Only 94 updates since SP1 - most systems have 130 to 140. Please visit Windows Updates and get all available updates.
Have seen a lot of issues recently with RAID array's on single drives in Dell systems. Breaking the RAID array and installing Windows without using RAID has fixed it for us. (I'm not suggesting this right now - just posting it FYI in case you decide to reinstall Windows).
The memory dump blames video drivers - please follow this procedure to install the Drivers Only:
McAfee drivers date from 2011, please try this to rule out McAfee:
Anti-Virus Removal:
Please do the following:
- download a free antivirus for testing purposes: Link Removed - Invalid URL
- un-install the McAfee from your system (you can reinstall it, if so desired, when we're done troubleshooting)
- remove any remnants of McAfee using this free tool: Link Removed (This link has changed a lot. If it doesn't work, search for McAfee Consumer Products Removal Tool)
- IMMEDIATELY install and update the free antivirus, then check to ensure that the Windows Firewall is turned on.
- check to see if this fixes the BSOD's
NOTE: NEVER run more than 1 anti-virus, firewall, Internet Security/Security Center application at the same time.
Although I'm going to suggest a bunch of driver updates - I'd also have to wonder if this is a hardware issue. As such, I'd suggest the free diagnostics here:
Rt64win7.sys Fri May 22 10:52:30 2009 (4A16BC2E)
Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC
jraid.sys Wed May 27 01:39:35 2009 (4A1CD217)
JMicron RAID Driver
RtsUStor.sys Thu Jun 4 04:46:49 2009 (4A2789F9)
Realtek USB Card Reader
iaStor.sys Thu Jun 4 21:53:40 2009 (4A287AA4)
Intel Storage drivers
usbcir.sys Mon Jul 13 20:06:36 2009 (4A5BCC0C)
ENE USB Consumer IR Driver for eHome
RTKVHD64.sys Fri Oct 2 07:09:59 2009 (4AC5DF87)
Realtek High Definition Audio Function Driver
athrx.sys Fri Oct 23 21:49:44 2009 (4AE25D38)
Atheros network adapter driver
Analysis:
[font=lucida console]**************************Fri Oct 5 04:01:21.850 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\100512-18127-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 6:46:26.865[/B]
BugCheck Code: [B]BugCheck 1E, {0, 0, 0, 0}[/B]
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
*** WARNING: Unable to verify checksum for win32k.sys
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VidSchiProcessDpcCompletedPacket+3a5 )[/B]
BugCheck Info: [B]KMODE_EXCEPTION_NOT_HANDLED (1e)[/B]
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0x1E
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_dxgmms1!VidSchiProcessDpcCompletedPacket+3a5[/B]
CPUID: "Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz"
MaxSpeed: 2670
CurrentSpeed: [B]2660[/B]
BIOS Version A16
BIOS Release Date 02/04/2010
Manufacturer DELL Inc.
Product Name Studio XPS 435T/9000
[/font]
3rd Party Drivers:
[B]Rt64win7.sys Fri May 22 10:52:30 2009 (4A16BC2E)[/B]
[B]jraid.sys Wed May 27 01:39:35 2009 (4A1CD217)[/B]
[B]RtsUStor.sys Thu Jun 4 04:46:49 2009 (4A2789F9)[/B]
[B]iaStor.sys Thu Jun 4 21:53:40 2009 (4A287AA4)[/B]
[B]PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)[/B]
intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[B]usbcir.sys Mon Jul 13 20:06:36 2009 (4A5BCC0C)[/B]
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
mfehidk.sys Wed Mar 2 11:38:02 2011 (4D6E726A)
mfewfpk.sys Wed Mar 2 11:38:16 2011 (4D6E7278)
mfenlfk.sys Wed Mar 2 11:38:26 2011 (4D6E7282)
mfeapfk.sys Wed Mar 2 11:38:39 2011 (4D6E728F)
mfeavfk.sys Wed Mar 2 11:39:02 2011 (4D6E72A6)
mfefirek.sys Wed Mar 2 11:42:01 2011 (4D6E7359)
cfwids.sys Wed Mar 2 11:42:51 2011 (4D6E738B)
AtihdW76.sys Fri May 11 04:25:40 2012 (4FACCD04)
atikmpag.sys Fri Jul 27 21:14:47 2012 (50133D07)
atikmdag.sys Fri Jul 27 21:48:09 2012 (501344D9)
[/font]
