Help me with my Blue Screen of Death (BSOD)
basically I had a prob with blue screens reformatted and reinstalled everything and now I am getting multiple Blue screens slowly. Memory Management / IRQL not equal/ bad pool header I will include the dmp file please help me
Problem signature:
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1033
Additional information about the problem:
BCCode: 1a
BCP1: 00000031
BCP2: 867CAB68
BCP3: 90E20000
BCP4: 949646E7
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\013011-25724-01.dmp
C:\Users\John\AppData\Local\Temp\WER-42151-0.sysdata.xml
Problem signature:
Locale ID: 1033
BCCode: a
BCP1: 80010057
BCP2: 00000002
BCP3: 00000000
BCP4: 8288AA57
Service Pack: 0_0
Product: 256_1
C:\Windows\Minidump\013011-21496-01.dmp
C:\Users\John\AppData\Local\Temp\WER-38142-0.sysdata.xml
BugCheck A, {80010057, 2, 0, 8288aa57}
Probably caused by : ntkrpamp.exe ( nt!KiInsertTimerTable+273 )
1. http://windows7forums.com/blue-scre...mportant-every-thread-starter-please-see.html
-----> MEMORY and SPD for EACH slot.
2. Uninstall Avast and update Realtek HD Audio driver:
avast! Uninstall Utility
https://www.microsoft.com/security_essentials/
Realtek
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\013011-25724-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Built by: 7600.16385.x86fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0x82813000 PsLoadedModuleList = 0x8295b810
Debug session time: Sun Jan 30 10:09:27.191 2011 (UTC - 5:00)
System Uptime: 0 days 0:00:28.329
Loading Kernel Symbols
Loading User Symbols
0: kd> !analyze -v
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 00000031, The subtype of the bugcheck.
Arg2: 867cab68
Arg3: 90e20000
Arg4: 949646e7
Debugging Details:
BUGCHECK_STR:  0x1a_31
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  audiodg.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 82a9be9c to 828efd10
STACK_TEXT:
8e1b99e4 82a9be9c 0000001a 00000031 867cab68 nt!KeBugCheckEx+0x1e
8e1b9a08 82a9bfe8 90e20000 02290000 6889d000 nt!MiApplyCompressedFixups+0x70
8e1b9a44 829ee835 867cab68 02290000 00000000 nt!MiPerformFixups+0x6d
8e1b9a74 829f20ec 972c2000 90e1f000 00003800 nt!MiValidateRelocatedImagePfn+0x231
8e1b9aa4 828c3cfe 867cab68 00003800 00000000 nt!MiValidateImagePfn+0xc5
8e1b9b04 829edcd4 8693ea20 00000000 00000000 nt!MiValidateImagePages+0x347
8e1b9b74 82a36678 877253c0 8693ea20 00000002 nt!MiValidateImageHeader+0x270
8e1b9c9c 82a43e51 8e1b9cf0 0000000f 00000000 nt!MmCreateSection+0x568
8e1b9d10 8285642a 0020f758 0000000f 00000000 nt!NtCreateSection+0x16e
8e1b9d10 773b64f4 0020f758 0000000f 00000000 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
0020f76c 00000000 00000000 00000000 00000000 0x773b64f4
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt!MiApplyCompressedFixups+70
82a9be9c cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!MiApplyCompressedFixups+70
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc007
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  0x1a_31_nt!MiApplyCompressedFixups+70
Followup: MachineOwner
Loading Dump File [F:\a\Minidump\D M P\DMP\013011-21496-01.dmp]
Machine Name:
Kernel base = 0x8281f000 PsLoadedModuleList = 0x82967810
Debug session time: Sun Jan 30 10:31:31.463 2011 (UTC - 5:00)
System Uptime: 0 days 0:21:14.601
Loading unloaded module list
0: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 80010057, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, bitfield :
Arg4: 8288aa57, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 82987718
Unable to read MiSystemVaType memory at 82967160
 80010057
CURRENT_IRQL:  2
FAULTING_IP:
8288aa57 8b521c          mov     edx,dword ptr [edx+1Ch]
BUGCHECK_STR:  0xA
PROCESS_NAME:  uTorrent.exe
TRAP_FRAME:  9a4b36f4 -- (.trap 0xffffffff9a4b36f4)
ErrCode = 00000000
eax=00000002 ebx=807c2a3c ecx=f7b8ad90 edx=8001003b esi=807c0020 edi=00000002
eip=8288aa57 esp=9a4b3768 ebp=9a4bdb98 iopl=0         nv up ei ng nz ac po cy
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010293
nt!KiInsertTimerTable+0x273:
8288aa57 8b521c          mov     edx,dword ptr [edx+1Ch] ds:0023:80010057=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from 8288aa57 to 828657eb
STACK_TEXT:
9a4b36f4 8288aa57 badb0d00 8001003b 90e5f9cb nt!KiTrap0E+0x2cf
9a4bdb98 00000000 00000000 00000000 00000000 nt!KiInsertTimerTable+0x273
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_NAME:  nt!KiInsertTimerTable+273
