HELP! HP dv7-4051nr BSODs
I have attached my minidump file. I've had several instances where I leave my laptop and come back to find it has rebooted. I've managed to see the blue screen that accompanies this issue but I've not been able to capture it. Can anyone tell from my 2 minidump files what the issue is? One is the one from this issue happening today, the other is a random one possibly for comparison.
Both crashes were caused by Atheros network adapter driver.
athrx.sys Sun Sep 26 23:15:20 2010
The driver looks good, but you may wanna check for its newer version.
Update drivers:
Citrix ICA Client
ctxusbm.sys Mon Sep 07 14:09:28 2009
Virtual Clone
VClone.sys Sun Aug 09 17:25:45 2009
If crashes reoccur, replace Panda with MSE:
http://www.microsoft.com/security_essentials/
CRASH DUMPS
Loading Dump File [F:\DMP\032511-28298-01.dmp]
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?00000000`00000000?
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`0423e500?
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`02c1a000 PsLoadedModuleList = 0xfffff800`02e5fe90
Debug session time: Fri Mar 25 20:03:57.726 2011 (UTC - 4:00)
System Uptime: 3 days 0:18:38.751
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 9F, {3, fffffa8004646a10, fffff8000423e518, fffffa8005ef82b0}
Probably caused by : pci.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8004646a10, Physical Device Object of the stack
Arg3: fffff8000423e518, Functional Device Object of the stack
Arg4: fffffa8005ef82b0, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7928f
MODULE_NAME: pci
FAULTING_MODULE: fffff88000f79000 pci
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
STACK_TEXT:
fffff800`0423e4c8 fffff800`02d06b52 : 00000000`0000009f 00000000`00000003 fffffa80`04646a10 fffff800`0423e518 : nt!KeBugCheckEx
fffff800`0423e4d0 fffff800`02ca6062 : fffff800`0423e600 fffff800`0423e600 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x34a90
fffff800`0423e570 fffff800`02ca5f06 : fffff800`02e42740 00000000`00fe9f90 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`0423e5e0 fffff800`02ca5dee : 0000025e`1a1140da fffff800`0423ec58 00000000`00fe9f90 fffff800`02e10488 : nt!KiProcessExpiredTimerList+0xc6
fffff800`0423ec30 fffff800`02ca5bd7 : 0000005e`778fc9c1 0000005e`00fe9f90 0000005e`778fc9d4 00000000`00000090 : nt!KiTimerExpiration+0x1be
fffff800`0423ecd0 fffff800`02c9236a : fffff800`02e0ce80 fffff800`02e1acc0 00000000`00000000 fffff800`02d48a20 : nt!KiRetireDpcList+0x277
fffff800`0423ed80 00000000`00000000 : fffff800`0423f000 fffff800`04239000 fffff800`0423ed40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0x9F_3_athrx_IMAGE_pci.sys
Loading Dump File [F:\DMP\031011-31356-01.dmp]
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`00b9c500?
