- Thread Author
- #1
okay here's my problem i have had this issue for about two months now on and off and it is irritating the crap out of me. so my internet is more or less dying I can't for a period of time connect to the internet and when i go to the network and sharing center it doesn't identify my network even though I use it on a daily basis and have used it and identified it as my home network for eight months now. if I use the windows network diagnostics it gives me either the error in the title or it says "the dns server isn't responding" i have attempted to fix that problem by giving it a dns to use and have tried to set a static ip but nothing has worked. here is the text from the command prompt when i use the command ipconfig /all
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : BrycesHP
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Peer-Peer
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection 3:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #
2
Physical Address. . . . . . . . . : 74-E5-0B-32-C4-A7
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection 2:
DHCP Enabled. . . . . . . . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : domain.actdsltmp
Description . . . . . . . . . . . : Intel(R) WiFi Link 1000 BGN
Physical Address. . . . . . . . . : 74-E5-0B-32-C4-A6
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 10-1F-74-1C-20-2F
Link-local IPv6 Address . . . . . : fe80::d429:a16:8006:64e%11(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.6.78(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 235937652
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-16-3A-D5-08-10-1F-74-1D-36-78
DNS Servers . . . . . . . . . . . : 8.8.8.8
8.8.4.4
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Hamachi:
Description . . . . . . . . . . . : Hamachi Network Interface
Physical Address. . . . . . . . . : 7A-79-05-64-F5-8E
IPv6 Address. . . . . . . . . . . : 2620:9b::564:f58e(Preferred)
Link-local IPv6 Address . . . . . : fe80::7df9:98ff:d42:9234%21(Preferred)
IPv4 Address. . . . . . . . . . . : 5.100.245.142(Preferred)
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Lease Obtained. . . . . . . . . . : Wednesday, October 31, 2012 7:02:21 PM
Lease Expires . . . . . . . . . . : Saturday, November 02, 2013 2:35:05 PM
Default Gateway . . . . . . . . . : 5.0.0.1
DHCP Server . . . . . . . . . . . : 5.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 360348079
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter isatap.domain.actdsltmp:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Tunnel adapter isatap.{3807F475-DE85-4C51-8515-003158984420}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter isatap.{061E912B-7983-49F5-AE69-F67EC6A07488}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter isatap.{F8E84067-B45A-418C-AB07-52F5212FE251}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Tunnel adapter Reusable ISATAP Interface {119CBE7E-FD48-4087-9D68-80A038447264}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
so ya if you have any solutions please post them i would love to have this fixed.
Note: if this is a router problem I can't change any router settings but if not please don't blame it on that. also despite what my profile says i am running windows 7
2
8.8.4.4
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
