Giga Computing’s appearance at the OCP Global Summit and the debut of the OCP‑based GIGABYTE TO86‑SD1 mark a clear step toward making rack‑scale Blackwell‑class GPU servers more broadly accessible to cloud providers, enterprises, and research institutions focused on large‑scale AI and HPC workloads.
Giga Computing — the GIGABYTE subsidiary responsible for enterprise servers, high‑density trays and advanced cooling systems — used the OCP Global Summit platform to highlight an expanding catalogue of HGX B200‑based systems and ORv3 (Open Rack v3)‑aligned designs intended for modern AI datacenters. The new TO86 family, exemplified by the TO86‑SD1 configuration, targets 8‑GPU HGX deployments built around NVIDIA’s Blackwell architecture while offering front‑accessible expansion, Gen5 NVMe bays, and compatibility with modern DPUs and SuperNICs. This push follows earlier Giga Computing/GIGABYTE launches of air‑ and liquid‑cooled servers using HGX B200 and sits inside a broader industry trend that emphasizes standardized, open‑rack hardware to reduce custom engineering burden for tier‑2 cloud and enterprise buyers.
The announcement is notable because it blends three industry vectors that matter today: 1) NVIDIA’s HGX B200 reference platform for 8‑GPU Blackwell systems, 2) OCP ORv3 rack/tray standards that simplify integration at scale, and 3) server designs that anticipate modern networking and DPU offload (BlueField‑3, ConnectX‑7). Together these aim to lower the integration and operational cost of high‑performance GPU clusters while offering a path to higher energy efficiency and denser compute.
That pooled HBM approach is the reason big racks (NVL72/GB300 style) can function like a single enormous accelerator for both training and inference. Giga Computing’s TO86 path makes that capability available in a smaller ORv3‑compatible footprint for customers who want the benefits of HGX memory pooling without building completely bespoke rack systems.
However, buyers must be disciplined. The most important next steps for prospective customers are: validate with your own models, plan for facility power and cooling, insist on workload‑matched benchmarks, and secure supply‑chain and portability protections. When these boxes are checked, the TO86 family (and the broader GIGABYTE HGX B200 portfolio) is a viable and competitive route to next‑generation AI and HPC capacity that sits squarely between costly hyperscaler bespoke systems and fragmentary PCIe‑GPU farms.
Giga Computing’s OCP summit presence and the TO86 launch are a signal that high‑memory, NVLink‑coherent GPU systems are moving into standardized, deployable product lines — an important evolution for regional cloud providers, research institutions, and enterprises that need frontier GPU capability without the enterprise expense or engineering lift of custom rack design.
Source: TechPowerUp Giga Computing Joins OCP Global Summit and Debuts New OCP-based GIGABYTE Server
Background / Overview
Giga Computing — the GIGABYTE subsidiary responsible for enterprise servers, high‑density trays and advanced cooling systems — used the OCP Global Summit platform to highlight an expanding catalogue of HGX B200‑based systems and ORv3 (Open Rack v3)‑aligned designs intended for modern AI datacenters. The new TO86 family, exemplified by the TO86‑SD1 configuration, targets 8‑GPU HGX deployments built around NVIDIA’s Blackwell architecture while offering front‑accessible expansion, Gen5 NVMe bays, and compatibility with modern DPUs and SuperNICs. This push follows earlier Giga Computing/GIGABYTE launches of air‑ and liquid‑cooled servers using HGX B200 and sits inside a broader industry trend that emphasizes standardized, open‑rack hardware to reduce custom engineering burden for tier‑2 cloud and enterprise buyers. The announcement is notable because it blends three industry vectors that matter today: 1) NVIDIA’s HGX B200 reference platform for 8‑GPU Blackwell systems, 2) OCP ORv3 rack/tray standards that simplify integration at scale, and 3) server designs that anticipate modern networking and DPU offload (BlueField‑3, ConnectX‑7). Together these aim to lower the integration and operational cost of high‑performance GPU clusters while offering a path to higher energy efficiency and denser compute.
What Giga Computing showed: the TO86 family and ecosystem
The TO86‑SD1 in brief
The TO86‑SD1 is presented as an ORv3 (Open Rack v3) compatible, 8OU GPU server that integrates an NVIDIA HGX B200 baseboard and supports:- 8x NVIDIA Blackwell SXM GPUs (HGX B200 form factor) with a total of roughly 1.4 TB HBM3e across the GPUs, enabling very large pooled GPU memory working sets.
- Dual Intel Xeon 6700/6500‑series processors (server CPUs), supporting up to 32 DIMM slots per node (8‑channel DDR5 per CPU) to keep the host side balanced for data‑feeding and pre/post processing.
