Windows 7 Frequent BSOD's...please help!
laugh039
Frequent BSOD's...please help! :confused::confused: It appears to be a driver issue but I don't know what to do about it. I attached all of the requested files from the "how to ask for help with a bsod problem" thread.
Thanks in advance!:DLink Removed
Nothing significant of note in the MSINFO32 files, so it's safe to assume that this is most likely a driver problem with the wifi card.
This should be the link for the Intel(R) Centrino(R) Wireless-N 2230 for 64 bit Windows 7: Link Removed
Some reports are missing from the uploaded files. Please provide this:
MSINFO32:
Please go to Start and type in "msinfo32.exe" (without the quotes) and press Enter
Save the report as an .nfo file, then zip up the .nfo file and upload/attach the .zip file with your next post.
Also, save a copy as a .txt file and include it also (it's much more difficult to read, but we have greater success in getting the info from it).
If you're having difficulties with the format, please open an elevated (Run as administrator) Command Prompt and type "msinfo32 /nfo C:\Users\Public\Desktop\TEST.NFO" (without the quotes) and press Enter. Then navigate to the C:\Users\Public\Desktop directory to retrieve the TEST.NFO file. If you have difficulties with making this work, please post back.
The memory dumps primarily blame Netwsw00.sys - a driver component of your Intel® Wireless WiFi Link Adapter. Please:
- download a fresh copy of the latest available Win7 compatible driver from Link Removed
- un-install the current driver
- install the freshly downloaded drivers
- monitor for further BSOD's
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Sat Mar 30 19:12:08.030 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\033013-25162-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]1 days 17:29:27.247[/B]
Probably caused by :[B]memory_corruption ( nt!MiCheckSpecialPoolSlop+83 )[/B]
BugCheck [B]C1, {fffff9808a6fef10, fffff9808a6feb5e, 4740f0, 32}[/B]
BugCheck Info: [B]Link Removed[/B]
Arguments:
Arg1: fffff9808a6fef10, address trying to free
Arg2: fffff9808a6feb5e, address where one bit is corrupted
Arg3: 00000000004740f0, (reserved)
Arg4: 0000000000000032, caller is freeing an address where nearby bytes within the same page have a single bit error
BUGCHECK_STR:  0xC1_32
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]X64_0xC1_32_VRFK_nt!MiCheckSpecialPoolSlop+83[/B]
CPUID:        "Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz"
MaxSpeed:     2500
CurrentSpeed: [B]2494[/B]
  BIOS Version                  F.03
  BIOS Release Date             05/03/2012
  Manufacturer                  Hewlett-Packard
  Product Name                  HP Pavilion m6 Notebook PC
**************************Tue Mar 26 22:37:04.306 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-28875-01.dmp]
System Uptime:[B]0 days 0:05:56.523[/B]
BugCheck [B]C1, {fffff98065162f70, fffff98065162b5e, 31c098, 32}[/B]
Arguments:
Arg1: fffff98065162f70, address trying to free
Arg2: fffff98065162b5e, address where one bit is corrupted
Arg3: 000000000031c098, (reserved)
PROCESS_NAME:  svchost.exe
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Tue Mar 26 18:27:59.763 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-38469-01.dmp]
System Uptime:[B]0 days 0:31:56.996[/B]
BugCheck [B]C1, {fffff98016dcef10, fffff98016dceb5e, 3540f0, 32}[/B]
Arguments:
Arg1: fffff98016dcef10, address trying to free
Arg2: fffff98016dceb5e, address where one bit is corrupted
Arg3: 00000000003540f0, (reserved)
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Mon Mar 25 21:09:20.935 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-21465-01.dmp]
System Uptime:[B]0 days 1:20:50.168[/B]
*** ERROR: Module load completed but symbols could not be loaded for pci.sys
Probably caused by :[B]pci.sys[/B]
BugCheck [B]9F, {3, fffffa8007b06a10, fffff80000b9c3d8, fffffa800c11a010}[/B]
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8007b06a10, Physical Device Object of the stack
Arg3: fffff80000b9c3d8, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800c11a010, The blocked IRP
BUGCHECK_STR:  0x9F
FAILURE_BUCKET_ID: [B]X64_0x9F_3_Netwsw00_IMAGE_pci.sys[/B]
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Thu Mar 14 06:46:05.996 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031413-19702-01.dmp]
System Uptime:[B]0 days 10:40:24.230[/B]
Probably caused by :[B]tcpip.sys ( tcpip!FlPnpEvent+17d )[/B]
BugCheck [B]1000009F, {4, 258, fffffa8007000040, fffff80004f853d0}[/B]
Arguments:
Arg1: 0000000000000004, The power transition timed out waiting to synchronize with the Pnp
    subsystem.
Arg2: 0000000000000258, Timeout in seconds.
Arg3: fffffa8007000040, The thread currently holding on to the Pnp lock.
