Windows 7 frequent BSOD during start up
WeiST
I have frequent BSOD during start up, and if my windows can run without BSOD for 5 minutes then the entire session is fine. However sometimes there are numerous BSOD causing multiple restarts.
Please find attached my memory dump files and other required information.
Really appreciate your help. Thank you.
View attachment WeiST BSOD.rar
Hello and welcome to the forum.
First try removing sptd.sys
Go here DuplexSecure - Downloads grab the correct version for your architecture, run the program and be sure to choose the UNINSTALL button.
Reboot and see if that helps.
If Blue Screens persist then try it without your Linksys AE2500 USB network adapter, and this driver AE2500w7.sys (you may need to rename it from .sys to .OLD to prevent it from loading, easily reversed by changing it back to .sys if it proves not to be the actual culprit. But it looks, at least on the surface like that driver is messing with native Windows 7 afd and tcpip drivers.
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: c000001d, The exception code that was not handled
Arg2: a366b330, The address that the exception occurred at
Arg3: 00000000, Parameter 0 of the exception
Arg4: 00000000, Parameter 1 of the exception
EXCEPTION_CODE: (NTSTATUS) 0xc000001d - {EXCEPTION}  Illegal Instruction  An attempt was made to execute an illegal instruction.
FAULTING_IP:
+3362613565393032
a366b330 50              push    eax
EXCEPTION_PARAMETER1:  00000000
EXCEPTION_PARAMETER2:  00000000
ERROR_CODE: (NTSTATUS) 0xc000001d - {EXCEPTION}  Illegal Instruction  An attempt was made to execute an illegal instruction.
BUGCHECK_STR:  0x1E_c000001d
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  QvodTerminal.e
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 82edc3b1 to 82edcd10
FAILED_INSTRUCTION_ADDRESS:
+3362613565393032
STACK_TEXT:
a366b2e4 82edc3b1 0000001e c000001d a366b330 nt!KeBugCheckEx+0x1e
a366b300 82e8ff9a 0000001e 82e6a474 00000001 nt!KipFatalFilter+0x16
a366b990 8cafd170 8cafd367 a366b9b8 00000000 nt!KeExpandKernelStackAndCalloutEx+0x142
a366b9d0 90c0f783 889a4158 a366ba04 889a64c8 tcpip!UdpTlProviderSendMessages+0x67
a366b9e8 90c2f72f 86e8a1d8 a366ba04 86e8a1d8 afd!AfdTLSendMessages+0x27
a366ba40 90c2f398 86e8a1d8 889a64c8 33a759a6 afd!AfdTLFastDgramSend+0x7d
a366bab0 90c1f3e1 86e8a1d8 a366bb6c 00000024 afd!AfdFastDatagramSend+0x5d3
a366bc28 8305a8f7 86dcf401 00000001 0341f7ec afd!AfdFastIoDeviceControl+0x3dc
a366bcd0 8305d4ac 86b84a00 00000238 00000000 nt!IopXxxControlFile+0x2d0
a366bd04 82e4342a 00000214 00000238 00000000 nt!NtDeviceIoControlFile+0x2a