Machine Name:
Kernel base = 0xfffff800`02c14000 PsLoadedModuleList = 0xfffff800`02e59e90
Debug session time: Thu Mar 10 01:22:17.627 2011 (UTC - 4:00)
System Uptime: 0 days 9:34:09.594
BugCheck 9F, {3, fffffa8004660a10, fffff80000b9c518, fffffa8010018010}
0: kd> !analyze -v
Arguments:
Arg2: fffffa8004660a10, Physical Device Object of the stack
Arg3: fffff80000b9c518, Functional Device Object of the stack
Arg4: fffffa8010018010, The blocked IRP
Debugging Details:
IMAGE_NAME:  pci.sys
MODULE_NAME: pci
FAULTING_MODULE: fffff88000f51000 pci
BUGCHECK_STR:  0x9F
CURRENT_IRQL:  2
STACK_TEXT:
fffff800`00b9c4c8 fffff800`02d00b52 : 00000000`0000009f 00000000`00000003 fffffa80`04660a10 fffff800`00b9c518 : nt!KeBugCheckEx
fffff800`00b9c4d0 fffff800`02ca0062 : fffff800`00b9c600 fffff800`00b9c600 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x34a90
fffff800`00b9c570 fffff800`02c9ff06 : fffff800`02e3c740 00000000`0021b225 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`00b9c5e0 fffff800`02c9fdee : 00000050`358ee4c2 fffff800`00b9cc58 00000000`0021b225 fffff800`02e09728 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9cc30 fffff800`02c9fbd7 : 0000000c`806597c1 0000000c`0021b225 0000000c`80659766 00000000`00000025 : nt!KiTimerExpiration+0x1be
fffff800`00b9ccd0 fffff800`02c8c36a : fffff800`02e06e80 fffff800`02e14cc0 00000000`00000000 fffff800`02d42a20 : nt!KiRetireDpcList+0x277
fffff800`00b9cd80 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cd40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
DRIVERS
fffff880`04792000 fffff880`0479f000   Accelerometer Accelerometer.sys Fri Jul 16 11:02:38 2010 (4C40748E)
fffff880`00ee7000 fffff880`00f3e000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`084a5000 fffff880`084ec000   afcdp    afcdp.sys    Tue Aug 10 11:24:00 2010 (4C616F10)
fffff880`02ef9000 fffff880`02f82000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`047e2000 fffff880`047f8000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`04119000 fffff880`0412e000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00ec4000 fffff880`00ecf000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`055ef000 fffff880`055fa000   appliand appliand.sys Fri May 28 07:54:10 2010 (4BFFAEE2)
fffff880`00e76000 fffff880`00e7f000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e7f000 fffff880`00ea9000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff880`0521c000 fffff880`05466000   athrx    athrx.sys    Sun Sep 26 23:15:20 2010 (4CA00C48)
fffff880`0405a000 fffff880`0407d000   AtiHdmi  AtiHdmi.sys  Thu May 06 05:20:39 2010 (4BE289E7)
fffff880`04a2c000 fffff880`051e8000   atikmdag atikmdag.sys Wed Sep 29 22:55:51 2010 (4CA3FC37)
fffff880`0412e000 fffff880`04178000   atikmpag atikmpag.sys Wed Sep 29 22:13:37 2010 (4CA3F251)
fffff880`019ef000 fffff880`019f7000   AtiPcie64 AtiPcie64.sys Wed Mar 10 09:33:45 2010 (4B97ADC9)
fffff960`008c0000 fffff960`00921000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`00faf000 fffff880`00fbb000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`01443000 fffff880`0144a000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`040e2000 fffff880`040f3000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`04952000 fffff880`04970000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00730000 fffff960`00757000   cdd      cdd.dll      unavailable (00000000)
fffff880`01000000 fffff880`0102a000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00c8a000 fffff880`00d4a000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`04443000 fffff880`04455000   circlass circlass.sys Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`01400000 fffff880`01430000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00c2c000 fffff880`00c8a000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0479f000 fffff880`047a3500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`0118e000 fffff880`01200000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`00fa6000 fffff880`00faf000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`047ad000 fffff880`047bd000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`06b6f000 fffff880`06b7d000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`040c7000 fffff880`040e2000   ctxusbm  ctxusbm.sys  Mon Sep 07 14:09:28 2009 (4AA54C58)
fffff880`00fd0000 fffff880`00fee000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`010af000 fffff880`010be000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01be9000 fffff880`01bff000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`041ae000 fffff880`041d0000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06b7d000 fffff880`06b89000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06b94000 fffff880`06ba7000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06b89000 fffff880`06b94000   dump_msahci dump_msahci.sys Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`02ef0000 fffff880`02ef8000   dvmio    dvmio.sys    Tue Nov 10 23:38:32 2009 (4AFA3FC8)
fffff880`06ba7000 fffff880`06bb3000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04464000 fffff880`04558000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`04558000 fffff880`0459e000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`02ee5000 fffff880`02ef0000   ElbyCDIO ElbyCDIO.sys Thu Dec 17 17:25:16 2009 (4B2AAFCC)
