I’ve used four simple, built‑in Windows 11 tweaks to bring sluggish machines back to life — no third‑party cleaners, no registry hacks, no risky downloads — and you can apply the same steps in 10–15 minutes to make your laptop or desktop feel noticeably snappier.
Background / Overview
Windows 11 ships with more polished visuals and background services than earlier releases, and while that improves usability and aesthetics, it also increases the number of subsystems competing for CPU, GPU and storage I/O. Over time, installs, background apps, drivers and temporary files accumulate and can make a system feel slower than it did on day one. The four adjustments outlined below —
disabling visual effects,
choosing a higher power mode,
cleaning and maintaining storage, and
temporarily prioritizing a foreground app — are reversible, low‑risk changes that address the most common software bottlenecks without new hardware. These moves mirror the recommendations in the practical Pocket‑lint checklist and community maintenance guides.
This article explains each change, shows exactly where to find the controls in Windows 11, verifies the claims against Microsoft and independent documentation, and highlights when each tweak helps most and when it can backfire.
Why these four tweaks matter
- They target the components that most commonly cause a subjective slowdown: UI rendering, power throttling, storage congestion, and scheduler fairness.
- Each tweak is built into Windows 11 and reversible — no permanent changes.
- The biggest real‑world gains often come from storage cleanup and reducing background tasks; a faster power plan and fewer animations make the system feel more responsive immediately.
Disable visual effects
What this fixes
Windows 11 brings translucency, blur, animated transitions and other effects that look great but use GPU cycles and CPU time for compositing and animation. On integrated‑graphics laptops or older machines, those costs translate to stutters and slower windowing behavior.
How to disable the basic effects (fast)
- Press Windows + I to open Settings.
- Go to Accessibility > Visual effects.
- Turn off Transparency effects and Animation effects.
This quick toggle reduces GPU and compositor work without touching more advanced system options.
How to disable nearly all effects (deeper)
- Press Windows + R, type sysdm.cpl and press Enter to open System Properties.
- Go to the Advanced tab and click Settings… under Performance.
- Choose Adjust for best performance and click Apply (or choose Custom and keep font smoothing/thumbnail options you prefer).
The classic Performance Options dialog still exists in Windows 11 and is the place to get the broadest visual‑effect reduction. Microsoft and longstanding Windows documentation show this path and recommend it when animations or desktop composition cause GPU/CPU pressure.
When to use it
- Low‑end laptops with integrated graphics.
- Desktop VMs or remote sessions where you want minimal UI overhead.
- Systems that stutter when switching windows or minimizing apps.
Trade-offs and practical tips
- Turning everything off makes Windows look more utilitarian; keep a few effects (like font smoothing) if readability matters.
- If you use GPU‑accelerated apps (games, video editors), test both settings; some GPU drivers handle composition differently and you may prefer leaving some effects on.
- If DWM.exe or the display driver is consuming abnormally high GPU, transparency and animations are often the first things to try.
Set your PC to Best Performance (Power Mode)
What the power slider does
Windows 11’s Power Mode controls how aggressively the OS allows the CPU, GPU and other components to downclock in the name of battery savings. Setting Power Mode to
Best performance reduces throttling and prioritizes responsiveness. Microsoft documents the available modes and where to change them in Settings.
Where to change it
- Open Settings (Windows + I) → System → Power & battery.
- Under Power mode, choose Best performance for plugged‑in use (or Best power efficiency when you must conserve battery).
Many OEM support pages reiterate this flow and explain that desktops benefit from a High/Best Performance plan because they are usually plugged in and thermal limits differ from laptops.
When it helps
- You’re running CPU‑bound workloads (rendering, compiling, gaming).
- You notice sluggish app startup when the device is on battery and throttled.
- You prefer consistent responsiveness over battery runtime.
Trade‑offs and cautions
- Expect noticeably higher power draw and warmer system temperatures; on laptops this reduces battery life and can increase fan noise.
- For everyday, mixed use keep Balanced or use Best Performance selectively when you need it (for example, while gaming or editing).
- Some enterprise fleets use managed power plans; the slider might be locked if a custom power plan is present.
