Fixing Ready or Not Crashes on PC: Causes and Solutions
Ready or Not crashing on PC is more than just a minor glitch—it can turn an intense tactical simulation into a frustrating experience. Players have reported random crashes during gameplay even after updating the game, and if you're stuck in this loop, you're not alone. While VOID Interactive has yet to officially address the issue, there are several workarounds you can try to keep your mission on track. Let’s break down the possible causes and potential fixes, and see what you can do to restore peace to your gaming sessions.
Understanding the Crashing Conundrum​
Modern PC games, especially those rooted in realism like Ready or Not, demand a reliable environment. When crashes occur unexpectedly, it disrupts the immersion and raises the question: What’s really causing the problem? Here are some factors that might be contributing:
  • Corrupt Game Files: Sometimes, either an incomplete update or a corrupted file can trigger instability.
  • Background Interference: Running too many applications simultaneously might conflict with your game’s processes.
  • Software Conflicts: Anti-virus programs, while essential for security, can interfere with game functionality.
  • Hardware or Driver Issues: Outdated graphics drivers or other hardware-related conflicts might be the underlying culprits.
Each of these reasons can lead to the unsettling experience of crashing in the midst of a planning operation. Let’s explore how you can address these issues.
Quick Fixes to Get You Back in the Game​
While there’s no one-size-fits-all cure for this issue, the following workarounds have shown promise for many Windows users:
1. Shut Down Background Applications​
Running applications in the background may seem harmless, but they can hog your PC’s resources or even conflict with Ready or Not’s processes.
  • Steps to Disable Unnecessary Background Apps:
    • Click on the Windows search bar in the taskbar and type “Settings.”
    • Once the Settings window opens, navigate to the “Apps” section.
    • From the list of installed applications, select the ones you suspect might be problematic.
    • Head to the “Background Apps Permissions” tab.
    • Change the setting to “Never” allow the app to run in the background.
By reducing the number of active applications, you can free up system resources and potentially prevent random game crashes.
2. Adjust Your Anti-Virus Settings​
Anti-virus software is crucial for system security, but sometimes it can act a little too zealously. In some cases, your anti-virus might falsely identify Ready or Not processes as threats, leading to interruptions.
  • Steps to Temporarily Disable Your Anti-Virus:
    • Locate your anti-virus icon on the Windows taskbar.
    • Right-click and choose the option to temporarily disable real-time protection.
    • Launch Ready or Not. If the game runs smoothly, add an exception for the game’s installation folder (typically found in C:\Program Files (x86)\Steam\steamapps\common\Ready Or Not).
    • Remember to re-enable your anti-virus once you confirm the game is stable.
This small tweak can prevent overzealous security software from interfering with your game’s execution.
3. Run the Game as an Administrator​
Sometimes, simply changing how your application runs can bypass underlying permission issues that lead to crashes.
  • How to Run Ready or Not with Admin Rights:
    • Open File Explorer and navigate to the game’s installation folder (usually located at C:\Program Files (x86)\Steam\steamapps\common\Ready Or Not).
    • Right-click on the game’s executable file.
    • Select “Properties” and then go to the “Compatibility” tab.
    • Check the box that says “Run this program as an administrator.”
    • Apply the change and relaunch the game.
Running as an administrator ensures that Ready or Not has all the permissions it needs—potentially sidestepping crashes caused by restricted access.
Additional Considerations and Expert Tips​
While the above fixes are often effective, here are a few more suggestions to keep in mind:
  • Verify Game Integrity: Use the game’s client (like Steam) to verify and repair game files. This process can replace any corrupt files with fresh copies.
  • Update Drivers: Ensure that your graphics and other essential device drivers are up to date. Manufacturers often release updates that improve compatibility and performance with new game releases.
  • Adjust In-Game Settings: Lowering graphics settings or disabling certain advanced effects might reduce the load on your system, contributing to a smoother gaming experience.
  • Check for Windows Updates: Sometimes, system-level updates fix underlying issues that could be affecting your game performance.
It’s important to note that these are workarounds rather than guaranteed solutions. Every PC configuration is unique, and what fixes the problem for one user might not work for another. Nonetheless, if you’re experiencing repeated crashes, these steps are a good place to start.
The Bigger Picture: Troubleshooting in a Changing Environment​
PC gaming is inherently complex. As games continue to push the boundaries of realism and immersion, they also expose the varying configurations and potential vulnerabilities within players' systems. Gaming issues like the Ready or Not crashing error remind us that even the latest updates and technological advancements aren’t immune to hiccups.
In broader terms, these problems highlight the need for robust testing and frequent communication between developers and the gaming community. While the current scenario shows that VOID Interactive has not yet addressed the reported crashes, community-driven fixes like these become essential. They empower players to troubleshoot independently while urging developers to prioritize these issues in subsequent patches.
A Few Rhetorical Pointers:​
  • Ever wondered why your meticulously updated system still throws a tantrum? Sometimes, the real cause is hidden in plain sight among background apps and overzealous security software.
  • Could a missed driver update be the silent saboteur of your gaming experience? Absolutely—keeping your system optimized is as crucial as the latest game patch.
In Conclusion​
The Ready or Not crashing on PC error isn’t just a minor annoyance—it’s a reminder that even in today’s advanced tech landscape, small issues can lead to big disruptions. By systematically addressing potential causes such as background apps, anti-virus conflicts, and permission issues, you stand a good chance of mitigating these crashes.
While these fixes serve as temporary workarounds, they also underscore the importance of community feedback and proactive troubleshooting. As you implement these steps, keep a close eye on official updates from VOID Interactive, and don’t hesitate to share your findings on WindowsForum.com, where fellow users and experts can offer further insights.
Stay tuned for more in-depth articles on troubleshooting Windows issues and the latest updates in the tech world—because every gamer deserves an uninterrupted mission briefing.
Happy troubleshooting, and may your operations run without a hitch!
Source: Sportskeeda Ready or Not crashing on PC error: Possible reasons and fixes
