Frequent blue screens (64 bit)
Hello,
I'm using Windows 7 64 bit and get blue screens frequently. I've alredy tried to update my video card drivers, audio driver (I'm using the new beta now), replacing Avast with ESET NOD32 and replacing Daemon Tools with Virtual CloneDrive but I still get blue screens. (not only when playing games).
All the hardwares are new, except my hard drives and my USB soundcard.
I attached CPU-Z screens and information from the diagnostic tool.
Thanks,
szm33
Hello and welcome,
the memory is set right, thank you for attaching.
PAGE_FAULT_IN_NONPAGED_AREA (50)
Typically the address is just plain bad or it
is pointing at freed memory
Probably caused by : ntkrnlmp.exe ( nt!FsRtlTeardownPerStreamContexts+69 )
1. Update the software:
VirtualClone
VClone.sys Sun Aug 09 17:25:45 2009
Elaborate Bytes AG CD/DVD Tool
ElbyCDIO.sys Thu Dec 17 17:25:16 2009
2. Command Prompt >> chkdsk /f
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\011711-17940-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e5b000 PsLoadedModuleList = 0xfffff800`03098e50
Debug session time: Mon Jan 17 12:15:58.942 2011 (UTC - 5:00)
System Uptime: 0 days 3:12:50.846
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 50, {fffff8800a4645d0, 1, fffff800031ba81d, 2}
Followup: MachineOwner
3: kd> !analyze -v
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff8800a4645d0, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff800031ba81d, If non-zero, the instruction address which referenced the bad memory
	address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff800031030e0
 fffff8800a4645d0
FAULTING_IP:
fffff800`031ba81d 48894808        mov     qword ptr [rax+8],rcx
MM_INTERNAL_CODE:  2
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x50
PROCESS_NAME:  System
CURRENT_IRQL:  0
TRAP_FRAME:  fffff88002f7e7c0 -- (.trap 0xfffff88002f7e7c0)
rax=fffff8800a4645c8 rbx=0000000000000000 rcx=fffff8a00a4645c8
rdx=fffff88002dd4180 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800031ba81d rsp=fffff88002f7e950 rbp=0000000000000130
 r8=0000000000000003  r9=00000000000000b0 r10=fffff80002e5b000
r11=0000000000000019 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na pe nc
nt!FsRtlTeardownPerStreamContexts+0x69:
fffff800`031ba81d 48894808        mov     qword ptr [rax+8],rcx ds:5350:fffff880`0a4645d0=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002f4a8f2 to fffff80002ecb740
STACK_TEXT:
fffff880`02f7e658 fffff800`02f4a8f2 : 00000000`00000050 fffff880`0a4645d0 00000000`00000001 fffff880`02f7e7c0 : nt!KeBugCheckEx
fffff880`02f7e660 fffff800`02ec982e : 00000000`00000001 00000000`00000001 00000000`00000700 00000000`000000c0 : nt! ?? ::FNODOBFM::`string'+0x40ec0
fffff880`02f7e7c0 fffff800`031ba81d : fffff8a0`0b057590 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
fffff880`02f7e950 fffff880`012d0bcc : fffff8a0`0a464590 00000000`00000130 fffff880`02f7ea28 00000000`00000706 : nt!FsRtlTeardownPerStreamContexts+0x69
fffff880`02f7e9a0 fffff880`012d08d5 : 00000000`00000000 00000000`00000000 fffff800`03070500 00000000`00000001 : Ntfs!NtfsDeleteScb+0x108
fffff880`02f7e9e0 fffff880`01243cb4 : fffff8a0`0a464490 fffff8a0`0a464590 fffff800`03070500 fffff880`02f7eb52 : Ntfs!NtfsRemoveScb+0x61
fffff880`02f7ea20 fffff880`012ce2dc : fffff8a0`0a464460 fffff800`030705a0 fffff880`02f7eb52 fffffa80`04020a70 : Ntfs!NtfsPrepareFcbForRemoval+0x50
fffff880`02f7ea50 fffff880`0124c882 : fffffa80`04020a70 fffffa80`04020a70 fffff8a0`0a464460 00000000`00000000 : Ntfs!NtfsTeardownStructures+0xdc
fffff880`02f7ead0 fffff880`012e5813 : fffffa80`04020a70 fffff800`030705a0 fffff8a0`0a464460 00000000`00000009 : Ntfs!NtfsDecrementCloseCounts+0xa2
fffff880`02f7eb10 fffff880`012bf38f : fffffa80`04020a70 fffff8a0`0a464590 fffff8a0`0a464460 fffffa80`04994180 : Ntfs!NtfsCommonClose+0x353
fffff880`02f7ebe0 fffff800`02ed8961 : 00000000`00000000 fffff880`012bf200 fffffa80`03a03b00 000004f4`00000005 : Ntfs!NtfsFspClose+0x15f
fffff880`02f7ecb0 fffff800`0316fc06 : 000004f4`00000000 fffffa80`03a03b60 00000000`00000080 fffffa80`03973890 : nt!ExpWorkerThread+0x111
fffff880`02f7ed40 fffff800`02ea9c26 : fffff880`02d63180 fffffa80`03a03b60 fffff880`02d6dfc0 000004f4`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`02f7ed80 00000000`00000000 : fffff880`02f7f000 fffff880`02f79000 fffff880`02f7e9f0 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!FsRtlTeardownPerStreamContexts+69
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
FAILURE_BUCKET_ID:  X64_0x50_nt!FsRtlTeardownPerStreamContexts+69
Drivers:
fffff880`00f7f000 fffff880`00fd6000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02b2d000 fffff880`02bb7000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03fc1000 fffff880`03fd7000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`03ed3000 fffff880`03ee8000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00dd3000 fffff880`00dde000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`11c40000 fffff880`11c48000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`03cb8000 fffff880`03cbe000   AsIO     AsIO.sys     Mon Aug 03 03:03:16 2009 (4A768BB4)
fffff880`03cb2000 fffff880`03cb8000   AsUpIO   AsUpIO.sys   Sun Jul 05 22:21:38 2009 (4A515FB2)
fffff880`00ec0000 fffff880`00ec9000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00da9000 fffff880`00dd3000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`01231000 fffff880`01239000   AtiPcie  AtiPcie.sys  Mon Aug 24 04:25:26 2009 (4A924E76)
fffff960`00940000 fffff960`009a1000   ATMFD    ATMFD.DLL    Tue Oct 19 23:05:45 2010 (4CBE5C89)
