Windows 7 Help please!! ASAP!
leslieerin86
Help!!
Okay, the laptop I have did not come with a Windows Vista reinstall disk and nothing on my computer is working. The internet says that it is connected but I can't surf the web because it comes up with a message saying "failed to connect". I have searched the internet on my desktop for help and none of the suggestions worked.
My question is, can I get 7 on my desktop (which the internet works on for some odd reason), save it to a hard drive and then install it on my laptop?
I need an answer asap! I wanted to ask before I spent the money on it.
Thanks in advance,
Leslie
Thanks in advance,
Leslie
How are you connected to internet ?
1. Depending on your internet connection type, you may need to set up all the required parameters (e.g. IPV4).
2. If you use firewall, it shouldn't block your internet connection/btowser/ports.
(3. If you browse through an external proxy server, it my be the cause too).
Top Bottom