MODULE_NAME: nt
IMAGE_NAME:  ntkrpamp.exe
FAILURE_BUCKET_ID:  0xA_nt!KiInsertTimerTable+273
Drivers:
start    end        module name
82fae000 82ff6000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
90e3e000 90e98000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
96395000 963a7000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
90cc7000 90cd9000   amdk8    amdk8.sys    Mon Jul 13 19:11:03 2009 (4A5BBF07)
8bf92000 8bf9b000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
821ea000 821ecb00   aswFsBlk aswFsBlk.SYS Thu Jan 13 03:37:07 2011 (4D2EB9B3)
91b4d000 91b84000   aswMonFlt aswMonFlt.sys Thu Jan 13 03:37:17 2011 (4D2EB9BD)
90e98000 90e9c200   aswRdr   aswRdr.SYS   Thu Jan 13 03:37:29 2011 (4D2EB9C9)
90c5f000 90ca5480   aswSP    aswSP.SYS    Thu Jan 13 03:41:11 2011 (4D2EBAA7)
90e34000 90e3df00   aswTdi   aswTdi.SYS   Thu Jan 13 03:40:14 2011 (4D2EBA6E)
8befa000 8bf03000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
8bf03000 8bf26000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
95c05000 96298000   atikmdag atikmdag.sys Tue Oct 26 22:26:21 2010 (4CC78DCD)
91a4d000 91a8a000   atikmpag atikmpag.sys Tue Oct 26 22:14:03 2010 (4CC78AEB)
8c3eb000 8c3f2000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
90c51000 90c5f000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
82e3a000 82e42000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
9aab1000 9aaca000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
967c0000 967de000   cdd      cdd.dll      Mon Jul 13 21:04:18 2009 (4A5BD992)
8bfe0000 8bfff000   cdrom    cdrom.sys    Mon Jul 13 19:11:24 2009 (4A5BBF1C)
82e84000 82f2f000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
8c3af000 8c3d4000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
82e42000 82e84000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8c193000 8c1f0000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
96388000 96395000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
91bed000 91bfa000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
90f87000 90feb000   csc      csc.sys      Mon Jul 13 19:15:08 2009 (4A5BBFFC)
90c39000 90c51000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
90f7b000 90f87000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
8c400000 8c411000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
820f5000 8210e000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
9162c000 91636000   dump_diskdump dump_diskdump.sys Mon Jul 13 19:45:49 2009 (4A5BC72D)
90de2000 90df3000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
90dbd000 90de2000   dump_nvstor dump_nvstor.sys Wed May 20 02:44:09 2009 (4A13A6B9)
8210e000 82118000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
96298000 9634f000   dxgkrnl  dxgkrnl.sys  Mon Jul 13 19:26:15 2009 (4A5BC297)
9634f000 96388000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
8bfcf000 8bfe0000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
8bf9b000 8bfcf000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
8c000000 8c009000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
8c37d000 8c3af000   fvevol   fvevol.sys   Mon Jul 13 19:13:01 2009 (4A5BBF7D)
8c55f000 8c590000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:12:03 2009 (4A5BBF43)
82c2f000 82c66000   hal      halmacpi.dll Mon Jul 13 19:11:03 2009 (4A5BBF07)
9160d000 9162c000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
8213c000 8214f000   HIDCLASS HIDCLASS.SYS Mon Jul 13 19:51:01 2009 (4A5BC865)
8214f000 82155480   HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
82131000 8213c000   hidusb   hidusb.sys   Mon Jul 13 19:51:04 2009 (4A5BC868)
9aa2c000 9aab1000   HTTP     HTTP.sys     Mon Jul 13 19:12:53 2009 (4A5BBF75)
8c5f0000 8c5f8000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
91ad0000 91add000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
82156000 82162000   kbdhid   kbdhid.sys   Mon Jul 13 19:45:09 2009 (4A5BC705)
80bb8000 80bc0000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
90d89000 90dbd000   ks       ks.sys       Mon Jul 13 19:45:13 2009 (4A5BC709)
8c180000 8c193000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
8c32b000 8c350000   ksecpkg  ksecpkg.sys  Mon Jul 13 19:34:00 2009 (4A5BC468)
821ed000 821fd000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
821cf000 821ea000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