fffff880`04178000 fffff880`041ae000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01110000 fffff880`01124000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010c4000 fffff880`01110000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`013da000 fffff880`013e4000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`019b5000 fffff880`019ef000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`0182f000 fffff880`01879000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`054bf000 fffff880`054cc000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`031fe000 fffff800`03247000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`0459e000 fffff880`045c2000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`047c0000 fffff880`047d9000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`047d9000 fffff880`047e1080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`01bdf000 fffff880`01be9000   hpdskflt hpdskflt.sys Fri Jul 16 11:02:38 2010 (4C40748E)
fffff880`04800000 fffff880`048c9000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01a4c000 fffff880`01a55000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`0554b000 fffff880`05569000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`047bd000 fffff880`047bf100   jumi     jumi.sys     Mon Sep 28 18:48:52 2009 (4AC13D54)
fffff880`05569000 fffff880`05578000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04a00000 fffff880`04a0e000   kbdhid   kbdhid.sys   Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00bbd000 fffff800`00bc7000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04400000 fffff880`04443000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`013ae000 fffff880`013c9000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`015ad000 fffff880`015d8000   ksecpkg  ksecpkg.sys  Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`047f8000 fffff880`047fd200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06be4000 fffff880`06bf9000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06bc1000 fffff880`06be4000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c0b000 fffff880`00c18000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`06bb3000 fffff880`06bc1000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04783000 fffff880`04792000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04455000 fffff880`04462000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e5c000 fffff880`00e76000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`0102a000 fffff880`0105b000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`08de2000 fffff880`08df2000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`04970000 fffff880`04988000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`04988000 fffff880`049b5000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`08434000 fffff880`08481000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`08481000 fffff880`084a5000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`00ea9000 fffff880`00eb4000   msahci   msahci.sys   Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`01064000 fffff880`0106f000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f47000 fffff880`00f51000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`08c8a000 fffff880`08c8bc00   MSPCLOCK MSPCLOCK.sys Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`08c88000 fffff880`08c89a80   MSPQM    MSPQM.sys    Mon Jul 13 20:00:17 2009 (4A5BCA91)
fffff880`01130000 fffff880`0118e000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`02eda000 fffff880`02ee5000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01a3a000 fffff880`01a4c000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0145a000 fffff880`0154d000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`05578000 fffff880`05584000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04927000 fffff880`0493a000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`05584000 fffff880`055b3000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`04a0e000 fffff880`04a23000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`02e16000 fffff880`02e25000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02f82000 fffff880`02fc7000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`0154d000 fffff880`015ad000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`08c00000 fffff880`08c15000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`0106f000 fffff880`01080000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02ece000 fffff880`02eda000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c14000 fffff800`031fe000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`0120b000 fffff880`013ae000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`019f7000 fffff880`01a00000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`048d4000 fffff880`04927000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02fd0000 fffff880`02ff6000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`00f91000 fffff880`00fa6000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`00f51000 fffff880`00f84000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`00eb4000 fffff880`00ec4000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013c9000 fffff880`013da000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`084ec000 fffff880`08592000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0407d000 fffff880`040ba000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c18000 fffff880`00c2c000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`06a00000 fffff880`06a2a000   PSINAflt PSINAflt.sys Wed Nov 24 10:38:15 2010 (4CED3167)
fffff880`06a4d000 fffff880`06a6c000   PSINFile PSINFile.sys Wed Nov 24 10:40:13 2010 (4CED31DD)
fffff880`02ea5000 fffff880`02ece000   psinknc  psinknc.sys  Wed Nov 24 10:36:19 2010 (4CED30F3)
fffff880`06a6c000 fffff880`06a8d000   PSINProc PSINProc.sys Wed Nov 24 10:42:34 2010 (4CED326A)
fffff880`06a2a000 fffff880`06a4d000   PSINProt PSINProt.sys Wed Nov 24 10:45:16 2010 (4CED330C)