a366bd04 773064f4 00000214 00000238 00000000 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
0341f8a8 00000000 00000000 00000000 00000000 0x773064f4
STACK_COMMAND:  kb
FOLLOWUP_IP:
tcpip!UdpTlProviderSendMessages+67
8cafd170 33c9            xor     ecx,ecx
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  tcpip!UdpTlProviderSendMessages+67
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: tcpip
IMAGE_NAME:  tcpip.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bbf8e
FAILURE_BUCKET_ID:  0x1E_c000001d_BAD_IP_tcpip!UdpTlProviderSendMessages+67
950a6000 950d2000   1394ohci 1394ohci.sys Mon Jul 13 18:51:59 2009 (4A5BC89F)
8c55c000 8c5a4000   ACPI     ACPI.sys     Mon Jul 13 18:11:11 2009 (4A5BBF0F)
[U][B]82214000 82323000   [COLOR=#ff0000]AE2500w7 AE2500w7.sys[/COLOR] Mon Mar 28 19:22:03 2011 (4D91262B)[/B][/U]
90c0d000 90c67000   afd      afd.sys      Mon Jul 13 18:12:34 2009 (4A5BBF62)
95128000 9513a000   AgileVpn AgileVpn.sys Mon Jul 13 18:55:00 2009 (4A5BC954)
8c6e7000 8c6f0000   amdxata  amdxata.sys  Tue May 19 12:57:35 2009 (4A12F30F)
950e2000 9511b000   and1fpl9 and1fpl9.SYS Tue Jul 14 16:12:41 2009 (4A5CF4C9)
90df8000 90dff000   AppleCharger AppleCharger.sys Mon Apr 26 22:54:05 2010 (4BD65FDD)
8c6bb000 8c6c4000   atapi    atapi.sys    Mon Jul 13 18:11:15 2009 (4A5BBF13)
8c6c4000 8c6e7000   ataport  ataport.SYS  Mon Jul 13 18:11:18 2009 (4A5BBF16)
8cda4000 8cdab000   Beep     Beep.SYS     Mon Jul 13 18:45:00 2009 (4A5BC6FC)
8ca00000 8ca0e000   blbdrive blbdrive.sys Mon Jul 13 18:23:04 2009 (4A5BC1D8)
8c296000 8c29e000   BOOTVID  BOOTVID.dll  Mon Jul 13 20:04:34 2009 (4A5BD9A2)
98b81000 98b9a000   bowser   bowser.sys   Mon Jul 13 18:14:21 2009 (4A5BBFCD)
9a0a0000 9a0be000   cdd      cdd.dll      Mon Jul 13 20:04:18 2009 (4A5BD992)
8cd7e000 8cd9d000   cdrom    cdrom.sys    Mon Jul 13 18:11:24 2009 (4A5BBF1C)
8c2e0000 8c38b000   CI       CI.dll       Mon Jul 13 20:09:28 2009 (4A5BDAC8)
8cd27000 8cd4c000   CLASSPNP CLASSPNP.SYS Mon Jul 13 18:11:20 2009 (4A5BBF18)
8c29e000 8c2e0000   CLFS     CLFS.SYS     Mon Jul 13 18:11:10 2009 (4A5BBF0E)
8c973000 8c9d0000   cng      cng.sys      Mon Jul 13 18:32:55 2009 (4A5BC427)
9511b000 95128000   CompositeBus CompositeBus.sys Mon Jul 13 18:45:26 2009 (4A5BC716)
98b4f000 98b5c000   crashdmp crashdmp.sys Mon Jul 13 18:45:50 2009 (4A5BC72E)
90d7c000 90de0000   csc      csc.sys      Mon Jul 13 18:15:08 2009 (4A5BBFFC)
90de0000 90df8000   dfsc     dfsc.sys     Mon Jul 13 18:14:16 2009 (4A5BBFC8)
90d70000 90d7c000   discache discache.sys Mon Jul 13 18:24:04 2009 (4A5BC214)
