Help please
So up until a few weeks ago my comp has been working flawlessly. I went on vaction for a week and came back turned by comp on and got a beep error code. I took out and reseated my ram and all was good for (close to a month) until this week. My computer went haywire was crashing non-stop BSOD or just plain restarting with no crash errors sometimes. I tried to update win 7 as couldn't bc of file corruption. So I reinstalled windows and even that took multiple tries. I finally got everything reinstalled and the system stable, but im still having some issues.
Whenever I am playing any game after a short while the computer will just freeze or sometimes restart. Sometimes I will get and error message and some times I won't. I also will get the beep code again from time to time. This is my most resent and biggest issue atm. this just started friday, thursday I was able to play BFBC2 for multiple hours with no issues. I have tried multiple games including torchlight which isn't graphically demanding and the same thing happens. After short while of playing the game freezes and my comp restrats itself. I have only gotten BSODs a couple times with this problem.
The beep code is three long continous beeps(I think). which is a key board error or usb port/mobo error. I have switched mouse and keyboard along with my usb headset and still the samething happens. Also somthing I forgot to mention was sometimes watching videos will cause a BSOD less crash and restart.
Earlier this week when everything was haywire I did checkdisk found some bad sectors and repaired them. I have run checkdisk numerious times since I renistalled and everything is fine. when I reinstalled windows 7 it kept all my old files in a folder called winold (or somthing like that). when I was trying to delete it my comp crashed and I came back and all the files were gone like they had been deleted. Do I have somhing stuck in limbo somewhere casuing a problem?
I have been using whocrashed to look at my dumpfiles and most are ntoskrnl.exe and unknown module. I don't really have that many third party driver on my system atm so I don't know what it is. I also have looked up ntoskrnl and all the fixes I find are for XP not win 7 which is utterly frustrating to me.
My setup:
Windows 7 Home Premiumx64
GigaByte GA-770T-USB3 AMD 770
AMD Phenom II x4 965 3.40ghz
GTX 460
8 gigs of ram ADATA DDR3/1600MHz Dual Channel Memory Module(4x2 gig sticks)
500 gig hardrive
No has replied yet but I tried reinstalling my nvida driver hoping that what causing me to crash, but it wasn't. This time I was given a BSOD error screen. When I used who crashed it says a third party driver is a probable cause, but says unknown driver. Can anybody help?
Updated with CPUID shots and SF Diagnostic tool info. Please some one help meh :(
nmsuk
Windows Forum Admin
I'm looking through it all now, RL got in the way sorry
nmsuk
Windows Forum Admin
Can you update the chipset drivers for you board from AMD, can you also update your video card drivers from Nvidia and then see how it behaves.
If I notice any more drivers that are old I'll let you know.
Elmer
Hi warheart and Welcome to The Forum.
STOP 0x0000003B: SYSTEM_SERVICE_EXCEPTION
Usual causes:
System service, Device driver, graphics driver, ?memory
Your latest dump file lists ntkrnlmp.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
As a Priority:
gdrv.sys Fri Mar 13 03:22:29 2009 Gigabyte Easy Saver. If you cannot update this then uninstall it.
Drivers with Updates:
nusb3hub.sys Fri Nov 20 10:15:57 2009
nusb3xhc.sys Fri Nov 20 10:16:01 2009
Go to your Motherboard Mfr. Support website and update your USB 3.0 drivers. Possible update Here.
