Help.. ntoskrnl.exe and Ntfs.sys BSOD
Hi..
I'm new on this forum, and I've been looking for a solution to my problem, but the solutions I find do not work with me..
I have BSOD caused by ntoskrnl.exe and by Ntfs.sys .. and I dont know how to solve my problem.
Ntfs.sys error appears at random, and I have the impression ntoskrnl.exe error that appears when I play games ..
can anyone help?
bump files are attached ..
sorry for my bad English ..
thanks in advance, I hope you can help me
122910-21278-01.dmp - CPU related, such as in a case of overclocking
BugCheck 101, {21, 0, fffff880009b1180, 4}
CLOCK_WATCHDOG_TIMEOUT (101)
An expected clock interrupt was not received on a secondary processor in an
MP system within the allocated interval. This indicates that the specified
processor is hung and not processing interrupts.
122810-24055-01.dmp - ntfs
NTFS_FILE_SYSTEM (24)
Ntfs.sys
Set the hardware clocks exactly as recommended by the manufacturer. No overclocking. Disable AMD Overdrive:
AODDriver2.sys Wed May 05 00:03:12 2010
AMD OverDrive Service Driver
Remove Avast, remove Antispyware, replace with MSE:
avast! Uninstall Utility
http://www.microsoft.com/security_essentials/
Uninstall Daemon Tools and remove its driver with the use of this tool:
DuplexSecure - FAQ
Remove Gygabite Tools:
gdrv.sys Thu Mar 12 23:22:29 2009
Update drivers:
eubakup.sys Tue Dec 01 23:19:57 2009
EuDisk.sys Tue Dec 01 23:20:08 2009
EASEUS Todo Backup
Rt64win7.sys Mon Mar 22 05:57:14 2010
Realtek 8136/8168/8169 NDIS 6.20 PCI/PCIe Adapters
RtNdPt60.sys Sun Jul 19 22:27:32 2009
Realtek NDIS Protocol Driver
RtHDMIVX.sys Tue Jan 26 22:04:58 2010
Realtek High Definition Audio
Crash Dump
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Loading Dump File [C:\Documents and Settings\XPMUser\My Documents\122910-21278-01.dmp]
Symbol search path is: SRV*C:\Documents and Settings\XPMUser\My Documents\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (6 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`03064000 PsLoadedModuleList = 0xfffff800`032a1e50
Debug session time: Wed Dec 29 12:33:44.539 2010 (UTC - 5:00)
System Uptime: 0 days 0:11:01.928
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
0: kd> !analyze -v
Arguments:
Arg1: 0000000000000021, Clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0.
Arg3: fffff880009b1180, The PRCB address of the hung processor.
Arg4: 0000000000000004, 0.
Debugging Details:
BUGCHECK_STR:  CLOCK_WATCHDOG_TIMEOUT_6_PROC
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  d
STACK_TEXT:
fffff880`05d5e478 fffff800`03082453 : 00000000`00000101 00000000`00000021 00000000`00000000 fffff880`009b1180 : nt!KeBugCheckEx
fffff880`05d5e480 fffff800`030dcde7 : 00000000`00000000 fffff800`00000004 00000000`00002711 fffff880`04902420 : nt! ?? ::FNODOBFM::`string'+0x4dfe
fffff880`05d5e510 fffff800`03025895 : fffff800`0304a460 fffff880`05d5e6c0 fffff800`0304a460 00000000`00000000 : nt!KeUpdateSystemTime+0x377
fffff880`05d5e610 fffff800`030d0c33 : fffff800`0324ee80 00000000`00000001 00000000`00000001 00000000`00000006 : hal!HalpHpetClockInterrupt+0x8d
fffff880`05d5e640 fffff800`030939e7 : fffff800`030e0b25 fffff880`05d5e728 fffff800`0324ee80 fffff880`05d5e860 : nt!KiInterruptDispatchNoLock+0x163
fffff880`05d5e7d0 fffff800`033d2568 : 00000000`00000000 fffff880`05d5eca0 fffff800`03064000 00000000`00000000 : nt!KeFlushProcessWriteBuffers+0x63
fffff880`05d5e840 fffff800`033d31e5 : 00000000`002fd240 fffff800`033cf10e 00000000`00000000 fffff800`030d384a : nt!ExpQuerySystemInformation+0x1368
fffff880`05d5ebe0 fffff800`030d3993 : 00000000`00000000 fffff880`05d5eca0 ffffffff`fffe7960 000007fe`fb6e0b48 : nt!NtQuerySystemInformation+0x4d
fffff880`05d5ec20 00000000`770600ba : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`00ebf388 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x770600ba
STACK_COMMAND:  kb
SYMBOL_NAME:  ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME:  Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_CLOCK_WATCHDOG_TIMEOUT_6_PROC_ANALYSIS_INCONCLUSIVE
Loading Dump File [C:\Documents and Settings\XPMUser\My Documents\122810-24055-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0305c000 PsLoadedModuleList = 0xfffff800`03299e50
Debug session time: Tue Dec 28 20:51:26.486 2010 (UTC - 5:00)
System Uptime: 0 days 0:01:40.499
BugCheck 24, {1904fb, fffff88005d1e5c8, fffff88005d1de30, fffff880012e47f3}
Probably caused by : Ntfs.sys ( Ntfs!NtfsOpenAttributeInExistingFile+613 )
4: kd> !analyze -v
    If you see NtfsExceptionFilter on the stack then the 2nd and 3rd
    parameters are the exception record and context record. Do a .cxr
    on the 3rd parameter and then kb to obtain a more informative stack
    trace.
