rayder
Hey guys, i'm trying to work out whats going on with my pc. It crashes fairly regularly but i have no idea how to find out whats wrong. I've attached a rar file with all of the minidumps, info from sf diagnostic tool, cpuz screen shots and the html export from rammon. I did however do a Memtest86+ test last night for almost 12 hours and it came up with no errors at all. There doesn't seem to be any one thing that causes the BSOD as most of the time i'll jump on my pc in the morning to find out it BSOD'D during the night and reset itself and is now patiently waiting for me to log in. Don't know if it means anything or not but for a quad core system with 4gb or ram, it appears to run really slow alot of the time. Any other info you need just ask. Thanks in advance guys.
Maybe start with your System BIOS possibly here Link Removed
And follow up with these
[TABLE="width: 1470"]
[TR]
[TD]hardlock.sys[/TD]
[TD="align: right"]11/30/2006[/TD]
[TD]Hardlock Device Driver by Aladdin KnowledgeSystems[/TD]
[TD]http://www.aladdin.co.il/support/default.aspx[/TD]
[/TR]
[TR]
[TD]pcouffin.sys[/TD]
[TD="align: right"]12/5/2006[/TD]
[TD]part of many different CD/DVD burning programs[/TD]
[TD]Update, uninstall or rename[/TD]
[/TR]
[TR]
[TD]aksdf.sys[/TD]
[TD="align: right"]12/13/2006[/TD]
[TD]Data Filter Driver by Aladdin Knowledge Systems[/TD]
[/TR]
[TR]
[TD]Rtnic64.sys[/TD]
[TD="align: right"]3/31/2008[/TD]
[TD]Realtek Ethernet NIC driver[/TD]...
Hi, I had a quick look at your dumps and your drivers need updating. Also are you running Daemon tools? If so, please remove it as it can cause blue screens.
can you tell which drivers? I dont use daemon tools but i do use PowerISO. That doesnt cause problems as well does it?
All your drivers need updating if I remember correctly. If you need links etc then please post back.
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]aksdf.sys[/TD]
[/TR]
[TR]
[TD]http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false[/TD]
[/TR]
[TR]
[TD]RTKVHD64.sys[/TD]
[TD="align: right"]5/20/2008[/TD]
[TD]Realtek High Definition Audio Function Driver[/TD]
[TD]http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=8&PFid=14&Level=3&Conn=2[/TD]
[/TR]
[TR]
[TD]LHidFilt.Sys[/TD]
[TD="align: right"]6/17/2009[/TD]
[TD]Logitech SetPoint HID Filter Driver[/TD]
[TD]http://www.logitech.com/en-us/support-downloads/downloads[/TD]
[/TR]
[TR]
[TD]LMouFilt.Sys[/TD]
[/TR]
[/TABLE]
Your CPU voltage might be low. Disable all power saving features in BIOS and try again
