Having problems with Bsod
I have been having problems with my machine lately. It has been having problems starting up. It seems to run memchk everytime it starts up. It also BSOD's occasionally.
I did have my cpu overclocked but have reverted it since. It's still having the same issues. Is my harddrive dying? I attached the logs from the windows 7 diagnostic tool that you guys have. I also attached my latest memchk results called, My_memchk_system_log, in there as well.
My specs:
i5 760 at stock frequency
ASUS P7P55D-e LGA 1156 Motherboard
GTX 470
530W Seasonic power supply
Appreciate any help!
usasma
Fantastic Member
Please do not resume overclocking until we've finished troubleshooting. If overclocking, please stop.
There are no Windows Updates since SP1 - most systems have 130 to 140. Please visit Windows Update and get ALL available updates immediately.
Only 222 mB of free RAM. Please add RAM to the system. While waiting to add RAM, do not run more than one program at a time - and eliminate as many of the 3rd party startup programs as you can.
Win7 doesn't like wireless USB network adapters. Ensure that you have the latest Win7 drivers for this device (DO NOT use Vista era drivers - they will cause BSOD's). Here's my rant about these devices:
I do not recommend using wireless USB devices. Especially in Win7 systems.
These wireless USB devices have many issues with Win7 - and using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have
seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome
sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL]
DuplexSecure - FAQ [/DEL]
Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install"
when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
There are a lot of these errors:
An I/O operation initiated by the Registry failed unrecoverably. The Registry could not read in, or write out, or flush, one of the files that contain the system's image of the Registry.
Are you able to perform a System Restore to a point before this started happening? If so, please do it and see if that helps.
dfmirage.sys Fri Jan 11 16:04:26 2008 (4787D9DA)
Mirage Driver by DemoForge, LLC.
http://www.carrona.org/drivers/driver.php?id=dfmirage.sys
wdcsam64.sys Wed Apr 16 04:39:08 2008 (4805BB2C)
Western Digital SCSI Arcitecture Model (SAM) WDM driver[br]2008 driver version has known BSOD issues in Win7
http://www.carrona.org/drivers/driver.php?id=wdcsam64.sys
Rt64win7.sys Thu Feb 26 04:04:13 2009 (49A65B0D)
Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
nusb3hub.sys Thu Jan 21 22:22:18 2010 (4B5919EA)
NEC Electronics USB 3.0 Host Controller Driver (previous BSOD issues with 2010 version)
http://www.carrona.org/drivers/driver.php?id=nusb3hub.sys
nusb3xhc.sys Thu Jan 21 22:22:21 2010 (4B5919ED)
http://www.carrona.org/drivers/driver.php?id=nusb3xhc.sys
dtsoftbus01.sys Fri Jun 17 03:38:37 2011 (4DFB047D)
Daemon Tools driver [br] Possible BSOD issues in Win7
http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sysPlease un-install this using the instructions provided above.
