Lottario
- Joined
- Mar 2, 2013
- Messages
- 6
- Thread Author
- #1
Hey everyone,
A while back I connected my laptop (running 64-bit Windows 7, if that matters) via Bluetooth to my girlfriend's Macbook (which she no longer has, hopefully that doesn't matter) to send some pictures to her. Since then, her Macbook has appeared under the Computer screen for me. I would like to get rid of it, but I can't figure out how.
If I double click on it, nothing happens, and if I right click, I only get three options, Open (doesn't do anything), Open in New Window (doesn't do anything), and Create Shortcut.
When selected, a properties button appears next to System Properties, but if I click on it, I get the error message "The properties for this item are not available". The title bar for that error says "Desktop" instead of the name of the Macbook, if that means anything.
In searching around the internet, I found that this may have been caused by the device still existing in either Device Manager, or my Bluetooth devices list. While it wasn't under Device Manager, I did manage to find it under Bluetooth devices, and remove it. This, however, didn't fix the problem.
I also saw it suggested that cleaning the registry could possibly remove it, so I tried that using CCleaner, but still no luck. I've completely run out of ideas, and can't seem to find anything else on it, so I was hoping someone here might know how to stop this Macbook from showing up for me.
Thanks very much in advance!
EDIT: I've attached a screenshot of the problem to better illustrate what I'm talking about.