fffff880`02a5c000 fffff880`02a63000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03ca1000 fffff880`03cb2000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`059db000 fffff880`059f9000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00600000 fffff960`00627000   cdd      cdd.dll      Tue Nov 02 00:59:22 2010 (4CCF9AAA)
fffff880`02a29000 fffff880`02a53000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cbf000 fffff880`00d7f000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01086000 fffff880`010b6000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c61000 fffff880`00cbf000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0117a000 fffff880`011ed000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`03fb1000 fffff880`03fc1000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`057af000 fffff880`057bd000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03c00000 fffff880`03c83000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03c83000 fffff880`03ca1000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03dd2000 fffff880`03de1000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0121b000 fffff880`01231000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`041c1000 fffff880`041e3000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`057c9000 fffff880`057d2000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`057bd000 fffff880`057c9000   dump_ataport dump_ataport.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`057d2000 fffff880`057e5000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0599e000 fffff880`059aa000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`128b0000 fffff880`129a4000   dxgkrnl  dxgkrnl.sys  Mon Nov 01 22:51:31 2010 (4CCF7CB3)
fffff880`129a4000 fffff880`129ea000   dxgmms1  dxgmms1.sys  Mon Nov 01 22:50:56 2010 (4CCF7C90)
fffff880`044ef000 fffff880`045c7000   eamonm   eamonm.sys   Fri Aug 13 08:38:55 2010 (4C653CDF)
fffff880`02a63000 fffff880`02a88000   ehdrv    ehdrv.sys    Wed Jul 14 04:14:21 2010 (4C3D71DD)
fffff880`03dc7000 fffff880`03dd2000   ElbyCDIO ElbyCDIO.sys Thu Dec 17 17:25:16 2009 (4B2AAFCC)
fffff880`04026000 fffff880`04047000   epfwwfpr epfwwfpr.sys Wed Jul 14 04:10:34 2010 (4C3D70FA)
fffff880`01108000 fffff880`0111c000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010bc000 fffff880`01108000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`00c00000 fffff880`00c3a000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01400000 fffff880`0144a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02e12000 fffff800`02e5b000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`11c00000 fffff880`11c24000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04000000 fffff880`04019000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`057f3000 fffff880`057fb080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`057e5000 fffff880`057f3000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`04418000 fffff880`044e0000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0144a000 fffff880`01453000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`03e91000 fffff880`03ea0000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05990000 fffff880`0599e000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00ba4000 fffff800`00bae000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04097000 fffff880`040da000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013de000 fffff880`013f8000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`015aa000 fffff880`015d5000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`041e3000 fffff880`041e8200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`058c2000 fffff880`0597e300   L6UX164  L6UX164.sys  Tue Sep 07 18:24:48 2010 (4C86BBB0)
fffff880`045e8000 fffff880`045fd000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`059b8000 fffff880`059db000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c40000 fffff880`00c4d000   mcupdate mcupdate.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`059aa000 fffff880`059b8000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`03cbe000 fffff880`03ccd000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04019000 fffff880`04026000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00d8f000 fffff880`00da9000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`05800000 fffff880`05818000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05818000 fffff880`05845000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`05845000 fffff880`05893000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`05893000 fffff880`058b6000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02ae6000 fffff880`02af1000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fdf000 fffff880`00fe9000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0111c000 fffff880`0117a000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03dbc000 fffff880`03dc7000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`015ed000 fffff880`015ff000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01458000 fffff880`0154a000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`03e00000 fffff880`03e0c000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`03e0c000 fffff880`03e3b000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04146000 fffff880`0415b000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03d04000 fffff880`03d13000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02bb7000 fffff880`02bfc000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0154a000 fffff880`015aa000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02af1000 fffff880`02b02000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03db0000 fffff880`03dbc000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e5b000 fffff800`03437000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`0123b000 fffff880`013de000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02a53000 fffff880`02a5c000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`128ae000 fffff880`128af180   nvBridge nvBridge.kmd Tue Dec 21 18:21:09 2010 (4D113665)
