Windows 7 Freeze and then BSOD
rautsik
Hello,
About a month ago I bought new laptop, Dell latidude E5520, and changed initial HDD to SSD. All work fine about 1,5 week then blue screen errors started. At the beginning over 2-3 days, but it got frequent later. Then I made backup to my laptop to time where all worked fine, also updated my SSD firmware to the latest version. It fixed a problem for a week, but today I got 2 blue screens that both had same message as it was when BSOD started appearing.
Week ago and before it just threw me into BSOD, but latest BSOD first freeze my screen for 3 to 4 sec and then throw into BSOD.
I am using 64 bit Windows 7.
I hope you can help me out.
Attached zip contains 2 dump files (both today blue screen dump files).
  • minidump.zip
Hi rautsik and Welcome to The Forum.
STOP 0x000000F4: CRITICAL_OBJECT_TERMINATION
Usual causes:
Your latest dump file lists csrss.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Highly likely related to your SSD Drive. Check with Dell and/or your chipset Mfr. (Intel/AMD) that you have all the latest drivers. Check with the SSD Mfr. you have the latest firmware. Make sure DiskDefrag is disabled You knew that!!). Some people have noticed improvements by disabling Superfetch.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
ATSwpWDF.sys Tue Nov 24 14:00:40 2009 Swipe Fingerprint Sensor USB Driver. This gets a few mentions. Check with O.E.M. Support or your Motherboard Mfr. for updates.
Outdated Drivers. Update:
b57nd60a.sys Sun Apr 26 12:14:55 2009 Broadcom NetXtreme Gigabit Ethernet
Bugcheck Analysis:
BugCheck F4, {3, fffffa8008477b30, fffffa8008477e10, fffff80002d828b0}
Probably caused by : csrss.exe
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa8008477b30, Terminating object
Arg3: fffffa8008477e10, Process image file name
Arg4: fffff80002d828b0, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: fffffa8008477b30
IMAGE_NAME:  csrss.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: csrss
FAULTING_MODULE: 0000000000000000
PROCESS_NAME:  csrss.exe
EXCEPTION_CODE: (NTSTATUS) 0xc0000006 - The instruction at 0x%p referenced memory at 0x%p. The required data was not placed into memory because of an I/O error status of 0x%x.
BUGCHECK_STR:  0xF4_IOERR
CUSTOMER_CRASH_COUNT:  1
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`0b9e6e38 fffff800`02e095e2 : 00000000`000000f4 00000000`00000003 fffffa80`08477b30 fffffa80`08477e10 : nt!KeBugCheckEx
fffff880`0b9e6e40 fffff800`02db699b : ffffffff`ffffffff fffffa80`09358590 fffffa80`08477b30 fffffa80`08477b30 : nt!PspCatchCriticalBreak+0x92
fffff880`0b9e6e80 fffff800`02d36448 : ffffffff`ffffffff 00000000`00000001 fffffa80`08477b30 00000000`00000008 : nt! ?? ::NNGAKEGL::`string'+0x176d6
fffff880`0b9e6ed0 fffff800`02a7ded3 : fffffa80`08477b30 fffff800`c0000006 fffffa80`09358590 00000000`02880c00 : nt!NtTerminateProcess+0xf4
fffff880`0b9e6f50 fffff800`02a7a470 : fffff800`02aca67f fffff880`0b9e7a38 fffff880`0b9e7790 fffff880`0b9e7ae0 : nt!KiSystemServiceCopyEnd+0x13
fffff880`0b9e70e8 fffff800`02aca67f : fffff880`0b9e7a38 fffff880`0b9e7790 fffff880`0b9e7ae0 00000000`02881910 : nt!KiServiceLinkage
fffff880`0b9e70f0 fffff800`02a7e2c2 : fffff880`0b9e7a38 00000000`0000d828 fffff880`0b9e7ae0 00000000`028813e8 : nt! ?? ::FNODOBFM::`string'+0x49874
fffff880`0b9e7900 fffff800`02a7ce3a : 00000000`00000000 000007fe`fde7d8b4 00000000`77b08d01 00000000`0000d828 : nt!KiExceptionDispatch+0xc2
fffff880`0b9e7ae0 00000000`77a09c12 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x23a
00000000`02881330 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77a09c12
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0xF4_IOERR_IMAGE_csrss.exe
Followup: MachineOwner
Drivers:
fffff880`08b38000 fffff880`08b76000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00f3b000 fffff880`00f92000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`02e96000 fffff880`02f1f000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`08be2000 fffff880`08bf8000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00c00000 fffff880`00c0b000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`0b471000 fffff880`0b47c000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00dac000 fffff880`00db5000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00db5000 fffff880`00ddf000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`0b539000 fffff880`0b5ee000   ATSwpWDF ATSwpWDF.sys Tue Nov 24 14:00:40 2009 (4B0BE708)
fffff880`08200000 fffff880`08248000   b57nd60a b57nd60a.sys Sun Apr 26 12:14:55 2009 (49F4422F)
fffff880`00e09000 fffff880`00e15000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`01633000 fffff880`0163a000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`0390b000 fffff880`0391c000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`04178000 fffff880`04196000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`02744000 fffff880`02754000   BthEnum  BthEnum.sys  Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`02754000 fffff880`02774000   bthpan   bthpan.sys   Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`0267e000 fffff880`0270a000   bthport  bthport.sys  Thu Apr 28 04:55:07 2011 (4DB8E51B)
fffff880`0a1e8000 fffff880`0a200000   BTHUSB   BTHUSB.sys   Thu Apr 28 04:54:56 2011 (4DB8E510)
fffff960`00720000 fffff960`00747000   cdd      cdd.dll      unavailable (00000000)
fffff880`01600000 fffff880`0162a000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00cd2000 fffff880`00d92000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`00c74000 fffff880`00cd2000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`082b7000 fffff880`082bb500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`01120000 fffff880`01192000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`00e00000 fffff880`00e09000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`08bd2000 fffff880`08be2000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`0a0ae000 fffff880`0a0bc000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0386a000 fffff880`038ed000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`038ed000 fffff880`0390b000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`02e68000 fffff880`02e77000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`07183000 fffff880`071a5000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`01400000 fffff880`01446000   dtsoftbus01 dtsoftbus01.sys Fri Jun 17 08:38:37 2011 (4DFB047D)
