Windows 7 Help omg
sameh83
Well-Known Member
I just went into BIOS and changed settings back to DEFAULT ! Now, i can't get into the computer anymore, Blue screen ! Help
Not much of a problem. Actually good. We can look at how to make your pc "better" now.
Boot to safe mode + networking. Tap f8 continuously on the keyboard while powering on to get the screen to choose to do so. Then go to C:\Windows\Minidump
Copy the files in there to any other folder then zip them. Attach the zip to a post using the paperclip above where you type, in advanced mode reply.
Just tried to boot in safe mode ! I got through, then it gave me the blue screen and an error !
"A problem has been detected and windows has been shut down to prevent damage to your computer !
I can't even boot !
You probably changed the SATA mode by reverting to default settings.
Try changing that to different settings, such as AHCI mode, IDE mode, SATA mode...etc...
Reboot with each try until successful. No big deal.
Thank you for the help ! I got the problem under control now ! lol
I thought it was done for good !
I guess i was wrong !
Thank you
Top Bottom