Arguments:
Arg1: 00000000001904fb
Arg2: fffff88005d1e5c8
Arg3: fffff88005d1de30
Arg4: fffff880012e47f3
Debugging Details:
EXCEPTION_RECORD:  fffff88005d1e5c8 -- (.exr 0xfffff88005d1e5c8)
ExceptionAddress: fffff880012e47f3 (Ntfs!NtfsOpenAttributeInExistingFile+0x0000000000000613)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT:  fffff88005d1de30 -- (.cxr 0xfffff88005d1de30)
rax=fffff880012904c0 rbx=fffff8800337d850 rcx=fffffa80068307a0
rdx=fffffa800589f301 rsi=fffffa80068307a0 rdi=0400000000000000
rip=fffff880012e47f3 rsp=fffff88005d1e800 rbp=0000000000000000
 r8=fffff8a0001fd960  r9=0000000000000012 r10=fffffa80068307a0
r11=0000000010000000 r12=fffff8a0001fd520 r13=fffff8800128fa00
r14=0000000000000000 r15=00000000c0000022
iopl=0         nv up ei pl nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010206
Ntfs!NtfsOpenAttributeInExistingFile+0x613:
fffff880`012e47f3 488b8f88000000  mov     rcx,qword ptr [rdi+88h] ds:002b:04000000`00000088=????????????????
Resetting default scope
CURRENT_IRQL:  0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800033040e0
 ffffffffffffffff
FOLLOWUP_IP:
FAULTING_IP:
BUGCHECK_STR:  0x24
LAST_CONTROL_TRANSFER:  from fffff880012e4eff to fffff880012e47f3
STACK_TEXT:
fffff880`05d1e800 fffff880`012e4eff : fffffa80`068307a0 fffffa80`0589f350 fffff8a0`001fd960 fffff880`00000012 : Ntfs!NtfsOpenAttributeInExistingFile+0x613
fffff880`05d1e990 fffff880`012f5e76 : fffffa80`068307a0 fffffa80`0589f350 fffff8a0`001fd960 00000000`00000701 : Ntfs!NtfsOpenExistingPrefixFcb+0x1ef
fffff880`05d1ea80 fffff880`012f028d : fffffa80`068307a0 fffffa80`0589f350 fffff880`05d1ec60 fffff880`05d1eca8 : Ntfs!NtfsFindStartingNode+0x5e6
fffff880`05d1eb50 fffff880`01259c0d : fffffa80`068307a0 fffffa80`0589f350 fffff880`0337d850 fffffa80`067aab00 : Ntfs!NtfsCommonCreate+0x3dd
fffff880`05d1ed30 fffff800`030c45c7 : fffff880`0337d7c0 00000000`00490730 00000000`77d74270 00000000`00000000 : Ntfs!NtfsCommonCreateCallout+0x1d
fffff880`05d1ed60 fffff800`030c4581 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KySwitchKernelStackCallout+0x27
fffff880`0337d690 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSwitchKernelStackContinue
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  Ntfs!NtfsOpenAttributeInExistingFile+613
MODULE_NAME: Ntfs
IMAGE_NAME:  Ntfs.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc14f
STACK_COMMAND:  .cxr 0xfffff88005d1de30 ; kb
FAILURE_BUCKET_ID:  X64_0x24_Ntfs!NtfsOpenAttributeInExistingFile+613
Drivers
fffff880`04580000 fffff880`045be000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`04400000 fffff880`04445000   a5u0bwtl a5u0bwtl.SYS Tue Jul 14 17:12:55 2009 (4A5CF4D7)
fffff880`00d7e000 fffff880`00dd5000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02cc0000 fffff880`02d4a000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0448e000 fffff880`044a4000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`042a1000 fffff880`042b6000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`01162000 fffff880`0116d000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`07c4e000 fffff880`07c7f000   AODDriver2 AODDriver2.sys Wed May 05 00:03:12 2010 (4BE0EE00)
fffff880`04052000 fffff880`0405a000   AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`061e4000 fffff880`061ed000   aswFsBlk aswFsBlk.SYS Tue Sep 07 10:47:09 2010 (4C86506D)
fffff880`053c3000 fffff880`053fd000   aswMonFlt aswMonFlt.sys Tue Sep 07 10:47:32 2010 (4C865084)
fffff880`02d4a000 fffff880`02d54000   aswRdr   aswRdr.SYS   Tue Sep 07 10:47:47 2010 (4C865093)
fffff880`0402f000 fffff880`04052000   aswSP    aswSP.SYS    Tue Sep 07 10:52:07 2010 (4C865197)
fffff880`02cb0000 fffff880`02cc0000   aswTdi   aswTdi.SYS   Tue Sep 07 10:52:27 2010 (4C8651AB)
fffff880`01124000 fffff880`0112d000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0112d000 fffff880`01157000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`04805000 fffff880`04fdb000   atikmdag atikmdag.sys Thu Nov 04 23:47:56 2010 (4CD37E6C)
fffff880`042bf000 fffff880`0430a000   atikmpag atikmpag.sys Thu Nov 04 22:41:15 2010 (4CD36ECB)
fffff960`00970000 fffff960`009d1000   ATMFD    ATMFD.DLL    Tue Oct 19 23:05:45 2010 (4CBE5C89)
fffff880`015f9000 fffff880`01600000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0401e000 fffff880`0402f000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03da8000 fffff880`03dc6000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006d0000 fffff960`006f7000   cdd      cdd.dll      unavailable (00000000)
fffff880`01000000 fffff880`0102a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01216000 fffff880`01246000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d20000 fffff880`00d7e000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01547000 fffff880`015ba000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`0447e000 fffff880`0448e000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03c9e000 fffff880`03ca7000   cpuz134_x64 cpuz134_x64.sys Fri Jul 09 07:16:58 2010 (4C37052A)
fffff880`045ee000 fffff880`045fc000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0417c000 fffff880`041ff000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`04000000 fffff880`0401e000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`0416d000 fffff880`0417c000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01200000 fffff880`01216000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06109000 fffff880`0612b000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`044a4000 fffff880`044b0000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`03ccd000 fffff880`03ce0000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`0405a000 fffff880`04065000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`061ca000 fffff880`061d6000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0430a000 fffff880`043fe000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04200000 fffff880`04246000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`015e0000 fffff880`015eb000   eubakup  eubakup.sys  Tue Dec 01 23:19:57 2009 (4B15EAED)