fffff880`01124000 fffff880`0112fe00   PxHlpa64 PxHlpa64.sys Tue Jun 23 19:16:35 2009 (4A416253)
fffff880`04600000 fffff880`04624000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`055b3000 fffff880`055ce000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`055ce000 fffff880`055ef000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`05200000 fffff880`0521a000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02e54000 fffff880`02ea5000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`013f4000 fffff880`013fd000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01200000 fffff880`01209000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0105b000 fffff880`01064000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01a00000 fffff880`01a3a000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`0493a000 fffff880`04952000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`045d1000 fffff880`04600000   SCSIPORT SCSIPORT.SYS Sat Nov 20 05:34:01 2010 (4CE7A419)
fffff880`08592000 fffff880`0859d000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`01b99000 fffff880`01bdf000   snapman  snapman.sys  Tue Aug 10 06:15:05 2010 (4C6126A9)
fffff880`01b91000 fffff880`01b99000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`08d49000 fffff880`08de2000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`08cde000 fffff880`08d49000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`0859d000 fffff880`085ce000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`06a91000 fffff880`06b13000   stwrt64  stwrt64.sys  Thu Jul 22 03:25:34 2010 (4C47F26E)
fffff880`04624000 fffff880`04625480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`04626000 fffff880`04781000   SynTP    SynTP.sys    Fri Sep 10 21:09:32 2010 (4C8AD6CC)
fffff880`0162b000 fffff880`0182f000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`085ce000 fffff880`085e0000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`010a2000 fffff880`010af000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`01a5a000 fffff880`01b91000   tdrpm273 tdrpm273.sys Tue Aug 10 05:54:18 2010 (4C6121CA)
fffff880`01080000 fffff880`010a2000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`02e40000 fffff880`02e54000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff880`01879000 fffff880`01969000   timntr   timntr.sys   Wed Jun 02 08:56:47 2010 (4C06550F)
fffff960`00590000 fffff960`0059a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`040f3000 fffff880`04119000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`051e8000 fffff880`051fa000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`08c8c000 fffff880`08c9d000   usbaapl64 usbaapl64.sys Fri Feb 11 13:13:08 2011 (4D557C34)
fffff880`06b13000 fffff880`06b30000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`04781000 fffff880`04782f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`0553a000 fffff880`0554b000   usbehci  usbehci.sys  Fri Dec 04 02:26:02 2009 (4B18B98A)
fffff880`0552d000 fffff880`0553a000   usbfilter usbfilter.sys Thu Apr 29 06:43:06 2010 (4BD962BA)
fffff880`04000000 fffff880`0405a000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`054cc000 fffff880`054d7000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`054d7000 fffff880`0552d000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`06b41000 fffff880`06b6e280   usbvideo usbvideo.sys Sat Nov 20 05:44:34 2010 (4CE7A692)
fffff880`045c2000 fffff880`045d1000   VClone   VClone.sys   Sun Aug 09 17:25:45 2009 (4A7F3ED9)
fffff880`00f84000 fffff880`00f91000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0144a000 fffff880`01458000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`015d8000 fffff880`015fd000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fbb000 fffff880`00fd0000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`01969000 fffff880`019b5000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`05466000 fffff880`05473000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`02e00000 fffff880`02e16000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`02e25000 fffff880`02e40000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`013e4000 fffff880`013f4000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00d4a000 fffff880`00dee000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00dee000 fffff880`00dfd000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02fc7000 fffff880`02fd0000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000c0000 fffff960`003d1000   win32k   win32k.sys   unavailable (00000000)
fffff880`06b30000 fffff880`06b41000   WinUSB   WinUSB.sys   Sat Nov 20 05:43:56 2010 (4CE7A66C)
fffff880`047a4000 fffff880`047ad000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f3e000 fffff880`00f47000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`05473000 fffff880`05494000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
fffff880`08c9d000 fffff880`08cce000   WUDFRd   WUDFRd.sys   Sat Nov 20 05:43:32 2010 (4CE7A654)
Unloaded modules:
fffff880`08c15000 fffff880`08c86000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`08c86000 fffff880`08c88000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  00002000
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01600000 fffff880`0160e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0160e000 fffff880`0161a000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0161a000 fffff880`01625000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`01430000 fffff880`01443000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`05473000 fffff880`054bf000   Rt64win7.sys
    Checksum:  00000000
    ImageSize:  0004C000