fffff880`0a0bc000 fffff880`0a0c8000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0a0d3000 fffff880`0a0e6000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`0a0c8000 fffff880`0a0d3000   dump_msahci dump_msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`0a0a2000 fffff880`0a0ae000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`06a40000 fffff880`06b34000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`06b34000 fffff880`06b7a000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`010ae000 fffff880`010c2000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01062000 fffff880`010ae000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`013e2000 fffff880`013ec000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01943000 fffff880`0197d000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01840000 fffff880`0188a000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`02feb000 fffff800`03034000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`06a00000 fffff880`06a24000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`0a046000 fffff880`0a0a2000   HdAudio  HdAudio.sys  Sat Nov 20 10:44:23 2010 (4CE7A687)
fffff880`06b7a000 fffff880`06b8b000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`040af000 fffff880`04178000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`0193a000 fffff880`01943000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`08248000 fffff880`08266000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`07432000 fffff880`07fee9a0   igdkmd64 igdkmd64.sys Wed Aug 31 20:53:13 2011 (4E5E9129)
fffff880`082a1000 fffff880`082b7000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`08266000 fffff880`08275000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00bc2000 fffff800`00bcc000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`03800000 fffff880`03843000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013b6000 fffff880`013d1000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`015ad000 fffff880`015d8000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`071a5000 fffff880`071aa200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`027b8000 fffff880`027cd000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`02774000 fffff880`02797000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c11000 fffff880`00c60000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`0b5ee000 fffff880`0b5fc000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`08292000 fffff880`082a1000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`00d92000 fffff880`00dac000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`01192000 fffff880`011c3000   MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`04072000 fffff880`04082000   MpNWMon  MpNWMon.sys  Wed Apr 06 21:07:23 2011 (4D9CC7FB)
fffff880`04196000 fffff880`041ae000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`041ae000 fffff880`041db000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`04000000 fffff880`0404e000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`0404e000 fffff880`04072000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`00ddf000 fffff880`00dea000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`011cc000 fffff880`011d7000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f9b000 fffff880`00fa5000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`010c2000 fffff880`01120000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`02e5d000 fffff880`02e68000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01928000 fffff880`0193a000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0145a000 fffff880`0154d000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`06a24000 fffff880`06a30000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`02653000 fffff880`02666000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`03942000 fffff880`03971000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`070ae000 fffff880`070c3000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`02fa9000 fffff880`02fb8000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`02f1f000 fffff880`02f64000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`0154d000 fffff880`015ad000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`082c0000 fffff880`08b2b000   NETwNs64 NETwNs64.sys Tue Dec 21 17:08:43 2010 (4D10DF1B)
fffff880`0b521000 fffff880`0b539000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`011d7000 fffff880`011e8000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`02e51000 fffff880`02e5d000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02a02000 fffff800`02feb000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01213000 fffff880`013b6000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`0162a000 fffff880`01633000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`02600000 fffff880`02653000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`08bb8000 fffff880`08bc8a80   O2MDRw7x64 O2MDRw7x64.sys Mon Jan 03 06:14:59 2011 (4D216963)
fffff880`08b76000 fffff880`08b88c00   o2sdjw7x64 o2sdjw7x64.sys Tue Mar 22 11:56:31 2011 (4D888E6F)
