I'm not sure what the problem is. I'm hoping you guys can help me once again
View attachment 5.31.11 BSOD.zip
* Bugcheck Analysis *
UNEXPECTED_KERNEL_MODE_TRAP (7f)
This means a trap occurred in kernel mode, and it's a trap of a kind
that the kernel isn't allowed to have/catch (bound trap) or that
is always instant death (double fault). The first number in the
bugcheck params is the number of the trap (8 = double fault, etc)
Consult an Intel x86 family manual to learn more about what these
traps are. Here is a *portion* of those codes:
If kv shows a taskGate
use .tss on the part before the colon, then kv.
Else if kv shows a trapframe
use .trap on that value
Else
.trap on the appropriate frame will show where the trap was taken
(on x86, this will be the ebp that goes with the procedure KiTrap)
Endif
kb will then show the corrected stack.
Arguments:
Arg1: 0000000000000008, EXCEPTION_DOUBLE_FAULT
Arg2: 0000000080050033
Arg3: 00000000000006f8
Arg4: fffff80002ca707c
Debugging Details:
BUGCHECK_STR: 0x7f_8
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: CODE_CORRUPTION
PROCESS_NAME: svchost.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff80002cca2a9 to fffff80002ccad00
STACK_TEXT:
fffff800`00ba4d28 fffff800`02cca2a9 : 00000000`0000007f 00000000`00000008 00000000`80050033 00000000`000006f8 : nt!KeBugCheckEx
fffff800`00ba4d30 fffff800`02cc8772 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff800`00ba4e70 fffff800`02ca707c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDoubleFaultAbort+0xb2
00000000`9305ead2 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!EtwpEventWriteFull+0x2a8
STACK_COMMAND: kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !nt
fffff80002ca7120 - nt!EtwpEventWriteFull+34c
[ 6f:4f ]
1 error : !nt (fffff80002ca7120)
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
FOLLOWUP_NAME: memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MEMORY_CORRUPTOR: ONE_BIT
FAILURE_BUCKET_ID: X64_MEMORY_CORRUPTION_ONE_BIT
Followup: memory_corruption
start end module name
fffff800`00bc0000 fffff800`00bca000 kdcom kdcom.dll Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff800`02c02000 fffff800`02c4b000 hal hal.dll Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff800`02c4b000 fffff800`03234000 nt ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff880`00c3e000 fffff880`00c8d000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`00c8d000 fffff880`00ca1000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00ca1000 fffff880`00cff000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00cff000 fffff880`00dbf000 CI CI.dll Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`00e39000 fffff880`00edd000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00edd000 fffff880`00eec000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00eec000 fffff880`00f43000 ACPI ACPI.sys Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`00f43000 fffff880`00f4c000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00f4c000 fffff880`00f56000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`00f56000 fffff880`00f89000 pci pci.sys Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00f89000 fffff880`00f96000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00f96000 fffff880`00fab000 partmgr partmgr.sys Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00fab000 fffff880`00fc0000 volmgr volmgr.sys Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`01000000 fffff880`01072000 cng cng.sys Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`01072000 fffff880`010bd000 aswSP aswSP.SYS Wed Feb 23 14:57:02 2011 (4D65203E)
fffff880`010f5000 fffff880`01151000 volmgrx volmgrx.sys Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01151000 fffff880`0116b000 mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`0116b000 fffff880`011c9000 msrpc msrpc.sys Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`01200000 fffff880`0122a000 ataport ataport.SYS Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`0122a000 fffff880`01235000 msahci msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`01235000 fffff880`01245000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01245000 fffff880`01250000 amdxata amdxata.sys Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`01250000 fffff880`0129c000 fltmgr fltmgr.sys Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`0129c000 fffff880`012b0000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`012ce000 fffff880`013ea000 iaStor iaStor.sys Fri Jun 05 02:53:40 2009 (4A287AA4)
fffff880`013ea000 fffff880`013f3000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01403000 fffff880`015a6000 Ntfs Ntfs.sys Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`015a6000 fffff880`015c1000 ksecdd ksecdd.sys Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`015c1000 fffff880`015d2000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`015d2000 fffff880`015dc000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`015dc000 fffff880`015f6c80 usbaudio usbaudio.sys Sat Nov 20 10:43:52 2010 (4CE7A668)