Clean up your storage (Disk Cleanup, Storage Sense, Optimize Drives)
Why storage matters
Low free space and accumulated temporary files cause more than filename clutter. Operating systems use free space for caching, virtual memory, and update staging; when the system drive gets crowded, read/write performance and responsiveness can degrade. Built‑in cleanup utilities can reclaim gigabytes and reduce I/O pressure. Microsoft explains Storage Sense and its safe defaults for automated cleanup.
Two easy approaches
- Manual Disk Cleanup (classic):
- Press Windows, type Disk Cleanup (cleanmgr), run it.
- Choose C:, click Clean up system files, then review categories (Temporary files, Windows Update Cleanup, Previous Windows installations). XDA and many community guides note Disk Cleanup remains useful for one‑off large reclaim operations (Windows.old, update leftovers).
- Storage Sense (automated):
- Settings → System → Storage → Storage Sense.
- Toggle on and configure frequency and items (Recycle Bin expiry, unused Downloads, temp files). Microsoft’s Storage Sense doc explains it runs automatically when disk space is low and won’t touch cloud content unless you opt in.
Optimize Drives and SSDs vs HDDs
- For HDDs: run the Defragment and Optimize Drives utility to defragment and reduce file fragmentation; this can improve sequential and small‑file access times on platter drives.
- For SSDs: Windows will perform TRIM and “optimize” tasks, but you should not defragment an SSD manually — defragmenting is unnecessary and can increase wear. Modern Windows detects SSDs and runs appropriate maintenance; reputable guides emphasize leaving SSD maintenance to the OS.
Practical cleanup checklist
- Run Disk Cleanup → Clean up system files and remove Windows Update leftovers if you don’t need to roll back.
- Use Storage Sense to automate small daily maintenance.
- Defragment HDDs only; let Windows handle SSD optimization.
- Uninstall large unused apps (Settings → Apps → Installed apps).
- If your drive is >90% full, consider moving media/games to another drive or upgrading to a larger SSD.
Expectations
Cleaning up 10–100+ GB can dramatically improve time to launch large apps, reduce paging activity, and lower general I/O contention. For the single biggest hardware improvement, migrating from an HDD to an SSD is the most transformative change for boot and app‑load times. Community testing and vendor reviews validate that NVMe SSDs yield the largest real‑world gains.
Change an app’s priority in Task Manager
What this does
Windows’ scheduler assigns CPU time to processes; by default most are “Normal.” Temporarily raising an app to
High priority nudges the scheduler to favor it for CPU slices, which can make a foreground app feel more responsive when the CPU is contended. Use Task Manager’s Details tab to set priority. Community guides and support threads explain the steps and warn about risks.
How to set priority
- Press Ctrl + Shift + Esc to open Task Manager and click More details.
- Go to the Details tab.
- Right‑click the process (for example chrome.exe or your game’s exe) → Set priority → choose High. Confirm the warning.
Important rules and risks
- Changes made this way are temporary and revert when the process restarts or you reboot. If an application restarts itself, the new priority is lost. Microsoft community answers and admin posts explain why the setting isn’t persistent by default.
- Don’t set more than one heavy app to High — competing High‑priority processes defeat the purpose.
- Never set non‑trusted processes to Realtime; Real‑time priority can starve essential system processes and cause instability.
When to use it
- Short, CPU‑bound tasks where a single foreground process needs immediate responsiveness (e.g., a render, compilation, or a game).
- Diagnostic scenarios to see if CPU scheduling is the bottleneck.
Alternatives for persistence
- If you need a permanent priority change, use a startup script, a third‑party tool (Process Lasso), or create an Image File Execution Options registry key (advanced, carries risk). Use this only in controlled, well‑documented environments.
Other helpful fixes that pair well with the four tweaks
1) Keep Windows and drivers updated
A strange slowdown can be caused by driver bugs or OS regressions. Check Settings → Windows Update → Check for updates. In several cases a single update resolved sluggish app launches. Microsoft and community troubleshooting guides recommend this as a basic step.