8cd16000 8cd27000   disk     disk.sys     Mon Jul 13 18:11:28 2009 (4A5BBF20)
984f4000 9850d000   drmk     drmk.sys     Mon Jul 13 19:36:05 2009 (4A5BD2F5)
98b67000 98b70000   dump_atapi dump_atapi.sys Mon Jul 13 18:11:15 2009 (4A5BBF13)
98b5c000 98b67000   dump_dumpata dump_dumpata.sys Mon Jul 13 18:11:16 2009 (4A5BBF14)
98b70000 98b81000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 18:12:47 2009 (4A5BBF6F)
98afe000 98b08000   Dxapi    Dxapi.sys    Mon Jul 13 18:25:25 2009 (4A5BC265)
92870000 92927000   dxgkrnl  dxgkrnl.sys  Mon Jul 13 18:26:15 2009 (4A5BC297)
92927000 92960000   dxgmms1  dxgmms1.sys  Mon Jul 13 18:25:25 2009 (4A5BC265)
8c724000 8c735000   fileinfo fileinfo.sys Mon Jul 13 18:21:51 2009 (4A5BC18F)
8c6f0000 8c724000   fltmgr   fltmgr.sys   Mon Jul 13 18:11:13 2009 (4A5BBF11)
8c9de000 8c9e7000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 18:11:14 2009 (4A5BBF12)
8cce4000 8cd16000   fvevol   fvevol.sys   Mon Jul 13 18:13:01 2009 (4A5BBF7D)
8cc1e000 8cc4f000   fwpkclnt fwpkclnt.sys Mon Jul 13 18:12:03 2009 (4A5BBF43)
950dc000 950e1280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 07:16:53 2009 (4A1151B5)
83210000 83247000   hal      halmacpi.dll Mon Jul 13 18:11:03 2009 (4A5BBF07)
92960000 9297f000   HDAudBus HDAudBus.sys Mon Jul 13 18:50:55 2009 (4A5BC85F)
9297f000 92989080   HECI     HECI.sys     Thu Sep 17 14:54:12 2009 (4AB293E4)
98b35000 98b48000   HIDCLASS HIDCLASS.SYS Mon Jul 13 18:51:01 2009 (4A5BC865)
98b48000 98b4e480   HIDPARSE HIDPARSE.SYS Mon Jul 13 18:50:59 2009 (4A5BC863)
98b2a000 98b35000   hidusb   hidusb.sys   Mon Jul 13 18:51:04 2009 (4A5BC868)
9850d000 98592000   HTTP     HTTP.sys     Mon Jul 13 18:12:53 2009 (4A5BBF75)
8ccdc000 8cce4000   hwpolicy hwpolicy.sys Mon Jul 13 18:11:01 2009 (4A5BBF05)
8ca0e000 8ca20000   intelppm intelppm.sys Mon Jul 13 18:11:03 2009 (4A5BBF07)
8c68a000 8c6a5000   jraid    jraid.sys    Wed Jan 27 02:58:03 2010 (4B60001B)
951cf000 951dc000   kbdclass kbdclass.sys Mon Jul 13 18:11:15 2009 (4A5BBF13)
82338000 82344000   kbdhid   kbdhid.sys   Mon Jul 13 18:45:09 2009 (4A5BC705)
80bb6000 80bbe000   kdcom    kdcom.dll    Mon Jul 13 20:08:58 2009 (4A5BDAAA)
95000000 95034000   ks       ks.sys       Mon Jul 13 18:45:13 2009 (4A5BC709)
8c960000 8c973000   ksecdd   ksecdd.sys   Mon Jul 13 18:11:56 2009 (4A5BBF3C)
8ca64000 8ca89000   ksecpkg  ksecpkg.sys  Mon Jul 13 18:34:00 2009 (4A5BC468)
82379000 82389000   lltdio   lltdio.sys   Mon Jul 13 18:53:18 2009 (4A5BC8EE)
82344000 8235f000   luafv    luafv.sys    Mon Jul 13 18:15:44 2009 (4A5BC020)
8c20d000 8c285000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 20:06:41 2009 (4A5BDA21)
