karimmaster
pls help me with this error, when i try to install some programs this error come to me "prog like HP smart webprinting - AT&T Natural Voice... "
and I have been search Google to get fix for this BUT I can't.
I looked at this support article at microsoft You receive an "Error 1606" error message when you try to install or remove a Microsoft program BUT the solve they suggest , (compare registry entries and replace them with the table) they mention this apply to xp and vista not 7
and when i try to replace I thought that there are a big difference between functionality vista and xp, So I am afraid to damage my registry and disable some functions of it
SO pls if anyone face this problem before and fix it , pls send me the correct registery to fix it
or any safe way to fix it
Pleaaaaaaaaaaaaase
Pleaaaaaaaaaaaaase