82e1e000 82e29000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 19:13:13 2009 (4A5BBF89)
91600000 9160d000   modem    modem.sys    Mon Jul 13 19:55:24 2009 (4A5BC96C)
82184000 8218f000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
91add000 91aea000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
82162000 8216d000   mouhid   mouhid.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
8bee4000 8befa000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
9aaca000 9aadc000   mpsdrv   mpsdrv.sys   Mon Jul 13 19:52:52 2009 (4A5BC8D4)
9aadc000 9aaff000   mrxsmb   mrxsmb.sys   Mon Jul 13 19:14:24 2009 (4A5BBFD0)
9aaff000 9ab3a000   mrxsmb10 mrxsmb10.sys Mon Jul 13 19:14:34 2009 (4A5BBFDA)
9ab3a000 9ab55000   mrxsmb20 mrxsmb20.sys Mon Jul 13 19:14:29 2009 (4A5BBFD5)
82e08000 82e13000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
82e00000 82e08000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
8c155000 8c180000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
90f71000 90f7b000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
8c5e0000 8c5f0000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
8c236000 8c2ed000   ndis     ndis.sys     Mon Jul 13 19:12:24 2009 (4A5BBF58)
963bf000 963ca000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
91bca000 91bda000   ndisuio  ndisuio.sys  Mon Jul 13 19:53:51 2009 (4A5BC90F)
963ca000 963ec000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
91b3c000 91b4d000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
90ef5000 90f03000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
90e9d000 90ecf000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
8c2ed000 8c32b000   NETIO    NETIO.SYS    Mon Jul 13 19:12:35 2009 (4A5BBF63)
90e04000 90e12000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
90f67000 90f71000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
8281f000 82c2f000   nt       ntkrpamp.exe Mon Jul 13 19:15:19 2009 (4A5BC007)
8c026000 8c155000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
8c5f8000 8c5ff000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
91a08000 91a4c880   nvmf6232 nvmf6232.sys Thu Jul 30 19:47:55 2009 (4A72312B)
8bf26000 8bf4b000   nvstor   nvstor.sys   Wed May 20 02:44:09 2009 (4A13A6B9)
91b84000 91bca000   nwifi    nwifi.sys    Mon Jul 13 19:51:59 2009 (4A5BC89F)
90ed6000 90ef5000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
8be63000 8be74000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
8be2e000 8be58000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
8becf000 8bed6000   pciide   pciide.sys   Mon Jul 13 19:11:19 2009 (4A5BBF17)
8bed6000 8bee4000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
8c1f0000 8c1fe000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
9ab55000 9abec000   peauth   peauth.sys   Mon Jul 13 20:35:44 2009 (4A5BD2E0)
820c6000 820f5000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
82e29000 82e3a000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
81e1a000 81e23000   rasacd   rasacd.sys   Mon Jul 13 19:54:40 2009 (4A5BC940)
963a7000 963bf000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
91a8a000 91aa2000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
91aa2000 91ab9000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
91ab9000 91ad0000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
90f26000 90f67000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
963ec000 963f6000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
8c016000 8c01e000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
8c01e000 8c026000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
8be21000 8be29000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
8c350000 8c37d000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
91bda000 91bed000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
81e29000 820c57c0   RTKVHDA  RTKVHDA.sys  Tue Aug 04 05:48:13 2009 (4A7803DD)
9abec000 9abf6000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
8c5d8000 8c5e0000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
9bc70000 9bcc1000   srv      srv.sys      Mon Jul 13 19:15:10 2009 (4A5BBFFE)
9bc21000 9bc70000   srv2     srv2.sys     Mon Jul 13 19:14:52 2009 (4A5BBFEC)
9aa00000 9aa21000   srvnet   srvnet.sys   Mon Jul 13 19:14:45 2009 (4A5BBFE5)
8bf4b000 8bf92000   storport storport.sys Mon Jul 13 19:45:58 2009 (4A5BC736)
963f6000 963f7380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