98b08000 98b13000   monitor  monitor.sys  Mon Jul 13 18:25:58 2009 (4A5BC286)
951dc000 951e9000   mouclass mouclass.sys Mon Jul 13 18:11:15 2009 (4A5BBF13)
8232d000 82338000   mouhid   mouhid.sys   Mon Jul 13 18:45:08 2009 (4A5BC704)
8c6a5000 8c6bb000   mountmgr mountmgr.sys Mon Jul 13 18:11:27 2009 (4A5BBF1F)
82200000 82212000   mpsdrv   mpsdrv.sys   Mon Jul 13 18:52:52 2009 (4A5BC8D4)
98b9a000 98bbd000   mrxsmb   mrxsmb.sys   Mon Jul 13 18:14:24 2009 (4A5BBFD0)
98bbd000 98bf8000   mrxsmb10 mrxsmb10.sys Mon Jul 13 18:14:34 2009 (4A5BBFDA)
98592000 985ad000   mrxsmb20 mrxsmb20.sys Mon Jul 13 18:14:29 2009 (4A5BBFD5)
8cc00000 8cc0b000   Msfs     Msfs.SYS     Mon Jul 13 18:11:26 2009 (4A5BBF1E)
8c5a4000 8c5ac000   msisadrv msisadrv.sys Mon Jul 13 18:11:09 2009 (4A5BBF0D)
8c935000 8c960000   msrpc    msrpc.sys    Mon Jul 13 18:11:59 2009 (4A5BBF3F)
90d66000 90d70000   mssmbios mssmbios.sys Mon Jul 13 18:19:25 2009 (4A5BC0FD)
8cccc000 8ccdc000   mup      mup.sys      Mon Jul 13 18:14:14 2009 (4A5BBFC6)
8c735000 8c7ec000   ndis     ndis.sys     Mon Jul 13 18:12:24 2009 (4A5BBF58)
95152000 9515d000   ndistapi ndistapi.sys Mon Jul 13 18:54:24 2009 (4A5BC930)
823cf000 823df000   ndisuio  ndisuio.sys  Mon Jul 13 18:53:51 2009 (4A5BC90F)
9515d000 9517f000   ndiswan  ndiswan.sys  Mon Jul 13 18:54:34 2009 (4A5BC93A)
9848c000 9849d000   NDProxy  NDProxy.SYS  Mon Jul 13 18:54:27 2009 (4A5BC933)
90cd0000 90cde000   netbios  netbios.sys  Mon Jul 13 18:53:54 2009 (4A5BC912)
90c67000 90c99000   netbt    netbt.sys    Mon Jul 13 18:12:18 2009 (4A5BBF52)
8ca26000 8ca64000   NETIO    NETIO.SYS    Mon Jul 13 18:12:35 2009 (4A5BBF63)
8cc0b000 8cc19000   Npfs     Npfs.SYS     Mon Jul 13 18:11:31 2009 (4A5BBF23)
90d5c000 90d66000   nsiproxy nsiproxy.sys Mon Jul 13 18:12:08 2009 (4A5BBF48)
82e00000 83210000   nt       ntkrpamp.exe Mon Jul 13 18:15:19 2009 (4A5BC007)
8c806000 8c935000   Ntfs     Ntfs.sys     Mon Jul 13 18:12:05 2009 (4A5BBF45)
8cd9d000 8cda4000   Null     Null.SYS     Mon Jul 13 18:11:12 2009 (4A5BBF10)
9847d000 9848b380   nusb3hub nusb3hub.sys Mon Oct 26 09:18:58 2009 (4AE5AFD2)
95082000 950a3600   nusb3xhc nusb3xhc.sys Mon Oct 26 09:19:00 2009 (4AE5AFD4)
9849d000 984c5000   nvhda32v nvhda32v.sys Tue Jan 17 06:45:27 2012 (4F156D67)
91e00000 92870000   nvlddmkm nvlddmkm.sys Wed Feb 29 11:59:51 2012 (4F4E6797)
82389000 823cf000   nwifi    nwifi.sys    Mon Jul 13 18:51:59 2009 (4A5BC89F)
90ca0000 90cbf000   pacer    pacer.sys    Mon Jul 13 18:53:58 2009 (4A5BC916)
8c5e1000 8c5f2000   partmgr  partmgr.sys  Mon Jul 13 18:11:35 2009 (4A5BBF27)