Arg4: fffff80004f853d0, nt!TRIAGE_9F_PNP on Win7
BUGCHECK_STR:  0x9F
FAILURE_BUCKET_ID: [B]X64_0x9F_4_tcpip!FlPnpEvent+17d[/B]
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Wed Mar 13 11:58:14.813 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031313-20482-01.dmp]
System Uptime:[B]0 days 0:49:40.046[/B]
BugCheck [B]9F, {3, fffffa80079bc060, fffff80004f8b748, fffffa8011541010}[/B]
Arguments:
Arg2: fffffa80079bc060, Physical Device Object of the stack
Arg3: fffff80004f8b748, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8011541010, The blocked IRP
BUGCHECK_STR:  0x9F
PROCESS_NAME:  avp.exe
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Mon Mar 11 00:32:29.281 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-18127-01.dmp]
System Uptime:[B]0 days 10:51:31.514[/B]
Probably caused by :[B]win32k.sys ( win32k!memset+16d4 )[/B]
BugCheck [B]1A, {41790, fffffa8003197610, ffff, 0}[/B]
Arguments:
Arg1: 0000000000041790, A page table page has been corrupted. On a 64 bit OS, parameter 2
    contains the address of the PFN for the corrupted page table page.
    On a 32 bit OS, parameter 2 contains a pointer to the number of used
    PTEs, and parameter 3 contains the number of used PTEs.
Arg2: fffffa8003197610
Arg3: 000000000000ffff
Arg4: 0000000000000000
BUGCHECK_STR:  0x1a_41790
PROCESS_NAME:  chrome.exe
FAILURE_BUCKET_ID: [B]X64_0x1a_41790_win32k!memset+16d4[/B]
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Sun Mar 10 13:39:09.778 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\031013-29686-01.dmp]
System Uptime:[B]1 days 21:59:01.577[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35084 )[/B]
Arguments:
PROCESS_NAME:  IEWebSiteLogon
FAILURE_BUCKET_ID: [B]X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+35084[/B]
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Fri Mar  8 15:19:57.829 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030813-17862-01.dmp]
System Uptime:[B]0 days 20:21:10.062[/B]
BugCheck [B]9F, {3, fffffa80079bfa10, fffff80004f853d8, fffffa8007619810}[/B]
Arguments:
Arg2: fffffa80079bfa10, Physical Device Object of the stack
Arg3: fffff80004f853d8, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8007619810, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Thu Mar  7 17:53:50.766 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-24117-01.dmp]
System Uptime:[B]0 days 6:45:09.999[/B]
BugCheck [B]9F, {3, fffffa80079e1060, fffff80004f853d8, fffffa8013419a90}[/B]
Arguments:
Arg2: fffffa80079e1060, Physical Device Object of the stack
Arg4: fffffa8013419a90, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Thu Mar  7 04:51:15.141 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-22323-01.dmp]
System Uptime:[B]0 days 7:12:40.984[/B]
BugCheck [B]9F, {3, fffffa8007b0a060, fffff80000b9c3d8, fffffa80104eb3b0}[/B]
Arguments:
Arg2: fffffa8007b0a060, Physical Device Object of the stack
Arg4: fffffa80104eb3b0, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Wed Mar  6 21:31:37.156 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030613-25006-01.dmp]
System Uptime:[B]0 days 5:45:10.389[/B]
BugCheck [B]9F, {3, fffffa80079bba10, fffff80004f8c3d8, fffffa800ee88780}[/B]
Arguments:
Arg2: fffffa80079bba10, Physical Device Object of the stack
Arg3: fffff80004f8c3d8, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800ee88780, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Wed Mar  6 10:39:46.163 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030613-23712-01.dmp]
System Uptime:[B]0 days 8:06:37.006[/B]
BugCheck [B]9F, {3, fffffa8007b43a10, fffff80000b9c3d8, fffffa800e290980}[/B]
Arguments:
Arg2: fffffa8007b43a10, Physical Device Object of the stack
Arg4: fffffa800e290980, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Tue Mar  5 22:53:45.464 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030513-22604-01.dmp]
System Uptime:[B]1 days 2:32:13.697[/B]
BugCheck [B]9F, {3, fffffa8007b43060, fffff80000b9c3d8, fffffa80101cdc10}[/B]
Arguments:
Arg2: fffffa8007b43060, Physical Device Object of the stack
Arg4: fffffa80101cdc10, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2500