Rt64win7.sys Thu Aug 20 17:05:06 2009 Realtek PCIe GBE Family Controller v7.046
RTKVHD64.sys Tue Dec 08 10:20:05 2009 Realtek HD Audio R2.63
XENfiltv.sys Fri Jul 31 04:40:32 2009 Check for update. Sound Blaster Tactic(3d) Sigma Driver
Arctosa.sys Wed Aug 19 08:57:20 2009 Check for update. Razer Arctosa Keyboard Driver
Bugcheck Analysis:
BugCheck 3B, {c0000005, fffff80004112a42, fffff8800787a020, 0}
Probably caused by : ntkrnlmp.exe ( nt!CmpDestroySecurityCache+3a )
Followup: MachineOwner
2: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80004112a42, Address of the instruction which caused the bugcheck
Arg3: fffff8800787a020, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`04112a42 48894108        mov     qword ptr [rcx+8],rax
CONTEXT:  fffff8800787a020 -- (.cxr 0xfffff8800787a020)
rax=fffff8a008b9ad58 rbx=fffff8a00f08e010 rcx=7ffff8a00f08ea10
rdx=00000000e3534d43 rsi=000000000000007b rdi=00000000000007b0
rip=fffff80004112a42 rsp=fffff8800787aa00 rbp=0000000000000000
 r8=0000000000000002  r9=0000000000000140 r10=fffff80003e09000
r11=00000000000000af r12=0000000000000002 r13=0000000000000000
r14=0000000000000001 r15=0000000000000000
iopl=0         nv up ei ng nz na pe cy
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010283
nt!CmpDestroySecurityCache+0x3a:
fffff800`04112a42 48894108        mov     qword ptr [rcx+8],rax ds:002b:7ffff8a0`0f08ea18=????????????????
Resetting default scope
BUGCHECK_STR:  0x3B
PROCESS_NAME:  TrustedInstall
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff8000410cc54 to fffff80004112a42
STACK_TEXT:
fffff880`0787aa00 fffff800`0410cc54 : fffff8a0`0f08e010 fffff880`0787aac0 fffff8a0`0a85e008 fffff880`0787aa48 : nt!CmpDestroySecurityCache+0x3a
fffff880`0787aa30 fffff800`0410c975 : fffff8a0`08fd9120 fffff880`0787aca0 00000000`00000000 00000000`00000006 : nt!CmUnloadKey+0x138
fffff880`0787aa70 fffff800`03e87f93 : fffffa80`0733d060 000007fe`ff673110 00000000`00000001 fffffa80`0720b201 : nt!NtUnloadKey2+0x4e4
fffff880`0787ac20 00000000`77452b9a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`00b2e138 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77452b9a
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!CmpDestroySecurityCache+3a
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4d9fdd5b
STACK_COMMAND:  .cxr 0xfffff8800787a020 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!CmpDestroySecurityCache+3a
Drivers:
fffff880`13da6000 fffff880`13de4000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00ee4000 fffff880`00f3b000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`0116d000 fffff880`011f6000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`13de4000 fffff880`13dfa000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`04026000 fffff880`0403b000   amdppm   amdppm.sys   Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`00ff2000 fffff880`00ffd000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`05d51000 fffff880`05d55d80   Arctosa  Arctosa.sys  Wed Aug 19 08:57:20 2009 (4A8BB060)
fffff880`07671000 fffff880`0767c000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00fe9000 fffff880`00ff2000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e00000 fffff880`00e2a000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`01600000 fffff880`01607000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`041ca000 fffff880`041db000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`071be000 fffff880`071dc000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`006b0000 fffff960`006d7000   cdd      cdd.dll      unavailable (00000000)
fffff880`05c50000 fffff880`05c6d000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`019cc000 fffff880`019f6000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00d0d000 fffff880`00dcd000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01966000 fffff880`01996000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00caf000 fffff880`00d0d000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`010d9000 fffff880`0114b000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`03fea000 fffff880`03ffa000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`05c6d000 fffff880`05c7b000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`041ac000 fffff880`041ca000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`0419d000 fffff880`041ac000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01950000 fffff880`01966000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`04499000 fffff880`044bb000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05c87000 fffff880`05c90000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`05c7b000 fffff880`05c87000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`05c90000 fffff880`05ca3000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`05d1a000 fffff880`05d26000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`03ed9000 fffff880`03fcd000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`03e00000 fffff880`03e46000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`0767c000 fffff880`076b2000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`03eb8000 fffff880`03ec5000   fdc      fdc.sys      Tue Jul 14 01:00:54 2009 (4A5BCAB6)
fffff880`01067000 fffff880`0107b000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`045b4000 fffff880`045bf000   flpydisk flpydisk.sys Tue Jul 14 01:00:54 2009 (4A5BCAB6)
