gurugeorge
Hello folks, started getting this crash since a recent windows update - system was running fine before, at any rate - yet still get crash even after rollback. It only seems to happen with a music app called Cubase. Had no luck searching for a solution in relation to that program specifically, so coming here to see if any of you can help!
Minidump file attached.Link Removed
Comp is self-built, running Windows 7 64 bit. Gigabyte ep43t-usb3, QuadCore2 Extreme X9650 processor, 8G Corsair XMS ram, Crucial RealSSD C600 64G C drive, ordinary Seageate D drive, ATI 5400
TIA!
Cubase is the culprit from what I can read in your crash dumps and what you tell me. Update this software if available. Update drivers as in my 1st post and if crashes persist then replace AVG with MSE. Then if more crashes, uninstall Cubase.
PROCESS_NAME: Cubase5.exe
FAILURE_BUCKET_ID: X64_0x76_Cubase5.exe_nt!_??_::NNGAKEGL::_string_+18126
Does it happen ONLY at the time of running Steinberg Cubase 5?
Update:
Intel Matrix Storage
iaStor.sys Thu Jun 04 21:53:40 2009
Motherboard driver for NEC USB 3.0
nusb3hub.sys Mon Oct 26 10:19:44 2009
Realtek LAN
Rt64win7.sys Thu Aug 20 12:05:06 2009
Realtek Network Protocol
RtNdPt60.sys Sun Jul 19 22:27:32 2009
® Neutral Wireless Solution
scmndisp.sys Wed Jan 17 02:48:03 2007
Acronis
tdrpm251.sys Fri Jul 31 09:59:53 2009
Replace AVG with MSE:
Link Removed due to 404 Error
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\011311-9671-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c4e000 PsLoadedModuleList = 0xfffff800`02e8be50
Debug session time: Thu Jan 13 13:23:12.535 2011 (UTC - 5:00)
System Uptime: 0 days 0:17:54.003
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 76, {0, fffffa8006d33b30, ffffffffffffffee, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::NNGAKEGL::`string'+18126 )
Followup: MachineOwner
2: kd> !analyze -v
PROCESS_HAS_LOCKED_PAGES (76)
Caused by a driver not cleaning up correctly after an I/O.
Arguments:
Arg1: 0000000000000000, Locked memory pages found in process being terminated.
Arg2: fffffa8006d33b30, Process address.
Arg3: ffffffffffffffee, Number of locked pages.
Arg4: 0000000000000000, Pointer to driver stacks (if enabled) or 0 if not.
	Issue a !search over all of physical memory for the current process pointer.
	This will yield at least one MDL which points to it.  Then do another !search
	for each MDL found, this will yield the IRP(s) that point to it, revealing
	which driver is leaking the pages.
	Otherwise, set HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory
	Management\TrackLockedPages to a DWORD 1 value and reboot.  Then the system
	will save stack traces so the guilty driver can be easily identified.
	When you enable this flag, if the driver commits the error again you will
	see a different bugcheck - DRIVER_LEFT_LOCKED_PAGES_IN_PROCESS (0xCB) -
	which can identify the offending driver(s).
Debugging Details:
DEFAULT_BUCKET_ID:  DRIVER_FAULT_0x76
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x76
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002f60c25 to fffff80002cbe740
STACK_TEXT:
fffff880`035d2a98 fffff800`02f60c25 : 00000000`00000076 00000000`00000000 fffffa80`06d33b30 ffffffff`ffffffee : nt!KeBugCheckEx
fffff880`035d2aa0 fffff800`02f7bd27 : fffffa80`06d33b30 00000000`00000008 fffffa80`00000000 fffffa80`00000002 : nt! ?? ::NNGAKEGL::`string'+0x18126
fffff880`035d2ae0 fffff800`02cc38b4 : 00000000`00000000 fffffa80`06d33b30 fffffa80`06d33b00 00000000`0000000a : nt!PspProcessDelete+0x177
fffff880`035d2b40 fffff800`02fa3f43 : fffffa80`06d33b30 00000000`00000001 fffffa80`06a1ab60 00000000`00000012 : nt!ObfDereferenceObject+0xd4
fffff880`035d2ba0 fffff800`02fa76b8 : fffffa80`07427630 fffffa80`07427660 fffffa80`06a07080 fffffa80`07427660 : nt!PspThreadDelete+0xe3
fffff880`035d2be0 fffff800`02cd0523 : 00000000`00000000 00000000`00000000 fffffa80`07427660 00000000`00000001 : nt!ObpRemoveObjectRoutine+0x8c
fffff880`035d2c40 fffff800`02c9f5c9 : 00000000`00000000 fffffa80`06a1ab60 fffffa80`074279f0 fffffa80`06a1ab60 : nt!ObfDereferenceObjectWithTag+0x93
fffff880`035d2c80 fffff800`02ccb961 : fffff800`02c9f530 fffff800`02e63650 fffffa80`06a1ab60 00000000`00000000 : nt!PspReaper+0x99
fffff880`035d2cb0 fffff800`02f62c06 : 00000000`00000000 fffffa80`06a1ab60 00000000`00000080 fffffa80`06a07890 : nt!ExpWorkerThread+0x111
fffff880`035d2d40 fffff800`02c9cc26 : fffff880`03364180 fffffa80`06a1ab60 fffff880`0336efc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`035d2d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02f60c25 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::NNGAKEGL::`string'+18126
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
Drivers:
fffff880`00f72000 fffff880`00fc9000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`04a9e000 fffff880`04add000   afcdp    afcdp.sys    Fri Sep 11 12:19:38 2009 (4AAA789A)
fffff880`042b4000 fffff880`0433e000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`01610000 fffff880`01626000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`01035000 fffff880`01040000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`043de000 fffff880`043e6000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`0b35a000 fffff880`0b365000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`011ed000 fffff880`011f6000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01000000 fffff880`0102a000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`05753000 fffff880`05774000   AtiHdmi  AtiHdmi.sys  Wed Sep 30 09:54:46 2009 (4AC36326)
fffff880`04cf8000 fffff880`05334000   atikmdag atikmdag.sys Fri Oct 02 00:05:13 2009 (4AC57BF9)
fffff880`01200000 fffff880`01247000   avgldx64 avgldx64.sys Thu Jun 03 17:06:48 2010 (4C081968)
fffff880`042a6000 fffff880`042ad080   avgmfx64 avgmfx64.sys Sun Apr 25 17:06:15 2010 (4BD4AEC7)
fffff880`0155d000 fffff880`015ae000   avgtdia  avgtdia.sys  Thu Jun 03 17:09:57 2010 (4C081A25)
fffff880`03167000 fffff880`0316e000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04295000 fffff880`042a6000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`04ba5000 fffff880`04bc3000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006e0000 fffff960`00707000   cdd      cdd.dll      unavailable (00000000)