fffff880`05322000 fffff880`05347000   EuDisk   EuDisk.sys   Tue Dec 01 23:20:08 2009 (4B15EAF8)
fffff880`015cb000 fffff880`015d6000   eufs     eufs.sys     Tue Dec 01 23:19:58 2009 (4B15EAEE)
fffff880`011b9000 fffff880`011cd000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0116d000 fffff880`011b9000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`015d6000 fffff880`015e0000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0148f000 fffff880`014c9000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0162b000 fffff880`01675000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`07896000 fffff880`0789f000   gdrv     gdrv.sys     Thu Mar 12 23:22:29 2009 (49B9D175)
fffff800`03013000 fffff800`0305c000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04fdb000 fffff880`04fff000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`06131000 fffff880`0618d000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`0619b000 fffff880`061b4000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`061b4000 fffff880`061bc080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0618d000 fffff880`0619b000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`03ce0000 fffff880`03da8000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01486000 fffff880`0148f000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04451000 fffff880`0446f000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0446f000 fffff880`0447e000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bc4000 fffff800`00bce000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`052df000 fffff880`05322000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`0152d000 fffff880`01547000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01600000 fffff880`0162b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`0612b000 fffff880`06130200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`02deb000 fffff880`02e00000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06000000 fffff880`06023000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cff000 fffff880`00d0c000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`061d6000 fffff880`061e4000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`052ce000 fffff880`052dd000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`061bd000 fffff880`061ca000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`0110a000 fffff880`01124000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03dc6000 fffff880`03dde000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`03c00000 fffff880`03c2d000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`03c2d000 fffff880`03c7b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`03c7b000 fffff880`03c9e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01157000 fffff880`01162000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02c69000 fffff880`02c74000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e00000 fffff880`00e0a000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`014cf000 fffff880`0152d000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`04162000 fffff880`0416d000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01694000 fffff880`016a6000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`016a8000 fffff880`0179a000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`045e2000 fffff880`045ee000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04246000 fffff880`04275000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`06080000 fffff880`06095000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02ddc000 fffff880`02deb000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d54000 fffff880`02d99000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0179a000 fffff880`017fa000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02c74000 fffff880`02c85000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`04156000 fffff880`04162000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0305c000 fffff800`03638000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01248000 fffff880`013eb000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`013f7000 fffff880`01400000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02da2000 fffff880`02dc8000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`0106d000 fffff880`01082000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`0103a000 fffff880`0106d000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`010f3000 fffff880`010fa000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`010fa000 fffff880`0110a000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`052ae000 fffff880`052c2380   pcouffin pcouffin.sys Tue Dec 05 09:39:30 2006 (457584A2)
fffff880`015ba000 fffff880`015cb000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`078a1000 fffff880`07947000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`060cc000 fffff880`06109000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d0c000 fffff880`00d20000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`045be000 fffff880`045e2000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05258000 fffff880`05273000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`05273000 fffff880`05294000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`05294000 fffff880`052ae000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`04105000 fffff880`04156000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`052c3000 fffff880`052ce000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02c4e000 fffff880`02c57000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02c57000 fffff880`02c60000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02c60000 fffff880`02c69000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0144c000 fffff880`01486000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02c00000 fffff880`02c18000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`044b7000 fffff880`0450e000   Rt64win7 Rt64win7.sys Mon Mar 22 05:57:14 2010 (4BA73EFA)
