Windows 7 graphic problem screen faild
doman86
hi
j have a problem with my computer when j am using after 1 hour j see some thin like that (Attachments) my graphic details intel hd graphic family driver date 15/04/2011 driver version 8.15.10.2372
my laptop detail
intel i5 -2430m 2.40
6 gb ram
monitor 15.6
j try update drivers all of them but system its telling me that j have new version
Hi doman86 and Welcome to The Forum.
To stop Windows installing drivers automatically.
GoTo Start >> r-click Computer, select Properties. On Properties select (on left) Advanced system settings >> Hardware tab >> Device Installation Settings button.
Now update your graphics drivers yourself.
Use the Intel® Driver Update Utility (in Internet Explorer gives me the best results). Update any and all drivers available.
And regarding updates through Windows, my personal opinion is:
Do not have Windows update set to the Install update automatically (recommended) setting. Then you can veto any system / program / hardware drivers it wants to install.
I have "Never check for updates (not recommended)" as my setting. I know that Windows releases main updates on the second Tuesday of every month, and, apart from that, it takes a few seconds to initiate Windows Update to see if it's offering anything. At the maximum setting I would suggest "Check for updates but let me choose whether to download and install them".
HTH.
