Windows 7 Frequent BSOD
BMcg
Every Time I either try and play an online video game or just browse the internet in normal mode. I receive a bsod upon either start up of the program or shortly afterwards. I have recently wiped my hard-drive, I've installed a new GPU and PCU. I've posted a zipped file with my dumps inside. Please help!
Please provide this information for a more complete analysis of your problem: Link Removed
Update your video drivers and your USB 3.0 drivers to the latest available version.
SP1 isn't installed, please do the following:
Installing Windows 7 Service Pack 1
1. Visit the PC manufacturer's website and update ALL drivers. DO NOT use Windows Update or the "Update drivers" function of Device Manager.
2. Check Device Manager for any unknown/disabled devices - if there are unknown/disabled devices, fix them with the latest drivers from the device manufacturer's website (not the PC Manufacturer)
3. Visit Windows Update and get all updates (may take repeated visits)
4. Visit Windows...
As you know, internet is surrounded by various kind of viruses. When you play games online, while processing in RAM, they also download on your computer. I suggest you to install an internet security program on your computer.
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1: Steps to follow before you install Windows 7 SP1 and Windows Server 2008 R2 SP1 from the Microsoft Download Center
5. Visit Windows Update and get any other available updates. May take repeated visits, but keep it up until you get several "Windows is updated" results.
If you're having difficulties with installing a Service Pack, please use the SURTool from this link: What is the System Update Readiness Tool?
Also, check out this troubleshooting link from Microsoft: Troubleshoot problems installing Service Pack 1 (SP1) for Windows 7 and Windows Server 2008 R2
I have had limited success in installing updates/Service Packs when using a "clean boot". I suspect that I'm just bypassing the problem - and that it can come back to bite me in the butt later on.
Analysis:
[font=lucida console]**************************Tue Sep 11 22:47:20.113 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091112-27721-01.dmp]
Windows 7 Kernel Version [B]7600 [/B]MP (4 procs) Free x64
Built by: [B]7600[/B].16385.amd64fre.win7_rtm.090713-1255
System Uptime:[B]0 days 0:01:33.830[/B]
BugCheck Code: [B]BugCheck 1000007E, {ffffffffc0000005, fffff800032d3254, fffff88008b33938, fffff88008b33190}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!PfpFlushBuffers+294 )[/B]
BugCheck Info: [B]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/B]
DEFAULT_BUCKET_ID:  NULL_DEREFERENCE
PROCESS_NAME: [B]System[/B]
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_nt!PfpFlushBuffers+294[/B]
  BIOS Version                  1503
  BIOS Release Date             08/19/2010
**************************Tue Sep 11 22:43:37.071 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091112-34117-01.dmp]
System Uptime:[B]0 days 0:01:38.397[/B]
BugCheck Code: [B]BugCheck D1, {8, 2, 1, fffff88000db1e46}[/B]
Probably caused by :[B]ataport.SYS ( ataport!AtaPortGetParentBusType+270e )[/B]
BugCheck Info: [B]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/B]
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_ataport!AtaPortGetParentBusType+270e[/B]
  BIOS Version                  1503
**************************Tue Sep 11 22:23:09.000 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091112-24632-01.dmp]
System Uptime:[B]0 days 0:02:49.717[/B]
BugCheck Code: [B]BugCheck 50, {ffffffffffffffff, 0, fffff800032df02f, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!PfpFlushBuffers+6f )[/B]
BugCheck Info: [B]PAGE_FAULT_IN_NONPAGED_AREA (50)[/B]
BUGCHECK_STR:  0x50
FAILURE_BUCKET_ID: [B]X64_0x50_nt!PfpFlushBuffers+6f[/B]