fffff880`02f6d000 fffff880`02f93000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`08275000 fffff880`08292000   parport  parport.sys  Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`00fe5000 fffff880`00ffa000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00fa5000 fffff880`00fd8000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00dea000 fffff880`00dfa000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`013d1000 fffff880`013e2000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0b2aa000 fffff880`0b350000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`07146000 fffff880`07183000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c60000 fffff880`00c74000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`07400000 fffff880`07424000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`03971000 fffff880`0398c000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0398c000 fffff880`039ad000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`039ad000 fffff880`039c7000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`02e00000 fffff880`02e51000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`06a30000 fffff880`06a3b000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`01200000 fffff880`01209000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01209000 fffff880`01212000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`011c3000 fffff880`011cc000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`018ee000 fffff880`01928000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`02718000 fffff880`02744000   rfcomm   rfcomm.sys   Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`02666000 fffff880`0267e000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`08b89000 fffff880`08bb8000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`0b350000 fffff880`0b35b000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`018e6000 fffff880`018ee000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0b47f000 fffff880`0b517000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`0b200000 fffff880`0b269000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0b35b000 fffff880`0b38c000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`070c3000 fffff880`07146000   stwrt64  stwrt64.sys  Tue Jan 25 08:03:31 2011 (4D3E83D3)
fffff880`08bf8000 fffff880`08bf9480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0163c000 fffff880`01840000   tcpip    tcpip.sys    Tue Jun 21 04:33:55 2011 (4E001123)
fffff880`0b38c000 fffff880`0b39e000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01022000 fffff880`0102f000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01000000 fffff880`01022000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`02fd3000 fffff880`02fe7000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00420000 fffff960`0042a000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`0391c000 fffff880`03942000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`03843000 fffff880`03855000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`0a19b000 fffff880`0a1b8000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`0a1b8000 fffff880`0a1b9f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`06b8b000 fffff880`06b9c000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`07054000 fffff880`070ae000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`06b9c000 fffff880`06bf2000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`0a1ba000 fffff880`0a1e7280   usbvideo usbvideo.sys Sat Nov 20 10:44:34 2010 (4CE7A692)
fffff880`00fd8000 fffff880`00fe5000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01446000 fffff880`01454000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`015d8000 fffff880`015fd000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`0188a000 fffff880`0189a000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`00e15000 fffff880`00e2a000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e2a000 fffff880`00e86000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`0189a000 fffff880`018e6000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`08b2b000 fffff880`08b38000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`02f93000 fffff880`02fa9000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`0b517000 fffff880`0b521000   vwifimp  vwifimp.sys  Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`02fb8000 fffff880`02fd3000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`013ec000 fffff880`013fc000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e88000 fffff880`00f2c000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f2c000 fffff880`00f3b000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02f64000 fffff880`02f6d000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00373000   win32k   win32k.sys   Tue Sep 06 04:02:50 2011 (4E658D5A)
fffff880`08bc9000 fffff880`08bd2000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f92000 fffff880`00f9b000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`02797000 fffff880`027b8000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`01993000 fffff880`019c3000   CLASSPNP.SYS
    Checksum:  00000000
    ImageSize:  00030000
fffff880`0197d000 fffff880`01993000   disk.sys
    Checksum:  00000000
    ImageSize:  00016000
fffff880`0b539000 fffff880`0b5ee000   ATSwpWDF.sys
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
fffff880`0b400000 fffff880`0b471000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0b5ee000 fffff880`0b5fc000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
    Checksum:  00000000
    ImageSize:  000B5000
fffff880`0270a000 fffff880`02718000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Thank you for the help.
I did some things:
1)First I disabled DiskDefrag. But I think it was`nt problem, because it had never run.
2)Downloaded latest driver package from dell ftp. That was the only way I could update drivers, using check for updates in device manager never shows that my driver is out of date, it always says you have the latest if it can`t find any updates. Also downloading drivers separately and trying to install them I got errors. Only way that worked was to unzip driver package i downloaded from dell ftp and then manually went through all drivers in device manager and choosed :update driver software > browser my computer for drivers update.
Then I got to "IDE ATA/ATAPI controllers" and under that point i saw about 5 to 7 different devices like usb 1, usb 2 and so one. After updating that section only one was left: "Intel(R) Mobile Express Chipset SATA AHCI Controller". After the reboot notice appeard: "OCZ SSD drive is ready for use".
Since that I haven`t got any more blue screens, I suppose that old driver under "IDE ATA/ATAPI controllers" was the cause of blue screen.
rautsik
Well, I think it sounds like you are sorted!! :)
Never rely on Windows Update or Device Manager to update your drivers until you've exhausted your PC Mfr., Motherboard Mfr. or the software/hardware Mfr. resources. It's often known to "update" your rivers to older versions.
