Help Needed
Hi Everyone,
This is my first post and I'm not sure I'm in the right section and have a couple of issues so thought I'd post them both here (Sorry if I'm in the wrong place)
Issue 1:
I have a Dell Inspiron 530 and installed Windows 7 Home onto it. PC is running fine but whenever I try and burn a DVD or CD I get the following message:
My drive is the generic drive that came with the PC and worked fine with XP installed.
I've searched everywhere in Dells support pages and Microsofts but cannot find a solution :frown:
Issue 2:
I have installed a secondary internal SATA drive tonight. Everythings worked out fine except for some reason, Windows 7 has installed all of this:
Is this normal? Can I just format the drive so it has nothing other than the system files needed?
Appreciate any help that can be offered
Daniel :)
Saltgrass
Issue 1:
What type of media are you using? If the fastest, the drive might not be able to recognize it. Usually a firmware update will help in this area. You could look for a different speed media to test. It may be hard to find the 2-4x stuff, but you might be able to.
Issue 2:
That looks like it was an old XP drive. Have you verified what was on it? You are still booting normally to the Win 7 drive? Just to confirm, you did not install Win 7 with the XP drive installed, right?
reghakr
Could you please fill in your computer specs in the UserCP link at the top left hand side of the page.
Then click Edit Your Details.
This freeware program will give you all the information you will need:
EVEREST Ultimate Edition v5.30
or
SIV (System Information Viewer) 4.04
The drive worked fine with the media I use when it was XP
I believe it was a new drive from Dell
No did a clean install of Win 7
or
Thanks for that,
I'm not very advanced with PC's to be honest and I'm not entirely sure what those links are for? lol
reghakr
They give you detailed information about the hardware on your machine.
Look under my name and you;ll see what I mean.
#7
Hi Everyone,Is this normal? Can I just format the drive so it has nothing other than the system files needed?
Daniel :)
There is no "selective" format feature. When you format a drive or partition all is gone, clean off, nothing is left. You should first look through everything and make sure you have backed up anything you want to keep.