8c5b7000 8c5e1000   pci      pci.sys      Mon Jul 13 18:11:16 2009 (4A5BBF14)
8c675000 8c67c000   pciide   pciide.sys   Mon Jul 13 18:11:19 2009 (4A5BBF17)
8c67c000 8c68a000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 18:11:15 2009 (4A5BBF13)
8c9d0000 8c9de000   pcw      pcw.sys      Mon Jul 13 18:11:10 2009 (4A5BBF0E)
9fa01000 9fa98000   peauth   peauth.sys   Mon Jul 13 19:35:44 2009 (4A5BD2E0)
984c5000 984f4000   portcls  portcls.sys  Mon Jul 13 18:51:00 2009 (4A5BC864)
8c285000 8c296000   PSHED    PSHED.dll    Mon Jul 13 20:09:36 2009 (4A5BDAD0)
9513a000 95152000   rasl2tp  rasl2tp.sys  Mon Jul 13 18:54:33 2009 (4A5BC939)
9517f000 95197000   raspppoe raspppoe.sys Mon Jul 13 18:54:53 2009 (4A5BC94D)
95197000 951ae000   raspptp  raspptp.sys  Mon Jul 13 18:54:47 2009 (4A5BC947)
951ae000 951c5000   rassstp  rassstp.sys  Mon Jul 13 18:54:57 2009 (4A5BC951)
90d1b000 90d5c000   rdbss    rdbss.sys    Mon Jul 13 18:14:26 2009 (4A5BBFD2)
951c5000 951cf000   rdpbus   rdpbus.sys   Mon Jul 13 19:02:40 2009 (4A5BCB20)
8cde5000 8cded000   RDPCDD   RDPCDD.sys   Mon Jul 13 19:01:40 2009 (4A5BCAE4)
8cded000 8cdf5000   rdpencdd rdpencdd.sys Mon Jul 13 19:01:39 2009 (4A5BCAE3)
8cdf5000 8cdfd000   rdprefmp rdprefmp.sys Mon Jul 13 19:01:41 2009 (4A5BCAE5)
8cc9f000 8cccc000   rdyboost rdyboost.sys Mon Jul 13 18:22:02 2009 (4A5BC19A)
823df000 823f2000   rspndr   rspndr.sys   Mon Jul 13 18:53:20 2009 (4A5BC8F0)
9503d000 95082000   Rt86win7 Rt86win7.sys Thu Mar 04 07:42:33 2010 (4B8FB8C9)
98817000 98afd880   RTKVHDA  RTKVHDA.sys  Fri Mar 26 05:24:53 2010 (4BAC8B75)
8c536000 8c55c000   SCSIPORT SCSIPORT.SYS Mon Jul 13 18:45:55 2009 (4A5BC733)
9fa98000 9faa2000   secdrv   secdrv.SYS   Wed Sep 13 08:18:32 2006 (45080528)
950d2000 950dc000   serenum  serenum.sys  Mon Jul 13 18:45:27 2009 (4A5BC717)
90cde000 90cf8000   serial   serial.sys   Mon Jul 13 18:45:33 2009 (4A5BC71D)
8cc97000 8cc9f000   spldr    spldr.sys    Mon May 11 11:13:47 2009 (4A084EBB)
[U][B]8c43a000 8c52d000   sptd     [COLOR=#ff0000]sptd.sys[/COLOR]     Sun Oct 11 15:54:02 2009 (4AD245EA)[/B][/U]
9fb1f000 9fb70000   srv      srv.sys      Mon Jul 13 18:15:10 2009 (4A5BBFFE)
9fad0000 9fb1f000   srv2     srv2.sys     Mon Jul 13 18:14:52 2009 (4A5BBFEC)
9faa2000 9fac3000   srvnet   srvnet.sys   Mon Jul 13 18:14:45 2009 (4A5BBFE5)
951e9000 951ea380   swenum   swenum.sys   Mon Jul 13 18:45:08 2009 (4A5BC704)
8ca89000 8cbd2000   tcpip    tcpip.sys    Mon Jul 13 18:13:18 2009 (4A5BBF8E)
9fac3000 9fad0000   tcpipreg tcpipreg.sys Mon Jul 13 18:54:14 2009 (4A5BC926)
8cbe9000 8cbf4000   TDI      TDI.SYS      Mon Jul 13 18:12:12 2009 (4A5BBF4C)
