mrobjo
Hi,have a sound blaster audigy se,drivers work fine,but no longer have the graphic equalizer,have been on google but i am just finding an answer.If there is no way of getting it for this sound card,can anyone recommend another budget card.thank you
There is a graphic equalizer in WMP 12: open the little arrow under "Now Playing" and go to "Enhancements".
3rd party players have equalizers too.
If there's no equalizer application from creative labs, you can try to substitute it with a 3rd party software, or simply use widows volume mixer:
