Please provide this info so we can provide a complete analysis of your problem:
Both memory dumps blame networking components. The older memory dump blames your wired network device driver: Rtlh64.sys ( More info on it here:
Link Removed ).
Please:
- download a fresh copy of the appropriate driver package from
- un-install the current wired networking drivers
- install the freshly downloaded drivers
- monitor for further BSOD's
rixdpe64.sys Tue Jan 13 23:50:48 2009 (496D6F28)
Ricoh Memory Card Reader driver
rimspe64.sys Thu Mar 26 00:21:28 2009 (49CB02C8)
bcmwl664.sys Thu Mar 26 21:06:57 2009 (49CC26B1)
Broadcom 802.11g Network Adapter - Dell Wireless 1390 WLAN Mini-Card
btwl2cap.sys Fri Apr 3 20:28:45 2009 (49D6A9BD)
Broadcom Bluetooth L2CAP Servicen
Rtlh64.sys Tue Jun 16 03:07:52 2009 (4A3744C8)
Realtek 8101/8168/8169 Wired Network Driver
btwavdt.sys Thu Jun 25 01:50:13 2009 (4A431015)
Broadcom Bluetooth AVDT Service
btwrchid.sys Thu Jun 25 01:51:37 2009 (4A431069)
Bluetooth Remote Control HID Minidriver
SynTP.sys Fri Jun 26 14:35:47 2009 (4A451503)
Synaptic Touch Pad Driver
Acceler.sys Fri Jun 26 16:56:34 2009 (4A453602)
Accelerometer - in this case Dell, however the same driver could be used by other manufacturers
btwaudio.sys Wed Jul 1 09:54:56 2009 (4A4B6AB0)
Broadcom Bluetooth Audio Device
stdflt.sys Thu Jul 16 11:36:50 2009 (4A5F4912)
Dell OEM Accelerometer driver
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Sat Dec 1 15:37:40.961 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\120212-15537-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17514.amd64fre.win7sp1_rtm.101119-1850
System Uptime:[B]0 days 2:06:05.976[/B]
*** ERROR: Module load completed but symbols could not be loaded for tcpip.sys
Probably caused by :[B]tcpip.sys ( tcpip+1245bc )[/B]
BugCheck [B]1E, {0, 0, 0, 0}[/B]
BugCheck Info: [B]Link Removed[/B]
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
BUGCHECK_STR: 0x1E
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_tcpip+1245bc[/B]
CPUID: "Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz"
MaxSpeed: 1600
CurrentSpeed: [B]1596[/B]
BIOS Version A09
BIOS Release Date 03/30/2011
Manufacturer Dell Inc.
Product Name Studio 1557
**************************Thu Nov 29 21:13:57.769 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\113012-14508-01.dmp]
System Uptime:[B]0 days 6:32:08.784[/B]
Probably caused by :[B]pci.sys[/B]
BugCheck [B]9F, {3, fffffa8004927a10, fffff80000b9c518, fffffa80040da1c0}[/B]
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8004927a10, Physical Device Object of the stack
Arg3: fffff80000b9c518, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa80040da1c0, The blocked IRP
BUGCHECK_STR: 0x9F
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x9F_3_Rtlh64_IMAGE_pci.sys[/B]
MaxSpeed: 1600
BIOS Version A09
[/font]
3rd Party Drivers:
[B]rixdpe64.sys Tue Jan 13 23:50:48 2009 (496D6F28)[/B]
[B]rimspe64.sys Thu Mar 26 00:21:28 2009 (49CB02C8)[/B]
[B]bcmwl664.sys Thu Mar 26 21:06:57 2009 (49CC26B1)[/B]
[B]btwl2cap.sys Fri Apr 3 20:28:45 2009 (49D6A9BD)[/B]
[B]Rtlh64.sys Tue Jun 16 03:07:52 2009 (4A3744C8)[/B]
[B]btwavdt.sys Thu Jun 25 01:50:13 2009 (4A431015)[/B]
[B]btwrchid.sys Thu Jun 25 01:51:37 2009 (4A431069)[/B]
[B]SynTP.sys Fri Jun 26 14:35:47 2009 (4A451503)[/B]
[B]Acceler.sys Fri Jun 26 16:56:34 2009 (4A453602)[/B]
[B]btwaudio.sys Wed Jul 1 09:54:56 2009 (4A4B6AB0)[/B]
intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[B]stdflt.sys Thu Jul 16 11:36:50 2009 (4A5F4912)[/B]
AtiHdmi.sys Fri Jul 24 02:33:11 2009 (4A6955A7)
atikmdag.sys Wed Jul 29 23:33:27 2009 (4A711487)
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
epfwwfp.sys Tue Jun 28 03:30:08 2011 (4E098300)
epfw.sys Tue Jun 28 03:30:10 2011 (4E098302)
ehdrv.sys Tue Jun 28 03:34:38 2011 (4E09840E)
EpfwLWF.sys Mon Jul 11 12:19:38 2011 (4E1B229A)
eamonm.sys Tue Aug 2 05:33:29 2011 (4E37C469)
[/font]