fffff880`0101b000 fffff880`01067000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`013de000 fffff880`013e8000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01916000 fffff880`01950000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01823000 fffff880`0186d000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`0778a000 fffff880`07793000   gdrv     gdrv.sys     Fri Mar 13 03:22:29 2009 (49B9D175)
fffff800`043f2000 fffff800`0443b000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`03e46000 fffff880`03e6a000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`04400000 fffff880`0445c000   HdAudio  HdAudio.sys  Sat Nov 20 10:44:23 2010 (4CE7A687)
fffff880`05cc1000 fffff880`05cda000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`05cda000 fffff880`05ce2080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`05cb3000 fffff880`05cc1000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`070f5000 fffff880`071be000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`0190d000 fffff880`01916000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`1304b000 fffff880`1305a000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05d56000 fffff880`05d64000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00bba000 fffff800`00bc4000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`044ee000 fffff880`04531000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013b2000 fffff880`013cd000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`044bb000 fffff880`044c0200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`05ce3000 fffff880`05cf9000   LHidFilt LHidFilt.Sys Sat Apr 30 12:51:39 2011 (4DBBF7CB)
fffff880`05dd1000 fffff880`05de6000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05d06000 fffff880`05d1a000   LMouFilt LMouFilt.Sys Sat Apr 30 12:51:45 2011 (4DBBF7D1)
fffff880`05d8d000 fffff880`05db0000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`05ca3000 fffff880`05cb3000   LUsbFilt LUsbFilt.Sys Sat Apr 30 12:51:49 2011 (4DBBF7D5)
fffff880`00c8e000 fffff880`00c9b000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 02:29:09 2009 (4A5BDF65)
fffff880`05d26000 fffff880`05d34000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`015ee000 fffff880`015fd000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05cf9000 fffff880`05d06000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00fcf000 fffff880`00fe9000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`071dc000 fffff880`071f4000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`07000000 fffff880`0702d000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`0702d000 fffff880`0707b000   mrxsmb10 mrxsmb10.sys Wed Apr 27 03:39:40 2011 (4DB781EC)
fffff880`0707b000 fffff880`0709f000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`015c5000 fffff880`015d0000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f44000 fffff880`00f4e000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`0107b000 fffff880`010d9000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`04192000 fffff880`0419d000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`018fb000 fffff880`0190d000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`014c9000 fffff880`015bc000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`13024000 fffff880`13030000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`00c5c000 fffff880`00c8b000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`045bf000 fffff880`045d4000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`040da000 fffff880`040e9000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`04066000 fffff880`040ab000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`015d0000 fffff880`015e1000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`04186000 fffff880`04192000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03e09000 fffff800`043f2000   nt       ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff880`0120f000 fffff880`013b2000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`019f6000 fffff880`019ff000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`04543000 fffff880`0455a000   nusb3hub nusb3hub.sys Fri Nov 20 10:15:57 2009 (4B066C5D)
fffff880`03e6a000 fffff880`03e9a000   nusb3xhc nusb3xhc.sys Fri Nov 20 10:16:01 2009 (4B066C61)
fffff880`13d0c000 fffff880`13d11000   nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`1305e000 fffff880`13d0c000   nvlddmkm nvlddmkm.sys Sat May 21 05:07:04 2011 (4DD73A68)
fffff880`040b4000 fffff880`040da000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`03fcd000 fffff880`03fea000   parport  parport.sys  Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`00f8e000 fffff880`00fa3000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f4e000 fffff880`00f81000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00fb8000 fffff880`00fbf000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00fbf000 fffff880`00fcf000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`013cd000 fffff880`013de000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`074bc000 fffff880`07562000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0445c000 fffff880`04499000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c9b000 fffff880`00caf000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`13000000 fffff880`13024000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`13030000 fffff880`1304b000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04044000 fffff880`04065000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`041db000 fffff880`041f5000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`04135000 fffff880`04186000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`01615000 fffff880`0161e000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`014c0000 fffff880`014c9000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`015bc000 fffff880`015c5000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`018c1000 fffff880`018fb000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`05de6000 fffff880`05dfe000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`13d11000 fffff880`13d50000   Rt64win7 Rt64win7.sys Thu Aug 20 17:05:06 2009 (4A8D7432)