  BIOS Version                  1503
**************************Tue Sep 11 22:19:20.160 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091112-27580-01.dmp]
System Uptime:[B]0 days 0:02:29.876[/B]
BugCheck Code: [B]BugCheck C5, {8, 2, 0, fffff80002fc30bf}[/B]
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+233 )[/B]
BugCheck Info: [B]DRIVER_CORRUPTED_EXPOOL (c5)[/B]
BUGCHECK_STR:  0xC5_2
PROCESS_NAME: [B]LolClient.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xC5_2_nt!ExDeferredFreePool+233[/B]
  BIOS Version                  1503
**************************Fri Sep  7 18:22:05.543 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090712-16364-01.dmp]
System Uptime:[B]0 days 0:02:34.259[/B]
BugCheck Code: [B]BugCheck 1000007E, {ffffffffc0000005, fffff8000308aa84, fffff880031bda18, fffff880031bd270}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!PfSnCleanupTrace+24 )[/B]
BUGCHECK_STR:  0x7E
DEFAULT_BUCKET_ID:  NULL_CLASS_PTR_DEREFERENCE
FAILURE_BUCKET_ID: [B]X64_0x7E_nt!PfSnCleanupTrace+24[/B]
  BIOS Version                  1503
**************************Fri Sep  7 18:18:45.284 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090712-16645-01.dmp]
System Uptime:[B]0 days 0:02:19.001[/B]
BugCheck Code: [B]BugCheck 34, {50830, fffff88002f857f8, fffff88002f85050, fffff80002dbf90d}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ExAllocatePoolWithTag+53d )[/B]
BugCheck Info: [B]CACHE_MANAGER (34)[/B]
BUGCHECK_STR:  0x34
FAILURE_BUCKET_ID: [B]X64_0x34_nt!ExAllocatePoolWithTag+53d[/B]
  BIOS Version                  1503
**************************Fri Sep  7 18:02:29.995 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090712-21996-01.dmp]
System Uptime:[B]0 days 0:02:25.711[/B]
BugCheck Code: [B]BugCheck D1, {8, 2, 1, fffff88000e11e46}[/B]
BUGCHECK_STR:  0xD1
  BIOS Version                  1503
**************************Fri Sep  7 17:58:54.273 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090712-25443-01.dmp]
System Uptime:[B]0 days 0:02:40.599[/B]
BugCheck Code: [B]BugCheck 19, {3, fffffa8006bd5410, fffffa8006bd5410, fffffa8006bf5410}[/B]
Probably caused by :[B]Pool_Corruption ( nt!ExFreePool+75b )[/B]
BugCheck Info: [B]BAD_POOL_HEADER (19)[/B]
BUGCHECK_STR:  0x19_3
PROCESS_NAME: [B]sppsvc.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x19_3_nt!ExFreePool+75b[/B]
  BIOS Version                  1503
[/font]
3rd Party Drivers:
[B]amdxata.sys                 Tue May 19 13:56:59 2009 (4A12F2EB)[/B]
ASACPI.sys                  Wed Jul 15 23:31:29 2009 (4A5E9F11)
AsIO.sys                    Mon Aug  3 03:03:16 2009 (4A768BB4)
AtiPcie.sys                 Mon Aug 24 04:25:26 2009 (4A924E76)
nusb3hub.sys                Thu Apr 22 21:34:35 2010 (4BD0F92B)
nusb3xhc.sys                Thu Apr 22 21:34:36 2010 (4BD0F92C)
Rt64win7.sys                Wed Jun 23 05:10:45 2010 (4C21CF95)
RTKVHD64.sys                Tue Jul  6 06:05:16 2010 (4C32FFDC)
nvhda64v.sys                Tue May 10 05:41:18 2011 (4DC9083E)
nvBridge.kmd                Fri May 20 23:58:23 2011 (4DD7385F)
nvlddmkm.sys                Sat May 21 00:07:04 2011 (4DD73A68)
avgfwd6a.sys                Sun May 22 18:33:25 2011 (4DD98F35)
usbfilter.sys               Fri Mar 30 23:48:56 2012 (4F767EA8)
avgtpx64.sys                Thu Jul 19 10:07:13 2012 (50081491)
avgidsha.sys                Thu Aug  9 07:43:57 2012 (5023A27D)
avgldx64.sys                Thu Aug  9 07:45:04 2012 (5023A2C0)
avgloga.sys                 Thu Aug  9 07:45:25 2012 (5023A2D5)
avgmfx64.sys                Thu Aug  9 22:33:51 2012 (5024730F)
avgrkx64.sys                Thu Aug  9 22:33:54 2012 (50247312)
avgtdia.sys                 Thu Aug  9 22:35:19 2012 (50247367)
avgidsdrivera.sys           Mon Aug 13 10:28:50 2012 (50290F22)
[/font]
Link Removed - Invalid URL
avgloga.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