- Front‑accessible I/O and expansion: 12 front PCIe Gen5 FHHL slots (x16), and 8 hot‑swap 2.5" Gen5 NVMe bays for front serviceability — an OCP‑friendly design choice for rack operators.
- DPU / SuperNIC compatibility with NVIDIA BlueField‑3 DPUs and ConnectX‑7 NICs for high‑bandwidth, low‑latency fabrics and in‑network acceleration.
- Management and OS compatibility including Windows Server, RHEL, Ubuntu, Citrix, VMware ESXi, and other industry OS stacks (as listed on product pages and press materials).
Where this fits in GIGABYTE’s portfolio
Giga Computing’s announcement did not appear in isolation. It expands an existing line of HGX B200‑based products that GIGABYTE has been shipping in multiple thermal flavors:- 8U air‑cooled HGX systems for customers prioritizing easier field maintenance and standard data center cooling.
- 4U liquid‑cooled variants where thermal density and energy efficiency matter more aggressively (e.g., GPU farms and AI factories).
- Rack‑scale NVL/GB‑class systems such as GIGABYTE’s GB300/GB200 family that tie many GPUs and CPs together in a rack fabric for large pooled memory and NVSwitch/NVLink coherence.
Technical deep dive: what the HGX B200 base brings
Blackwell, HBM3e and the pooled memory advantage
NVIDIA’s HGX B200 is a reference platform built around eight Blackwell SXM GPUs and an NVSwitch fabric that glues them into a single coherent accelerator domain. The headline number most buyers need to know is ~1.4 TB total HBM3e pooled across the rack’s eight SXM GPUs — this is what enables single‑node working sets that are orders of magnitude larger than previous generations of 4‑GPU or PCIe‑attached setups. The HGX architecture also offers extremely high NVLink/NVSwitch bandwidth (multi‑terabytes/sec inter‑GPU), which reduces the need for complex model sharding across hosts and cuts synchronization overhead for attention‑heavy models.That pooled HBM approach is the reason big racks (NVL72/GB300 style) can function like a single enormous accelerator for both training and inference. Giga Computing’s TO86 path makes that capability available in a smaller ORv3‑compatible footprint for customers who want the benefits of HGX memory pooling without building completely bespoke rack systems.
CPU, PCIe Gen5 and host bandwidth
The inclusion of Intel Xeon 6700/6500‑series CPUs aligns with the need to provide enough host compute, DMA channels and PCIe Gen5 lanes to feed the accelerator fabric — dual CPUs, DDR5 channels and up to 12 PCIe Gen5 slots on the front panel give operators room to add DPUs, NVMe controllers, and other accelerators while preserving host‑side bandwidth for I/O, preprocessing, and orchestration tasks. GIGABYTE’s product sheet for the TO86 models documents these platform choices explicitly.Networking and DPU considerations
Modern large‑model workflows increasingly rely on offload to DPUs and SmartNICs for telemetry, security, and network‑level collective operations. The TO86 design’s compatibility with BlueField‑3 DPUs and ConnectX‑7 NICs means operators can deploy advanced zero‑trust, telemetry, and in‑network reduction/offload functions without swapping server form factors. This helps when scaling to multi‑node clusters or when adopting NVL/NVL72 fabrics in rack‑scale builds.Use cases and target customers
- Tier‑2 cloud providers and regional AI clouds — need HGX performance but cannot justify hyperscaler bespoke racks; ORv3 standardization lowers integration cost.
- Research labs and HPC centers — benefit from pooled GPU memory and NVLink performance for massive simulations and large‑context LLM training.
- Enterprises building private AI clusters — want certified OS stacks and front‑serviceable designs to reduce maintenance windows and integrate into existing rack operations.
- AI inference farms / AI factories — where low latency, high concurrency inference and dense rack utilization are critical; GIGABYTE’s GB300/NVL72‑style racks are complementary reference architectures for this pattern.
Strengths: why this matters for operators
- Standardization: ORv3 alignment means operators can adopt consistent rack trays, power distribution (48V bus bar options) and service practices across vendors, lowering integration risk.
- High GPU memory and NVLink fabrics: HGX B200’s pooled HBM3e gives teams more flexibility in model sizes without complex multi‑host sharding, shortening development cycles.
- Serviceability: Front‑accessible NVMe bays and PCIe slots reduce mean time to repair and make hot‑swap maintenance simpler for smaller datacenters that may not have rear‑access aisles.
- Networking & security paths: BlueField‑3 and ConnectX‑7 compatibility enables offloadable, programmable NIC/DPU functions important for multi‑tenant and zero‑trust operational models.
- Thermal flexibility: GIGABYTE’s portfolio includes air, liquid and immersion options — allowing operators to choose the thermal envelope that matches facility constraints and energy goals.
