- Thread Author
- #1
Hi
I noticed a few days ago that my computer power plan was wrong so went to control panel to change and it says some settings are managed by your administrator and wont let me choose anything.
- UAC is disabled
- My account is only admin account
- Global built in admin account is disabled
- System restore wont work
Basically the computer is still functioning to an extent
- Still have access to C:\ and my other drive
- can access cmd.exe
- also got access to system folder too
I have went through checked all the privileges for my user and the administrators group all are ok, used the "windows god mode" shortcut to check through the rest of the settings everything to my knowledge seems fine except a few basic rights it seems.
Also it blocks access to things like my AMD Fusion utility which works with the motherboard to control the Power plans (which i need to change)
So does anyone know how I can restore my admin rights? Bear in mind that I cannot do system restore I also tried it from F8 no go.
Greg
- UAC is disabled
Greg