fffff880`05a32000 fffff880`05c4f300   RTKVHD64 RTKVHD64.sys Tue Dec 08 10:20:05 2009 (4B1E2855)
fffff880`07562000 fffff880`0756d000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`03ec5000 fffff880`03ed1000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`040e9000 fffff880`04106000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`018b9000 fffff880`018c1000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`076f2000 fffff880`0778a000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`07400000 fffff880`07469000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0756d000 fffff880`0759e000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`03ffa000 fffff880`03ffb480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0161f000 fffff880`01823000   tcpip    tcpip.sys    Mon Apr 25 03:37:30 2011 (4DB4DE6A)
fffff880`0759e000 fffff880`075b0000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`015e1000 fffff880`015ee000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`0114b000 fffff880`0116d000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`04121000 fffff880`04135000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00420000 fffff960`0042a000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`04000000 fffff880`04026000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`04531000 fffff880`04543000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`05d64000 fffff880`05d7ec80   usbaudio usbaudio.sys Sat Nov 20 10:43:52 2010 (4CE7A668)
fffff880`05d34000 fffff880`05d51000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`03e9a000 fffff880`03e9bf00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`03ea7000 fffff880`03eb8000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`0455a000 fffff880`045b4000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`03e9c000 fffff880`03ea7000   usbohci  usbohci.sys  Fri Mar 25 03:29:03 2011 (4D8C0BFF)
fffff880`13d50000 fffff880`13da6000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`00f81000 fffff880`00f8e000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01607000 fffff880`01615000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0148b000 fffff880`014b0000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00fa3000 fffff880`00fb8000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`0186d000 fffff880`018b9000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`04106000 fffff880`04121000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`014b0000 fffff880`014c0000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e31000 fffff880`00ed5000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ed5000 fffff880`00ee4000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`040ab000 fffff880`040b4000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00040000 fffff960`00353000   win32k   win32k.sys   Sat Jun 11 04:06:57 2011 (4DF2DBD1)
fffff880`0403b000 fffff880`04044000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f3b000 fffff880`00f44000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`05db0000 fffff880`05dd1000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`05d7f000 fffff880`05d8d000   XENfiltv XENfiltv.sys Fri Jul 31 04:40:32 2009 (4A7267B0)
Unloaded modules:
fffff880`07600000 fffff880`07671000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01996000 fffff880`019a4000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`019a4000 fffff880`019b0000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`019b0000 fffff880`019b9000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`019b9000 fffff880`019cc000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Like buses. Don't see one for ages and then two come along together!! :D
nmsuk
Windows Forum Admin
#7
Elmer noticed your memory voltage is a bit low, can you set it in the bios to 1.65v please. Been through a STOP 0x3B earlier and it turned out to be the memory volts on High perf. RAM.
#8
Thank you both. I am working updated drivers and will change my memory volatge. To my knowledge unless new Nvida drives came out since last night(tried uninstalling and reinstalling). Mine are the newest ones. there are no updates for the acrosta keyboard, but if I have to I can unistall the driver. It doesn't really do much and I have no macros for it.
While I was waiting for replies I tried Bad Company again. Same story.....runs flawlessly for a few minutes then while playing it crashes. I actually got a stop error this time instead of the comp self restarting. I attached it below.
nmsuk
Windows Forum Admin
#9
Just been checking you drivers, and a few are out of date. You can update you creative drivers using their auto updater
Realtek Audio from Here and Realtek Network from here. The latest AMD drivers for your board can be got here
I think that covers them all :)