fffff880`03134000 fffff880`0315e000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00ccc000 fffff880`00d8c000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01aae000 fffff880`01ade000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c6e000 fffff880`00ccc000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01485000 fffff880`014f8000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`01600000 fffff880`01610000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`069ce000 fffff880`069dc000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04277000 fffff880`04295000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`04268000 fffff880`04277000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01a98000 fffff880`01aae000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0463d000 fffff880`0465f000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`069dc000 fffff880`069ef000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`03000000 fffff880`0311c000   dump_iaStor dump_iaStor.sys Thu Jun 04 21:53:40 2009 (4A287AA4)
fffff880`069c2000 fffff880`069ce000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04c00000 fffff880`04cf4000   dxgkrnl  dxgkrnl.sys  Mon Nov 01 22:51:31 2010 (4CCF7CB3)
fffff880`05334000 fffff880`0537a000   dxgmms1  dxgmms1.sys  Mon Nov 01 22:50:56 2010 (4CCF7C90)
fffff880`02c0c000 fffff880`02c42000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`047e2000 fffff880`047ef000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`0108c000 fffff880`010a0000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`05733000 fffff880`0573e000   flpydisk flpydisk.sys Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`01040000 fffff880`0108c000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01509000 fffff880`01513000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01a5e000 fffff880`01a98000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01513000 fffff880`0155d000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`017ec000 fffff880`017f9000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02c05000 fffff800`02c4e000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`0537a000 fffff880`0539e000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`05774000 fffff880`057d0000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`047b9000 fffff880`047dc000   hdsp_64  hdsp_64.sys  Thu Aug 05 08:36:53 2010 (4C5AB065)
fffff880`0680e000 fffff880`06827000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`06827000 fffff880`0682f080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`06800000 fffff880`0680e000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`04add000 fffff880`04ba5000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01c88000 fffff880`01c91000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`0683f000 fffff880`069c2000   hypaudio64 hypaudio64.sys Mon Sep 20 23:51:57 2010 (4C982BDD)
fffff880`0477c000 fffff880`047b9000   hypkern64 hypkern64.sys Mon Sep 20 23:50:28 2010 (4C982B84)
fffff880`053c8000 fffff880`053e6000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010d1000 fffff880`011ed000   iaStor   iaStor.sys   Thu Jun 04 21:53:40 2009 (4A287AA4)
fffff880`043e6000 fffff880`043fc000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`053e6000 fffff880`053f5000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00b9d000 fffff800`00ba7000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0465f000 fffff880`046a2000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`0146b000 fffff880`01485000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01791000 fffff880`017bc000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`047dc000 fffff880`047e1200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02d63000 fffff880`02d78000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02d1f000 fffff880`02d42000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c16000 fffff880`00c5a000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`069ef000 fffff880`069fd000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0569f000 fffff880`056ae000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06830000 fffff880`0683d000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e81000 fffff880`00e9b000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`04bc3000 fffff880`04bdb000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`04a00000 fffff880`04a2d000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`04a2d000 fffff880`04a7b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`04a7b000 fffff880`04a9e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`0102a000 fffff880`01035000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`031cc000 fffff880`031d7000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fd2000 fffff880`00fdc000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0140d000 fffff880`0146b000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`0425d000 fffff880`04268000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01a4c000 fffff880`01a5e000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0163f000 fffff880`01731000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`01626000 fffff880`01632000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`02dcb000 fffff880`02dde000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`0561a000 fffff880`05649000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0573e000 fffff880`05753000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`04383000 fffff880`04392000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`015ae000 fffff880`015f3000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01731000 fffff880`01791000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`031d7000 fffff880`031e8000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04251000 fffff880`0425d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c4e000 fffff800`0322a000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01247000 fffff880`013ea000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`0315e000 fffff880`03167000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0571c000 fffff880`05733000   nusb3hub nusb3hub.sys Mon Oct 26 10:19:44 2009 (4AE5B000)