8cbd2000 8cbe9000   tdx      tdx.sys      Mon Jul 13 18:12:10 2009 (4A5BBF4A)
90d0b000 90d1b000   termdd   termdd.sys   Mon Jul 13 19:01:35 2009 (4A5BCADF)
9a070000 9a079000   TSDDD    TSDDD.dll    unavailable (00000000)
8c600000 8c621000   tunnel   tunnel.sys   Mon Jul 13 18:54:03 2009 (4A5BC91B)
951eb000 951f9000   umbus    umbus.sys    Mon Jul 13 18:51:38 2009 (4A5BC88A)
98b13000 98b2a000   usbccgp  usbccgp.sys  Mon Jul 13 18:51:31 2009 (4A5BC883)
950a4000 950a5700   USBD     USBD.SYS     Mon Jul 13 18:51:05 2009 (4A5BC869)
929e0000 929ef000   usbehci  usbehci.sys  Mon Jul 13 18:51:14 2009 (4A5BC872)
98439000 9847d000   usbhub   usbhub.sys   Mon Jul 13 18:52:06 2009 (4A5BC8A6)
92995000 929e0000   USBPORT  USBPORT.SYS  Mon Jul 13 18:51:13 2009 (4A5BC871)
9298a000 92995000   usbuhci  usbuhci.sys  Mon Jul 13 18:51:10 2009 (4A5BC86E)
8c5ac000 8c5b7000   vdrvroot vdrvroot.sys Mon Jul 13 18:46:19 2009 (4A5BC74B)
8cdab000 8cdb7000   vga      vga.sys      Mon Jul 13 18:25:50 2009 (4A5BC27E)
8cdb7000 8cdd8000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 18:25:49 2009 (4A5BC27D)
8cc4f000 8cc57380   vmstorfl vmstorfl.sys Mon Jul 13 18:28:44 2009 (4A5BC32C)
8c400000 8c410000   volmgr   volmgr.sys   Mon Jul 13 18:11:25 2009 (4A5BBF1D)
8c62a000 8c675000   volmgrx  volmgrx.sys  Mon Jul 13 18:11:41 2009 (4A5BBF2D)
8cc58000 8cc97000   volsnap  volsnap.sys  Mon Jul 13 18:11:34 2009 (4A5BBF26)
82323000 8232d000   vwifibus vwifibus.sys Mon Jul 13 18:52:02 2009 (4A5BC8A2)
90cbf000 90cd0000   vwififlt vwififlt.sys Mon Jul 13 18:52:03 2009 (4A5BC8A3)
90cf8000 90d0b000   wanarp   wanarp.sys   Mon Jul 13 18:55:02 2009 (4A5BC956)
8cdd8000 8cde5000   watchdog watchdog.sys Mon Jul 13 18:24:10 2009 (4A5BC21A)
8c38b000 8c3fc000   Wdf01000 Wdf01000.sys Mon Jul 13 18:11:36 2009 (4A5BBF28)
8c42c000 8c43a000   WDFLDR   WDFLDR.SYS   Mon Jul 13 18:11:25 2009 (4A5BBF1D)
90c99000 90ca0000   wfplwf   wfplwf.sys   Mon Jul 13 18:53:51 2009 (4A5BC90F)
99e10000 9a05a000   win32k   win32k.sys   Mon Jul 13 18:26:26 2009 (4A5BC2A2)
8c52d000 8c536000   WMILIB   WMILIB.SYS   Mon Jul 13 18:11:22 2009 (4A5BBF1A)
8235f000 82379000   WudfPf   WudfPf.sys   Mon Jul 13 18:50:13 2009 (4A5BC835)
a366b2a8  8222e8a4*** WARNING: Unable to verify timestamp for AE2500w7.sys
*** ERROR: Module load completed but symbols could not be loaded for AE2500w7.sys
 AE2500w7+0x1a8a4
Also double check this program;
QvodTerminal.exe
Make sure you know what it is, what it does and why you are running it on your computer. May be perfectly innocent, I'm just not familar with it and naturally suspicious ( QvodTerminal.exe Windows process - What is it? )