2) Fast Startup — understand when to disable it
Fast Startup reduces cold‑boot time by hybridizing shutdown and hibernate, but it can interfere with firmware updates, dual‑boot setups, external drive access and some device drivers. If you see freezes, odd device behavior, or you need deterministic clean boots, disable Fast Startup via Control Panel → Power Options → Choose what the power buttons do → Change settings that are currently unavailable → uncheck
Turn on fast startup. If that control is unavailable, disabling hibernation (powercfg -h off) also disables Fast Startup. Multiple community and documentation sources explain the trade‑offs.
3) Don’t forget malware scanning
Malware and unwanted background processes can chew CPU, RAM and I/O. A full scan with Microsoft Defender or a reputable antimalware tool is a sensible maintenance step when unexplained slowdowns occur.
Critical analysis — strengths, limitations and risks
Strengths of the four tweaks
- Low friction: each tweak is reversible, built into Windows, and accessible to non‑experts.
- Immediate payoff: disabling animations and switching power modes produce instantly noticeable improvements in perceived responsiveness.
- Storage cleanup and drive optimization address the most common long‑term causes of slowdown and can free gigabytes of space quickly.
Limitations and when they won’t help
- These tweaks can’t beat fundamental hardware limits. If your workload needs more RAM or direct storage bandwidth than your hardware provides, the only long‑term fix is upgrading components (e.g., adding RAM, installing an NVMe SSD). Community testing shows the single most transformative upgrade is switching from HDD to SSD.
- Power Mode changes help responsiveness but won’t remove a bad driver or solve a malware infection.
- Task Manager priority adjustments are temporary and won’t fix I/O or GPU bottlenecks.
Risks and caveats
- Setting multiple processes to High or using Realtime can cause system instability and should be avoided. Always use priority tweaks sparingly.
- Aggressively deleting items in Disk Cleanup (Windows.old or device driver packages) prevents rollbacks and can remove system restore points — review the list before confirming. Disk Cleanup’s “Clean up system files” is powerful but irreversible for some items.
- Disabling hibernation to remove Fast Startup will also remove actual hibernate functionality and the hiberfil.sys file; weigh this trade‑off if you rely on hibernate.
Unverifiable or anecdotal claims (flagged)
- Purchasing anecdotes (for example, an author reporting a flawless Samsung 980 PRO 2TB bought on Black Friday) are personal experiences and cannot be generalized. Drive model performance is documented by manufacturers and reviewers, but user experiences vary by firmware, motherboard and driver versions. Treat purchase stories as user testimony, not technical guarantees.
Step‑by‑step quick checklist (10–15 minutes)
- Disable animations & transparency: Settings → Accessibility → Visual effects → turn off both toggles.
- If you want maximal effect: Run sysdm.cpl → Advanced → Performance Settings → Adjust for best performance.
- Change Power Mode: Settings → System → Power & battery → Power mode → Best performance (for plugged use).
- Clean storage: Settings → System → Storage → Temporary files (or run Disk Cleanup → Clean up system files). Enable Storage Sense if you prefer automation.
- Optimize drives: Run “Defragment and Optimize Drives” only for HDDs; allow Windows to optimize SSDs (don’t defrag SSDs).
- If a single app is sluggish under CPU contention: Ctrl + Shift + Esc → Details → right‑click process → Set priority → High (temporary).
- If encountering boot, update or device problems, disable Fast Startup: Control Panel → Power Options → Choose what the power buttons do → uncheck Turn on fast startup.
Realistic expectations and closing notes
- Perceptible speed gains: disabling animations + Best Performance gives a snappier UI immediately. Storage cleanup reduces app‑load times and prevents paging; if you reclaim tens of gigabytes, the difference is tangible.
- The largest single upgrade is hardware: moving from an HDD to an SSD typically delivers the most dramatic and lasting improvement in boot and app‑launch times. Software tweaks are excellent first steps but are not substitutes for critically underpowered hardware.
- Always apply one change at a time and test: it makes it easy to roll back anything that causes unexpected side effects.
These four tricks are deliberately low‑risk and reversible, and they’re an efficient way to restore much of the responsiveness your PC had when it was new. Follow the checklist, keep Windows and drivers updated, and use these knobs selectively — and in most cases you’ll avoid spending money on new hardware while getting a faster, more responsive Windows 11 experience.
Source: Pocket-lint
I sped up Windows 11 with these 4 easy tricks, and you can too