fffff880`0470c000 fffff880`0473b000   nusb3xhc nusb3xhc.sys Mon Oct 26 10:19:48 2009 (4AE5B004)
fffff880`02d78000 fffff880`02dcb000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`04347000 fffff880`0436d000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`053ab000 fffff880`053c8000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e6a000 fffff880`00e71000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e71000 fffff880`00e81000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`014f8000 fffff880`01509000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`0720d000 fffff880`072b3000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04600000 fffff880`0463d000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c5a000 fffff880`00c6e000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`010a0000 fffff880`010c4000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05649000 fffff880`05664000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`05664000 fffff880`05685000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`05685000 fffff880`0569f000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04200000 fffff880`04251000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`031b1000 fffff880`031ba000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`031ba000 fffff880`031c3000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`031c3000 fffff880`031cc000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01c4e000 fffff880`01c88000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02dde000 fffff880`02df6000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0473d000 fffff880`0477c000   Rt64win7 Rt64win7.sys Thu Aug 20 12:05:06 2009 (4A8D7432)
fffff880`02c00000 fffff880`02c0c000   RtNdPt60 RtNdPt60.sys Sun Jul 19 22:27:32 2009 (4A63D614)
fffff880`017bc000 fffff880`017c6000   scmndisp scmndisp.sys Wed Jan 17 02:48:03 2007 (45ADD4B3)
fffff880`072b3000 fffff880`072be000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`047ef000 fffff880`047fb000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`04392000 fffff880`043af000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01c0f000 fffff880`01c4e000   snapman  snapman.sys  Tue Sep 08 03:57:04 2009 (4AA60E50)
fffff880`01c08000 fffff880`01c0f000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`01c00000 fffff880`01c08000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`07364000 fffff880`073fa000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`072fd000 fffff880`07364000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`072be000 fffff880`072eb000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`056ae000 fffff880`056af480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01803000 fffff880`01a00000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`072eb000 fffff880`072fd000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`031e8000 fffff880`031f5000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01c98000 fffff880`01dfe000   tdrpm251 tdrpm251.sys Fri Jul 31 09:59:53 2009 (4A72F8D9)
fffff880`01bda000 fffff880`01bf8000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`043ca000 fffff880`043de000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff880`01ae7000 fffff880`01bcc000   timntr   timntr.sys   Mon Aug 17 03:16:13 2009 (4A8903BD)
fffff960`005d0000 fffff960`005da000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`017c6000 fffff880`017ec000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`056b0000 fffff880`056c2000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0473b000 fffff880`0473cf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`046fb000 fffff880`0470c000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`056c2000 fffff880`0571c000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`046a5000 fffff880`046fb000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0539e000 fffff880`053ab000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0316e000 fffff880`0317c000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`0317c000 fffff880`031a1000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00e55000 fffff880`00e6a000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d8c000 fffff880`00de8000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01a00000 fffff880`01a4c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02d12000 fffff880`02d1f000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`0436d000 fffff880`04383000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`043af000 fffff880`043ca000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`031a1000 fffff880`031b1000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ebf000 fffff880`00f63000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f63000 fffff880`00f72000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0433e000 fffff880`04347000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02c9a000 fffff880`02d12000   wg111v2  wg111v2.sys  Fri Apr 02 06:45:08 2010 (4BB5CAB4)
fffff960`00010000 fffff960`00320000   win32k   win32k.sys   unavailable (00000000)
fffff880`00fc9000 fffff880`00fd2000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02d42000 fffff880`02d63000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`0b2e9000 fffff880`0b35a000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01bcc000 fffff880`01bda000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`03005000 fffff880`03121000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0011C000
fffff880`03121000 fffff880`03134000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Yes, usually when shutting Cubase down, but occasionally while doing other operations within Cubase. It hasn't happened yet with any other program (of general computing/office stuff and Sony Vegas, which we also use).
I have also been experiencing BSOD's with a similar call stack after installing update number #971033.
If you have installed it, try removing using this command:
Wusa.exe /uninstall /kb:971033