fffff880`0415b000 fffff880`04184000   nvhda64v nvhda64v.sys Thu Nov 11 18:10:36 2010 (4CDC77EC)
fffff880`11c53000 fffff880`128ad680   nvlddmkm nvlddmkm.sys Tue Dec 21 18:24:15 2010 (4D11371F)
fffff880`03cde000 fffff880`03d04000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`03f94000 fffff880`03fb1000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00e33000 fffff880`00e48000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00eb9000 fffff880`00ec0000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00d7f000 fffff880`00d8f000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`064ff000 fffff880`065a5000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04184000 fffff880`041c1000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c4d000 fffff880`00c61000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`03fd7000 fffff880`03ffb000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03e3b000 fffff880`03e56000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`03e56000 fffff880`03e77000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`03e77000 fffff880`03e91000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03d5f000 fffff880`03db0000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`11c48000 fffff880`11c53000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02acb000 fffff880`02ad4000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02ad4000 fffff880`02add000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02add000 fffff880`02ae6000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`04400000 fffff880`04418000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03ee8000 fffff880`03f3e000   Rt64win7 Rt64win7.sys Wed Jun 23 05:10:45 2010 (4C21CF95)
fffff880`04066000 fffff880`04095000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`065a5000 fffff880`065b0000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`129ea000 fffff880`129f6000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03d13000 fffff880`03d30000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`015e5000 fffff880`015ed000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06467000 fffff880`064fd000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`06400000 fffff880`06467000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`065b0000 fffff880`065dd000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`0597f000 fffff880`0598fd00   STREAM   STREAM.SYS   Mon Jul 13 20:06:18 2009 (4A5BCBFA)
fffff880`04095000 fffff880`04096480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01600000 fffff880`017fd000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`065dd000 fffff880`065ef000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02b20000 fffff880`02b2d000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02b02000 fffff880`02b20000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03d4b000 fffff880`03d5f000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`005a0000 fffff960`005aa000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`03ead000 fffff880`03ed3000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`040da000 fffff880`040ec000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`057fc000 fffff880`057fdf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`11c2f000 fffff880`11c40000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`040ec000 fffff880`04146000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`11c24000 fffff880`11c2f000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`03f3e000 fffff880`03f94000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`03ccd000 fffff880`03cdc000   VClone   VClone.sys   Sun Aug 09 17:25:45 2009 (4A7F3ED9)
fffff880`00fe9000 fffff880`00ff6000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02a88000 fffff880`02a96000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`05601000 fffff880`057af000   viahduaa viahduaa.sys Mon Jan 11 05:05:18 2010 (4B4AF7DE)
fffff880`02a96000 fffff880`02abb000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015d5000 fffff880`015e5000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e48000 fffff880`00e5d000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e5d000 fffff880`00eb9000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03d30000 fffff880`03d4b000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02abb000 fffff880`02acb000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ecc000 fffff880`00f70000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f70000 fffff880`00f7f000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02a00000 fffff880`02a09000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a0000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`129f6000 fffff880`129ff000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fd6000 fffff880`00fdf000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`045c7000 fffff880`045e8000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`09ca1000 fffff880`09d12000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`011ed000 fffff880`011fb000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`00dde000 fffff880`00dea000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`00ff6000 fffff880`00fff000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`00dea000 fffff880`00dfd000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Thanks for the quick reply.
