Windows 7 Found a fix for IE8 not obtaining IP.......so far!!
makroman
Ok, i just replied to "cant obtain Ip" several minutes ago. Well, thinking to myself as some stated that they drank and fixed issue...LOL i thought lets quit trying the obvious and do soemthing off the wall.
Here is what I did: open IE>tools>internet options>connections tab>Lan settings
Ok, It should be set to automatically detect settings since I use Road Runner, righ? It does obtain an IP through DHCP?
I Unchecked "Automatically detect swttings"
I then checked "Use automatic configuration script"....then closed the browser
Re-opened IE and WOW! to my surprise a beautiful Homepage Appeared!
I went back into the Lan settings and nothing is checked now. I havent checked "Automatically detect settings again , but I wonder what will happen............???
Ok, I did change the settings back to automatically detect and it works! The wierd thing was, I had a window pop-up as if I just installed IE8 for the first time......hmmm? I believe that when this came up the first time when I intalled Windows 7,I chose to do it later. But I went ahead and chose to do it Now this time. Could this be where MS needs to do some bug fixing? have others done the same as I did?
Hey Microsoft......I helped you, where noone has seemed to fix this issue.....I just got laid-off from my job and can use some cash......how about it? Email me, lets talk. Come on now, throw me a few bones! I dont need much, just enough to get by on. A JOB would be cool too!
loathe
its strange huh. i posted something similar earlier, it seems by just opening the lan settings menu it fixes it. ive had to do this a couple of times now.
Top Bottom