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Wed Nov 21 04:15:07.086 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\112112-38017-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 5:13:51.584[/B]
BugCheck Code: [B]BugCheck 1000007E, {ffffffffc0000022, fffff800032c4b80, fffff88003147d30, fffff88003147dd0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!RtlRaiseStatus+18 )[/B]
BugCheck Info: [B]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/B]
Arguments:
Arg1: ffffffffc0000022, The exception code that was not handled
Arg2: fffff800032c4b80, The address that the exception occurred at
Arg3: fffff88003147d30, Exception Record Address
Arg4: fffff88003147dd0, Context Record Address
PROCESS_NAME: [B]System[/B]
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_nt!RtlRaiseStatus+18[/B]
CPUID:        "Intel(R) Core(TM) i5 CPU         760  @ 2.80GHz"
MaxSpeed:     2800
CurrentSpeed: [B]2808[/B]
  BIOS Version                  1301
  BIOS Release Date             08/27/2010
**************************Tue Nov 20 22:28:37.056 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\112012-29250-01.dmp]
System Uptime:[B]0 days 0:03:39.555[/B]
BugCheck Code: [B]BugCheck 24, {1904fb, fffff88008eeb8e8, fffff88008eeb140, fffff880012bdb49}[/B]
Probably caused by :[B]memory_corruption[/B]
BugCheck Info: [B]NTFS_FILE_SYSTEM (24)[/B]
Arguments:
Arg1: 00000000001904fb
Arg2: fffff88008eeb8e8
Arg3: fffff88008eeb140
Arg4: fffff880012bdb49
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
PROCESS_NAME: [B]AvastSvc.exe[/B]
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]X64_MEMORY_CORRUPTION_ONE_BIT[/B]
MaxSpeed:     2800
  BIOS Version                  1301
**************************Tue Nov 20 22:18:48.522 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\112012-38298-01.dmp]
System Uptime:[B]0 days 0:01:54.630[/B]
BugCheck Code: [B]BugCheck 74, {2, fffff880067f8b20, 2, ffffffffc000014d}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!CmpLoadHiveThread+23a )[/B]
BugCheck Info: [B]BAD_SYSTEM_CONFIG_INFO (74)[/B]
Arguments:
Arg1: 0000000000000002, (reserved)
Arg2: fffff880067f8b20, (reserved)
Arg3: 0000000000000002, (reserved)
Arg4: ffffffffc000014d, usually the NT status code.
BUGCHECK_STR:  0x74
FAILURE_BUCKET_ID: [B]X64_0x74_nt!CmpLoadHiveThread+23a[/B]
MaxSpeed:     2800
**************************Thu Nov 15 13:13:22.529 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111512-38064-01.dmp]
System Uptime:[B]0 days 0:02:18.949[/B]
BugCheck Code: [B]BugCheck 74, {2, fffff8800676fb20, 2, ffffffffc000014d}[/B]
Arguments:
Arg2: fffff8800676fb20, (reserved)
BUGCHECK_STR:  0x74
**************************Sat Nov 10 11:54:37.583 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111012-27986-01.dmp]
System Uptime:[B]0 days 0:01:05.988[/B]
BugCheck Code: [B]BugCheck 74, {2, fffff88006761b20, 2, ffffffffc000014d}[/B]
Arguments:
Arg2: fffff88006761b20, (reserved)
BUGCHECK_STR:  0x74
MaxSpeed:     2800
CurrentSpeed: [B]3733[/B]
Processor may be overclocked!
Expected Frequency:   2800
Actual Frequency:     3733
Overclock Ratio:      [COLOR=red]1.33321[/COLOR]
**************************Sun Nov  4 12:55:55.521 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110412-16348-01.dmp]
System Uptime:[B]0 days 0:01:34.941[/B]
BugCheck Code: [B]BugCheck 74, {2, fffff880009ffb20, 2, ffffffffc000014d}[/B]
Arguments:
Arg2: fffff880009ffb20, (reserved)
BUGCHECK_STR:  0x74
**************************Sat Nov  3 13:43:19.889 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110312-66612-01.dmp]
System Uptime:[B]0 days 3:36:42.920[/B]
BugCheck Code: [B]BugCheck 50, {ffff8a00477abe48, 0, fffff8800133cb09, 7}[/B]
Probably caused by :[B]Ntfs.sys ( Ntfs!NtfsGrowLookupStack+19 )[/B]
BugCheck Info: [B]PAGE_FAULT_IN_NONPAGED_AREA (50)[/B]
Arguments:
Arg1: ffff8a00477abe48, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff8800133cb09, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000007, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x50_Ntfs!NtfsGrowLookupStack+19[/B]
