Yonose
Hello, so i recently reinstalled my computer to factory new.
I downloaded Win8 then did all the windows update and then moved on to Win8.1
After i reinstalled my computer i had my sound stutters, which makes this sound. This is very annoying of course.
Drivers or programs like Spotify or Nvidia shouldnt have a effect on this.
The sound stutter started before i downloaded any programs/drivers.
I have been researching around and havent really found much of fixes for my problem.
I did find some more problems with my computers.
When i start playing a game, the game also starts stuttering, it also cut the power because of this i would think.
My monitors also turn off and on sometimes and says it dosent get enought signal.
Is this Motherboard and CPU problem? do i need to buy new hardware.
Here is my specs:
Intel i5 2500K 3.30GHz
GTX 770
8GB RAM
Corsair RM 750W
I did had GTX 770 SLI, until i returned my card because of issuses with it.
The problem with all this actually when i started the computer the day after i had removed the 2nd GPU from my system and returende it to the producer.
Thank you.
Here is my specs:
GTX 770
8GB RAM
Corsair RM 750W
Thank you.