fffff880`01600000 fffff880`01616000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`01617000 fffff880`0170a000 ndis ndis.sys Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`0170a000 fffff880`0176a000 NETIO NETIO.SYS Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`0176a000 fffff880`01795000 ksecpkg ksecpkg.sys Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`01795000 fffff880`017a6000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`017a6000 fffff880`017c8000 tdx tdx.sys Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`017c8000 fffff880`017d8000 aswTdi aswTdi.SYS Wed Feb 23 14:55:51 2011 (4D651FF7)
fffff880`017d8000 fffff880`017fe000 tunnel tunnel.sys Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`01800000 fffff880`01825000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01825000 fffff880`01835000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`01835000 fffff880`0183e000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0183e000 fffff880`01847000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01847000 fffff880`01850000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01850000 fffff880`0185b000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0185d000 fffff880`01a61000 tcpip tcpip.sys Sat Nov 20 09:25:52 2010 (4CE79420)
fffff880`01a61000 fffff880`01aab000 fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`01aab000 fffff880`01af7000 volsnap volsnap.sys Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`01af7000 fffff880`01aff000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`01aff000 fffff880`01b39000 rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`01b39000 fffff880`01b4b000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01b4b000 fffff880`01b54000 hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`01b54000 fffff880`01b8e000 fvevol fvevol.sys Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01b8e000 fffff880`01ba4000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01ba4000 fffff880`01bd4000 CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`01be2000 fffff880`01bf0000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`01bf0000 fffff880`01bfd000 TDI TDI.SYS Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`02c00000 fffff880`02c3a000 aswMonFlt aswMonFlt.sys Wed Feb 23 14:55:04 2011 (4D651FC8)
fffff880`02c3a000 fffff880`02c43000 aswFsBlk aswFsBlk.SYS Wed Feb 23 14:54:56 2011 (4D651FC0)
fffff880`02c43000 fffff880`02c64000 WudfPf WudfPf.sys Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`02c64000 fffff880`02c79000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`02c79000 fffff880`02c91000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`02cff000 fffff880`02d50d00 lvrs64 lvrs64.sys Fri Apr 01 06:01:39 2011 (4D955C33)
fffff880`02d51000 fffff880`02d5f000 kbdhid kbdhid.sys Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff880`02d5f000 fffff880`02d6c000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`02d6c000 fffff880`02d92000 RzSynapse RzSynapse.sys Wed Dec 15 10:32:19 2010 (4D089933)
fffff880`02d92000 fffff880`02dad000 USBSTOR USBSTOR.SYS Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`02dad000 fffff880`02dd0000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`02e00000 fffff880`02e80000 aswSnx aswSnx.SYS Wed Feb 23 14:56:59 2011 (4D65203B)
fffff880`02e80000 fffff880`02f9c000 dump_iaStor dump_iaStor.sys Fri Jun 05 02:53:40 2009 (4A287AA4)
fffff880`02fb0000 fffff880`02fda000 cdrom cdrom.sys Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`02fda000 fffff880`02fe3000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`02fe3000 fffff880`02fea000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`02fea000 fffff880`02ff9000 SBREdrv SBREdrv.sys Mon Mar 22 14:54:10 2010 (4BA78492)
fffff880`04200000 fffff880`04221000 raspptp raspptp.sys Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04221000 fffff880`04229080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`0422e000 fffff880`04284000 USBPORT USBPORT.SYS Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`04284000 fffff880`04295000 usbehci usbehci.sys Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04295000 fffff880`042dd000 k57nd60a k57nd60a.sys Sun Apr 26 12:23:05 2009 (49F44419)
fffff880`042dd000 fffff880`0431b000 1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`0431b000 fffff880`04328000 fdc fdc.sys Tue Jul 14 01:00:54 2009 (4A5BCAB6)
fffff880`04328000 fffff880`04337880 intelsmb intelsmb.sys Wed May 13 08:31:00 2009 (4A0A7734)
fffff880`04338000 fffff880`04341000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`04341000 fffff880`04351000 CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`04351000 fffff880`04367000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`04367000 fffff880`0438b000 rasl2tp rasl2tp.sys Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`0438b000 fffff880`04397000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`04397000 fffff880`043c6000 ndiswan ndiswan.sys Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`043c6000 fffff880`043e1000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`043e1000 fffff880`043fb000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`043fb000 fffff880`043fc480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`04600000 fffff880`04651000 rdbss rdbss.sys Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`04651000 fffff880`0465d000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff880`0465d000 fffff880`04668000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`04668000 fffff880`04677000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`04677000 fffff880`04680000 easytthr easytthr.sys Sun Aug 29 15:10:54 2010 (4C7A6A6E)
fffff880`0468a000 fffff880`04713000 afd afd.sys Sat Nov 20 09:23:27 2010 (4CE7938F)
fffff880`04713000 fffff880`0471d000 aswRdr aswRdr.SYS Wed Feb 23 14:55:11 2011 (4D651FCF)
fffff880`0471d000 fffff880`04762000 netbt netbt.sys Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`04762000 fffff880`0476b000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`0476b000 fffff880`04791000 pacer pacer.sys Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`04791000 fffff880`047a0000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`047a0000 fffff880`047bb000 wanarp wanarp.sys Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`047bb000 fffff880`047cf000 termdd termdd.sys Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`047cf000 fffff880`047ed000 dfsc dfsc.sys Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`047ed000 fffff880`047fe000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`04a00000 fffff880`04a46000 dxgmms1 dxgmms1.sys Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`04a46000 fffff880`04a6a000 HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`04a6a000 fffff880`04a77000 usbuhci usbuhci.sys Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`04a77000 fffff880`04a86000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04a86000 fffff880`04a95000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04a95000 fffff880`04a99300 lvbflt64 lvbflt64.sys Fri Apr 01 06:01:07 2011 (4D955C13)
fffff880`04a9a000 fffff880`050d3000 atikmdag atikmdag.sys Sat Sep 19 03:44:52 2009 (4AB445A4)
fffff880`050d3000 fffff880`051c7000 dxgkrnl dxgkrnl.sys Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`051c7000 fffff880`051d1000 mio mio.sys Wed Oct 13 16:32:10 2010 (4CB5D0FA)
fffff880`051d1000 fffff880`051df000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`051df000 fffff880`051fc000 usbccgp usbccgp.sys Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`05200000 fffff880`0525c000 HdAudio HdAudio.sys Sat Nov 20 10:44:23 2010 (4CE7A687)
fffff880`0525c000 fffff880`05268000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`05268000 fffff880`05276000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`05276000 fffff880`05289000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0528d000 fffff880`052d0000 ks ks.sys Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`052d0000 fffff880`052e2000 umbus umbus.sys Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`052e2000 fffff880`0533c000 usbhub usbhub.sys Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`0533c000 fffff880`05351000 NDProxy NDProxy.SYS Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`05351000 fffff880`05372000 AtiHdmi AtiHdmi.sys Sun Aug 23 13:35:11 2009 (4A91377F)
fffff880`05372000 fffff880`053af000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`053af000 fffff880`053d1000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`053d1000 fffff880`053d6200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`053d7000 fffff880`053e5000 hidusb hidusb.sys Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`053e5000 fffff880`053fe000 HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`053fe000 fffff880`053fff00 USBD USBD.SYS Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`06004000 fffff880`06400000 lvuvc64 lvuvc64.sys Fri Apr 01 06:02:12 2011 (4D955C54)
fffff880`07800000 fffff880`0784d000 mrxsmb10 mrxsmb10.sys Wed Feb 23 04:55:12 2011 (4D649330)
fffff880`0784d000 fffff880`07871000 mrxsmb20 mrxsmb20.sys Wed Feb 23 04:55:12 2011 (4D649330)
fffff880`07871000 fffff880`0787a000 cpuz135_x64 cpuz135_x64.sys Tue Nov 09 13:33:36 2010 (4CD94DB0)
fffff880`0787a000 fffff880`07884000 IOCBIOS IOCBIOS.SYS Thu Jul 09 18:47:22 2009 (4A562D2A)
fffff880`078a8000 fffff880`07971000 HTTP HTTP.sys Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`07971000 fffff880`0798f000 bowser bowser.sys Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`0798f000 fffff880`079a7000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`079a7000 fffff880`079d4000 mrxsmb mrxsmb.sys Wed Feb 23 04:56:22 2011 (4D649376)
fffff880`0827f000 fffff880`08325000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`08325000 fffff880`08330000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`08330000 fffff880`08361000 srvnet srvnet.sys Wed Feb 23 04:55:44 2011 (4D649350)
fffff880`08361000 fffff880`08373000 tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`08373000 fffff880`083dd000 srv2 srv2.sys Wed Feb 23 04:56:00 2011 (4D649360)
fffff880`08aa8000 fffff880`08b40000 srv srv.sys Wed Feb 23 04:56:21 2011 (4D649375)
fffff880`08b40000 fffff880`08b71000 WUDFRd WUDFRd.sys Sat Nov 20 10:43:32 2010 (4CE7A654)
fffff960`00090000 fffff960`003a2000 win32k win32k.sys Thu Mar 03 03:51:40 2011 (4D6F104C)
fffff960`00510000 fffff960`0051a000 TSDDD TSDDD.dll Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff960`006c0000 fffff960`006e7000 cdd cdd.dll unavailable (00000000)
Unloaded modules:
fffff880`01bd4000 fffff880`01be2000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`02e81000 fffff880`02f9d000 dump_iaStor.
Checksum: 00000000
ImageSize: 0011C000
fffff880`02f9d000 fffff880`02fb0000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