MaxSpeed:     2800
  BIOS Version                  1301
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]dfmirage.sys                Fri Jan 11 16:04:26 2008 (4787D9DA)[/B][/COLOR]
[COLOR=RED][B]Rt64win7.sys                Thu Feb 26 04:04:13 2009 (49A65B0D)[/B][/COLOR]
[COLOR=RED][B]ASACPI.sys                  Wed May 13 21:25:17 2009 (4A0B72FD)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
LGVirHid.sys                Mon Nov 23 20:36:48 2009 (4B0B38B0)
LGBusEnum.sys               Mon Nov 23 20:36:48 2009 (4B0B38B0)
athurx.sys                  Mon Jan  4 22:23:16 2010 (4B42B0A4)
[COLOR=RED][B]nusb3hub.sys                Thu Jan 21 22:22:18 2010 (4B5919EA)[/B][/COLOR]
[COLOR=RED][B]nusb3xhc.sys                Thu Jan 21 22:22:21 2010 (4B5919ED)[/B][/COLOR]
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
cmudaxp.sys                 Wed Sep 15 23:41:13 2010 (4C9191D9)
nvBridge.kmd                Sat Oct 16 13:06:16 2010 (4CB9DB88)
cpuz135_x64.sys             Tue Nov  9 08:33:36 2010 (4CD94DB0)
LHidFilt.Sys                Sat Apr 30 07:51:39 2011 (4DBBF7CB)
LMouFilt.Sys                Sat Apr 30 07:51:45 2011 (4DBBF7D1)
[COLOR=RED][B]dtsoftbus01.sys             Fri Jun 17 03:38:37 2011 (4DFB047D)[/B][/COLOR]
nvhda64v.sys                Tue Jan 17 07:45:46 2012 (4F156D7A)
SCDEmu.SYS                  Wed Apr 18 23:53:28 2012 (4F8F8C38)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
aswFsBlk.SYS                Tue Aug 21 05:04:55 2012 (50334F37)
aswMonFlt.sys               Tue Aug 21 05:05:00 2012 (50334F3C)
aswTdi.SYS                  Tue Aug 21 05:05:01 2012 (50334F3D)
aswrdr2.sys                 Tue Aug 21 05:05:16 2012 (50334F4C)
aswSP.SYS                   Tue Aug 21 05:05:54 2012 (50334F72)
aswSnx.SYS                  Tue Aug 21 05:05:56 2012 (50334F74)
nvlddmkm.sys                Tue Oct  2 14:21:13 2012 (506B3099)
nvlddmkm.sys                Wed Feb 29 13:04:52 2012 (4F4E68C4)
[COLOR=RED][B]wdcsam64.sys                Wed Apr 16 04:39:08 2008 (4805BB2C)[/B][/COLOR]
usbaapl64.sys               Fri Jun 22 02:01:11 2012 (4FE40A27)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=LGVirHid.sys
http://www.carrona.org/drivers/driver.php?id=LGBusEnum.sys
http://www.carrona.org/drivers/driver.php?id=athurx.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=cmudaxp.sys
http://www.carrona.org/drivers/driver.php?id=nvBridge.kmd
http://www.carrona.org/drivers/driver.php?id=cpuz135_x64.sys
http://www.carrona.org/drivers/driver.php?id=LHidFilt.Sys
http://www.carrona.org/drivers/driver.php?id=LMouFilt.Sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=SCDEmu.SYS
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=aswFsBlk.SYS
http://www.carrona.org/drivers/driver.php?id=aswMonFlt.sys
http://www.carrona.org/drivers/driver.php?id=aswTdi.SYS
http://www.carrona.org/drivers/driver.php?id=aswrdr2.sys
http://www.carrona.org/drivers/driver.php?id=aswSP.SYS
http://www.carrona.org/drivers/driver.php?id=aswSnx.SYS
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
http://www.carrona.org/drivers/driver.php?id=usbaapl64.sys
Ok I went ahead and bought more ram.
I am not sure if a system restore is a viable option as the crashes started occurring a while ago.
I don't have any Windows updates to do. My computer does them automatically so I am not sure why the report would show 0 updates since SP1...
Thanks for the advice!
GeneralHiningII
Honorable Member
Could you try forcing a check for updates in Windows Update? Once you upgrade to SP1 it should still show the list of updates you did before the upgrade.
Just a suggestion - remember to follow the rest of the pointers provided by usasma.
Ok, I opened up Windows update and see that I have over 200 updates completed successfully. Not sure why it doesn't show in my log..ill follow the rest of the advice that usasma gave