Risks, caveats and open questions
- Vendor performance claims need workload validation. Marketing headlines about X× faster inference or “exascale in a rack” are directional. Real performance depends on model architecture, precision modes (e.g., NVFP4), software stacks, and scheduler topology. Operators should benchmark their workloads on evaluation hardware before committing. Treat headline metrics as vendor guidance, not guaranteed production throughput.
- Power and cooling are the real operational costs. HGX B200 systems (and dense NVL racks) consume multiple kilowatts per unit; facility power delivery, PDU design and chilled‑loop capacity (or immersion support) must be planned in detail. The initial capex on power infrastructure can dwarf compute hardware cost for new builds.
- Supply‑chain concentration and component lead times. High‑end GPUs, HBM stacks, and DPUs have been bottlenecked historically. Procurement timelines must consider vendor allocation, options for phased rollouts, and contractual protections.
- Software maturity for new numeric formats and scale‑out fabric features. New formats (e.g., FP4/NVFP4) and in‑network offloads require compiler/runtime support and validation for accuracy/latency tradeoffs. Some stacks need additional engineering to reach production reliability.
- Potential lock‑in and ecosystem dependency. Adopting an HGX‑centric, NVSwitch/NVLink coherent domain with heavy use of NVIDIA DPUs/SuperNICs can produce ecosystem dependency; multi‑vendor strategies and portability clauses are prudent for long‑term resilience.
- Unverifiable claims should be flagged. Some public announcements use aggregate terms such as “exascale” or “weeks instead of months.” Unless third‑party audited benchmarks or long‑duration field reports exist, treat these as aspirational. Where possible, ask vendors for validated test reports on representative workloads.
Procurement checklist: what to ask suppliers before you buy
When evaluating TO86‑class systems or HGX B200 builds, demand answers to this prioritized list:- Firmware and driver roadmap: how frequently are GPU/BlueField/BIOS firmware updates delivered and what is the validation process?
- Real workload benchmarks: provide MLPerf (or equivalent) plus customer‑provided model runs for training and inference, including tail‑latency percentiles.
- Power and cooling profile: list peak, sustained, and idle power figures under a representative production workload. Include recommended rack power distribution and facility changes needed.
- Support and spares: SLA for replaced components (GPU, DPU, NVMe) and expected on‑site repair times.
- Network fabric reference architecture: is a validated NVL/NVL72 or DGX‑class rack design available with pricing and switch recommendations?
- Portability and multi‑cloud strategy: options for moving models/data to alternative clouds or on‑prem hardware without wholesale rewrites.
- Security and silicon supply assurances: DPU firmware provenance, secure boot and hardware root‑of‑trust details.
Operational guidance for adoption
- Start with a pilot pod (1–4 racks) and validate your full pipeline — data ingestion, preprocessing, model sharding, checkpoint/restore and inference tail latency — under production workloads.
- Build topology‑aware schedulers that respect NVLink/NVSwitch domains to avoid inefficient cross‑host sharding.
- Invest in observability: telemetry from DPUs and SuperNICs (queue depths, packet drops, microburst events) is essential to diagnose scaling issues.
- Consider mixed thermal strategies: use air‑cooled nodes for development and liquid/immersion nodes for production inference pods where density matters.
Industry context and what this means for the market
Giga Computing’s move to deliver TO86 ORv3 servers with HGX B200 shows the ecosystem maturing in two ways:- Open rack standardization (OCP ORv3) is not just a hyperscaler play; vendors are designing mainstream product lines that fit OCP trays and busbars, enabling smaller operators to adopt hyperscale ideas without custom engineering. That lowers the barrier to entry for regional AI clouds and research clusters.
- Rack‑first thinking (NVL/NVL72 and GB300 concepts) is reshaping expectations about what a single rack can do. Where older strategies stitched many PCIe GPUs across hosts, HGX NVSwitch‑based racks enable much larger coherent working sets and reduce orchestration complexity for certain classes of models. This changes procurement priorities from “GPU count per server” to “coherent GPU memory and NVLink domain availability per allocation.”
Final assessment
Giga Computing’s TO86‑SD1 and related ORv3 offerings represent a pragmatic and timely addition to the market: they lower the technical and integration overhead for deploying HGX B200 Blackwell performance in an ORv3‑friendly, serviceable package. For organizations that need the large, pooled HBM capacity and NVLink coherence that Blackwell/SXM systems offer, these designs make it easier to realize that performance without fully custom rack engineering.However, buyers must be disciplined. The most important next steps for prospective customers are: validate with your own models, plan for facility power and cooling, insist on workload‑matched benchmarks, and secure supply‑chain and portability protections. When these boxes are checked, the TO86 family (and the broader GIGABYTE HGX B200 portfolio) is a viable and competitive route to next‑generation AI and HPC capacity that sits squarely between costly hyperscaler bespoke systems and fragmentary PCIe‑GPU farms.