  BIOS Version                  F.03
**************************Mon Mar  4 10:45:35.081 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030413-32541-01.dmp]
System Uptime:[B]0 days 12:02:09.924[/B]
BugCheck [B]9F, {3, fffffa8007b24060, fffff80004f8b748, fffffa8011ba9c10}[/B]
Arguments:
Arg2: fffffa8007b24060, Physical Device Object of the stack
Arg4: fffffa8011ba9c10, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     2500
  BIOS Version                  F.03
[/font]
3rd Party Drivers:
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
clwvd.sys                   Tue Jul 27 21:13:47 2010 (4C4F844B)
ElbyCDIO.sys                Thu Dec 16 17:58:13 2010 (4D0A9985)
VClone.sys                  Sat Jan 15 11:21:04 2011 (4D31C970)
iwdbus.sys                  Wed Mar  9 18:43:23 2011 (4D78109B)
ISCTD64.sys                 Tue Aug 23 13:32:39 2011 (4E53E437)
WPRO_41_2001.sys            Mon Nov  7 16:04:48 2011 (4EB847F0)
HECIx64.sys                 Wed Nov  9 19:52:25 2011 (4EBB2049)
btmaud.sys                  Wed Nov 30 02:09:26 2011 (4ED5D6A6)
btmaux.sys                  Wed Nov 30 02:09:32 2011 (4ED5D6AC)
btmhsf.sys                  Wed Nov 30 02:10:31 2011 (4ED5D6E7)
IntcDAud.sys                Tue Dec  6 06:23:07 2011 (4EDDFB1B)
ikbevent.sys                Tue Jan  3 19:35:09 2012 (4F039EBD)
imsevent.sys                Tue Jan  3 19:35:31 2012 (4F039ED3)
hswpan.sys                  Fri Jan  6 06:56:35 2012 (4F06E173)
iusb3hub.sys                Fri Jan 27 04:35:25 2012 (4F226FDD)
iusb3xhc.sys                Fri Jan 27 04:35:28 2012 (4F226FE0)
iusb3hcs.sys                Fri Jan 27 04:37:23 2012 (4F227053)
iaStor.sys                  Wed Feb  1 19:15:24 2012 (4F29D59C)
iBtFltCoex.sys              Tue Feb 14 15:38:54 2012 (4F3AC65E)
hpdskflt.sys                Wed Feb 22 11:30:18 2012 (4F45181A)
Accelerometer.sys           Wed Feb 22 11:30:18 2012 (4F45181A)
igdkmd64.sys                Tue Feb 28 03:55:17 2012 (4F4C9675)
stwrt64.sys                 Mon Mar  5 21:11:10 2012 (4F55723E)
RtsBaStor.sys               Wed Mar  7 22:25:17 2012 (4F58269D)
Rt64win7.sys                Fri Mar  9 07:40:37 2012 (4F59FA45)
AMPPAL.sys                  Thu Mar 15 09:02:45 2012 (4F61E875)
SynTP.sys                   Mon Mar 26 20:26:45 2012 (4F710945)
Smb_driver_Intel.sys        Mon Mar 26 20:28:15 2012 (4F71099F)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
Netwsw00.sys                Sun Jun  3 11:33:40 2012 (4FCB83D4)
aswRvrt.sys                 Wed Mar  6 18:21:43 2013 (5137CF87)
aswFsBlk.SYS                Wed Mar  6 18:22:01 2013 (5137CF99)
aswMonFlt.sys               Wed Mar  6 18:22:08 2013 (5137CFA0)
aswTdi.SYS                  Wed Mar  6 18:22:10 2013 (5137CFA2)
aswrdr2.sys                 Wed Mar  6 18:22:24 2013 (5137CFB0)
aswSP.SYS                   Wed Mar  6 18:23:05 2013 (5137CFD9)
aswSnx.SYS                  Wed Mar  6 18:23:10 2013 (5137CFDE)
aswVmm.SYS                  Wed Mar  6 18:21:46 2013 (5137CF8A)
kl1.sys                     Tue Jun 19 09:27:15 2012 (4FE07E33)
klim6.sys                   Thu Aug  2 07:09:23 2012 (501A5FE3)
klflt.sys                   Fri Aug  3 12:10:13 2012 (501BF7E5)
kneps.sys                   Mon Aug 13 08:45:42 2012 (5028F6F6)
klkbdflt.sys                Mon Sep  3 09:55:35 2012 (5044B6D7)
klmouflt.sys                Mon Sep  3 10:21:58 2012 (5044BD06)
kltdi.sys                   Thu Oct 18 06:50:34 2012 (507FDEFA)
klif.sys                    Fri Nov  2 07:41:30 2012 (5093B16A)
kltdi.sys                   Fri Jun  8 03:38:01 2012 (4FD1ABD9)
klif.sys                    Thu Sep  6 09:20:19 2012 (5048A313)
[/font]
aswRvrt.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
aswrdr2.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
aswVmm.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
Thanks for your response usasma. :D
Here is the msinfo32 NFO file you asked for: Link Removed
-I went to the Intel download center and I'm not sure which specific product I need. Is the automatic Intel® Driver Update Utility a reliable tool?
-Where do I uninstall/install these drivers? I searched Netwsw00.sys with no results.