fffff880`06095000 fffff880`060cbd80   RtHDMIVX RtHDMIVX.sys Tue Jan 26 22:04:58 2010 (4B5FAD5A)
fffff880`061ed000 fffff880`061f9000   RtNdPt60 RtNdPt60.sys Sun Jul 19 22:27:32 2009 (4A63D614)
fffff880`040fb000 fffff880`04105000   SASDIFSV64 SASDIFSV64.SYS Mon Feb 08 19:11:52 2010 (4B70A848)
fffff880`040f1000 fffff880`040fb000   SASKUTIL64 SASKUTIL64.SYS Tue Feb 09 17:27:34 2010 (4B71E156)
fffff880`00cc0000 fffff880`00cef000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`07947000 fffff880`07952000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04445000 fffff880`04451000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`00de2000 fffff880`00dff000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0168d000 fffff880`01694000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`01685000 fffff880`0168d000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`07c7f000 fffff880`07cf0000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`00ec8000 fffff880`00fee000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`07800000 fffff880`07896000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`07991000 fffff880`079f8000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`07952000 fffff880`0797f000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`052dd000 fffff880`052de480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01800000 fffff880`019fd000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0797f000 fffff880`07991000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02ca3000 fffff880`02cb0000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02c85000 fffff880`02ca3000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`040dd000 fffff880`040f1000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004f0000 fffff960`004fa000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0427b000 fffff880`042a1000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`05200000 fffff880`05254000   udfs     udfs.sys     Mon Jul 13 19:23:37 2009 (4A5BC1F9)
fffff880`05347000 fffff880`05359000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`05385000 fffff880`05386f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`0456f000 fffff880`04580000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`06026000 fffff880`06080000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`0450e000 fffff880`04519000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04519000 fffff880`0456f000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`05376000 fffff880`05385000   usbrpm   usbrpm.sys   Mon Jul 13 20:35:14 2009 (4A5BD2C2)
fffff880`00dd5000 fffff880`00de2000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0102a000 fffff880`01038000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02c19000 fffff880`02c3e000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01675000 fffff880`01685000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`01082000 fffff880`01097000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01097000 fffff880`010f3000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01400000 fffff880`0144c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`05387000 fffff880`053c3000   vpchbus  vpchbus.sys  Sat Sep 12 16:59:38 2009 (4AAC0BBA)
fffff880`02dc8000 fffff880`02ddc000   vpcnfltr vpcnfltr.sys Sat Sep 12 16:59:34 2009 (4AAC0BB6)
fffff880`05359000 fffff880`05376000   vpcusb   vpcusb.sys   Sat Sep 12 16:59:39 2009 (4AAC0BBB)
fffff880`04086000 fffff880`040dc180   vpcvmm   vpcvmm.sys   Sat Sep 12 16:59:38 2009 (4AAC0BBA)
fffff880`0406b000 fffff880`04086000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02c3e000 fffff880`02c4e000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e15000 fffff880`00eb9000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00eb9000 fffff880`00ec8000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d99000 fffff880`02da2000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a0000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`042b6000 fffff880`042bf000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fee000 fffff880`00ff7000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`011cd000 fffff880`011ee000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`07cf0000 fffff880`07cf6000   RTCore64.sys
    Checksum:  00000000
    ImageSize:  00006000
fffff880`015eb000 fffff880`015f9000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`013eb000 fffff880`013f7000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`011cd000 fffff880`011d8000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`011d8000 fffff880`011eb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
hey! tnx for the reply..
I was OCing my cpu, so I went back to the defaults values. I also updated the drivers you told me, and it seems that far so good! I hope not to have more problems in the future!
can close this thread! thanks for the help and quick response! ubiese I never imagined that it was the fault of the OC!
adios! thank you very much
(again, sorry for my bad english)
Sure thing, you're much welcome and happy holidays.
