Windows Vista Hardware Compatability
U
Unregistered
Guest
Does anyone know whether Windows Vista will be compatible with the following hardware:
AMD XP 3200
ASROCK K7 MOTHERBOARD
2GB DDR 400 RAM
PLEASE HELP??
Correct.. check the Aero requirements as well to make sure you can run the visual stuff. It mostly depends on your video card. You should be able to run. The amount of RAM you have is very sufficient and the CPU is really not that outdated.
A modern CPU... check
512MB RAM... check
DirectX 9 compatible card... don't know
These are the minimum requirements
http://www.microsoft.com/technet/windowsvista/evaluate/hardware/vistarpc.mspx
It will also depend on what you want to do with the new OS as well. What version ect... I for one am going for the ultimate that way I can use as I want without worry.
