But the longer you are prepared to run it the better. As I'm typing this I'm guessing at 90minutes? Give it two hours then you can stop. I think then we'll be very confident when we say "not the graphics card".
(Elmer now starts scratching head)
Just been through your dump files again. As of the last few your drivers are looking good.
When you've finished with Furmark, can you run sfc /scannow just to make sure your system files integrities are OK. Should've suggested that earlier, but I'm old. And senile. And don't agree :).
Then we'll give it say a day see if you crash and collect all the dump files. Then can you test your ram with Memtest?
I'm getting a bit miffed now! If we don't resolve this I personally will come and throw your laptop out the window and give you another one!! (call me Late Santa Elmer :D)
And could you fill in your system specs under your user profile? Anybody else who pops in for a quick look won't be prepared to trawl for info (not meant in a nasty way) so if it's all to hand, makes life so much easier all round. See: Link Removed (System specs show as a black monitor in the bottom bar on the left of your posts).
At this speed I'll be forwarding your name as a moderator before this gets resolved!
It finished after a little over two hours, or well I turned it off. Still nothing happened. Laptop didn't even get hot to the touch like it does when playing world of warcraft.
I did get a BSOD after about.... 15 minutes of playing warcraft though, sadly it didn't create a dumpfile for some reason.
Will run scan now/mem test and fill in the missing areas of the system info.
Oh believe me, I've often thought about taking a hammer to it. But as my husband likes to tell me, that won't solve anything. Personally, it will solve the annoyance!