8c416000 8c55f000   tcpip    tcpip.sys    Mon Jul 13 19:13:18 2009 (4A5BBF8E)
90df3000 90e00000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
90e29000 90e34000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
90e12000 90e29000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
90f16000 90f26000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
96790000 96799000   TSDDD    TSDDD.dll    unavailable (00000000)
90ca6000 90cc7000   tunnel   tunnel.sys   Mon Jul 13 19:54:03 2009 (4A5BC91B)
8218f000 821cf000   udfs     udfs.sys     Mon Jul 13 19:14:09 2009 (4A5BBFC1)
91aea000 91af8000   umbus    umbus.sys    Mon Jul 13 19:51:38 2009 (4A5BC88A)
82118000 8212f000   usbccgp  usbccgp.sys  Mon Jul 13 19:51:31 2009 (4A5BC883)
8212f000 82130700   USBD     USBD.SYS     Mon Jul 13 19:51:05 2009 (4A5BC869)
90d2e000 90d3d000   usbehci  usbehci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
91af8000 91b3c000   usbhub   usbhub.sys   Mon Jul 13 19:52:06 2009 (4A5BC8A6)
90cd9000 90ce3000   usbohci  usbohci.sys  Mon Jul 13 19:51:14 2009 (4A5BC872)
90ce3000 90d2e000   USBPORT  USBPORT.SYS  Mon Jul 13 19:51:13 2009 (4A5BC871)
8216d000 82184000   USBSTOR  USBSTOR.SYS  Mon Jul 13 19:51:19 2009 (4A5BC877)
8be58000 8be63000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
8c3f2000 8c3fe000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
8be00000 8be21000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
8c590000 8c598380   vmstorfl vmstorfl.sys Mon Jul 13 19:28:44 2009 (4A5BC32C)
8be74000 8be84000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
8be84000 8becf000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
8c599000 8c5d8000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
90d3d000 90d89000   VSTBS23  VSTBS23.SYS  Wed Oct 15 20:30:15 2008 (48F68B17)
91741000 917f6000   VSTCNXT3 VSTCNXT3.SYS Wed Oct 15 20:29:13 2008 (48F68AD9)
9163f000 91741000   VSTDPV3  VSTDPV3.SYS  Wed Oct 15 20:32:04 2008 (48F68B84)
90f03000 90f16000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
8c009000 8c016000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
82f2f000 82fa0000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
82fa0000 82fae000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
90ecf000 90ed6000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
96530000 9677a000   win32k   win32k.sys   Mon Jul 13 19:26:26 2009 (4A5BC2A2)
82ff6000 82fff000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
81e00000 81e1a000   WudfPf   WudfPf.sys   Mon Jul 13 19:50:13 2009 (4A5BC835)
9bcc1000 9bce1480   WUDFRd   WUDFRd.sys   Mon Jul 13 19:50:44 2009 (4A5BC854)
Unloaded modules:
9bce2000 9bd4c000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
9ab55000 9ab6d000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8c3d4000 8c3e1000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8c3e1000 8c3eb000   dump_storpor
    Checksum:  00000000
    ImageSize:  0000A000
8c200000 8c225000   dump_nvstor.
    Checksum:  00000000
    ImageSize:  00025000
8c225000 8c236000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
Ok here is my speed and everything have a look and tell me what you think
Also is there anyway you could find me a link to my motherboard driver ..I am trying to find it but I am a dumbass
RAM frequency is set WRONG. Load setup defaults in the bios or set it manually 666Mhz. Reattach the memory tab with the new settings.
Also, you got 2 Hyunday's in slots #3 and #4 and 1 Kingston in slot #2 - this will not necessarily work well.
Sure:
Also check for updates for your nForce motherboard:
Drivers - Download NVIDIA Drivers
#7
a) How do you reset it manually ? because load setup default never worked
b) I read the link u sent but it lists every product they have I dont know what type/make my motherboard is (I just got this comp)
#8
Nevermind b) my google chrome wouldnt search for drivers
#9
oh wait ...yeah I need to know what motherboard ..for some reason the scan just brought up audio hardware that never worked
Elmer
#10
Download Speccy (FileHippo) or SIW (Freeware). Should help you with your details (you can even use them to help fill in your system specs under your UserCP).
#12
Should add don't worry if there are no updates for the nForce. The culprit of your crashes is the Ram, set it right and take it from there. If any more bsod's then re-attach the CPU-Z tabs and submit the latest crash dumps.
