Hi, I`m running FSX in W7 and I noticed an issue about hatswitch (view pan) when using my logitech rumble pad 2 and it is not enabled the "Z" fix to move the camera. I have my HD partitioned and in one partition have Win XP SP3 and in the other W7. When I run FSX under W XP I see no problem with hatswitch, I looked into controls settings and I see view - left/right and up/down axis under "Calibration - sensitivity and null zone" panel but when I run FSX under W7 I cant see this options enabled. I,ve tried re installing FSX in W7 but it didnt solve the problem.
If you have the same problem or know how to solve this issue I will apprecitatte. I also notices a slight better performance for FSX in W7 than W XP but it is barely perceptible.
Thanks
Intel core 2 Quad 3.00, 4Gb OCZ ddr2, nforce 680iLt sli ready motherboard, GPU Gforce 8600 512 mgb.
I attached a graphic to see the difference
Thanks