I had the latest VirtualClone, so I uninstalled it to see if it caused the problem and I also ran chkdsk.
I don't get any blue screens now, but it still crashes often. Everything just freezes. There's no dump file so I've checked the log Management at My Computer. It says: Critical Kernel-Power 41 (63).
Could you help me?
Thanks,
szm33
1. Command prompt > sfc /scannow. This will check and fix the integrity of your system files.
2. Run SMART report HDDScan
3. In the device manager, check the state of your devices
sfc /scannow hasn't found any problems
I've checked the device manager and haven't found any errors.
Here are the HDDScan results.
Thanks
You got Ultradma CRC errors 200 points being the worst result. Replacing HDD cable may help.
#7
Thanks, I will try it.
#8
Before you do that, also try system integrity checker - command prompt > sfc /scannow
#9
Hello,
sorry for not writing for a long time.
I haven't got a new cable yet but here are some details:
I get two type of problems:
- everything just freezes and all I can do is turn it off
- a blue screen comes up for a really short time and it quickly restarts and then there's no dump file.
I've also tried running a 64 bit Ubuntu (boot from dvd) and Windows 7 in safe mode and they both worked perfectly.
Should I get a new cable anyway or is it something else that crashes my Windows?
Thanks,
szm33
#10
1. Run memtest 10 passes overnight:
Memtest86+ - Advanced Memory Diagnostic Tool
2. Reinstall the OS. If it freezes and crashes after you reinstall, blame your hardware.
3. New HDD cable may help, but not a 100% guarantee it will.
4. PSU might be the problem.
#12
Yesterday I reinstalled Windows but today it still crashes. (no blue screen, everything just stops)
I'm attaching my driver list
View attachment driverlist.txt
#13
"No bsod's, everything just stops" - what's that? Freezes? Falls into a black screen? If so it sounds like a hardware issue for sure. How's going with the HDD cable?
----> Update:
[b]
Driver Name       : ASACPI.sys
Address           : 0xfffff88003edc000
File Type         : System Driver
Description       : ATK0110 ACPI Utility
Version           : 1043, 2, 15, 37
Company           :
Product Name      : ATK0110 ACPI Utility
Modified Date     : 2005.03.29. 1:30:38
Created Date      : 2005.03.29. 1:30:38
Filename          : C:\Windows\system32\DRIVERS\ASACPI.sys[/b]
ASUSTeK Computer Inc.-Support-
ASUS support > downloads > utilities > ATK0110 ACPI Utility.
[b]VClone.sys
Address           : 0xfffff88011cae000
Description       : VirtualCloneCD Driver
Version           : 5, 4, 3, 5
Company           : Elaborate Bytes AG
Product Name      : Virtual CloneDrive
Modified Date     : 2009.08.09. 22:25:45
Created Date      : 2009.08.09. 22:25:45
Filename          : C:\Windows\system32\DRIVERS\VClone.sys[/b]
SlySoft Virtual CloneDrive
#14
The screen stops how it was at the moment. I do see Windows but I can't do anything, it doesn't react. (Sometimes some noise is coming from the speakers.)
I can't find ATK0110 ACPI Utility on the ASUS website.
The VirtualClone driver is the latest one from the SlySoft website.
Thanks,
szm33
#15
Thanks,
szm33
ATK0110 ACPI Utility from the ASUS website:
http://dlcdnet.asus.com/pub/ASUS/misc/utils/MB_WIN7_ATK.ZIP
Uninstasll Virtual Clone.
#16
Blame your hardware. Uninstall all Elaborate bytes software including Virtual Clone. Update the ASUS driver. Upgrade BIOS to the lastest. Then if the problem persists, test your hardware:
1. HDD:
HD Diagnostic
PassMark DiskCheckup - SMART hard drive monitoring utility
HD Tune website
HDDScan
2. RAM (again):
10 passes
3. Unplug USB soundcard.
#17
Hello,
I have already updated BIOS.
The first thing I wanted to test was the USB soundcard so when I reinstalled Windows 7 I didn't install its drivers or even plug it in but the same thing happened.
Then I bought a new HDD. The sound of the flash videos stopped crackling but it still freezes.
I ran memtest and it gave 0 errors. (only 2 passes tho)
(I've even tried a 32 bit Windows.)
I don't know what could cause the problem now.
#20
Kingmax 2GB DDR3 1333 FLFE85F-C8KM9 is your memory:
Kingmax 2GB DDR3 1333 Desktop memory
According to the link, the rated specs are 1333Mhz 7-7-7-21 1.5v. Adjust it in bios > Dram. At the moment your CAS Latency is 9-9-9-24. You can verify these specs written on the sticks, their package, or the RAM maker's site.
